MESA PWM
- kostas
- Thank you received: 6
13 Feb 2014 23:05 #43828
by kostas
How?
Replied by kostas on topic MESA PWM
That said, Its probably possible to make a bitfile with inverted PWM output with some minor VHDL hacking
How?
- Thank you received: 5283
13 Feb 2014 23:19 - 13 Feb 2014 23:20 #43830
Replied by PCW on topic MESA PWM
As a quit hack, changing:
in pwmpdmgen.vhd should work
if (UNSIGNED(maskedrefcount) < UNSIGNED(pwmval)) then
pwm <= '1';
else
pwm <= '0';
end if;
to
pwm <= '0';
else
pwm <= '1';
end if;
Last edit: 13 Feb 2014 23:20 by PCW. Reason: formatting
- eslavko
- Thank you received: 4
14 Feb 2014 02:44 #43834
by eslavko
Replied by eslavko on topic MESA PWM
Use hardware watchdog!!!
At startup ALL driver enable should be dissabled. When LinuxCNC starts then use F1 estop latch to kick watchdog on hardware pin. So in meantime you should set other pins correctly. Kep this as safery feature. When you plug in machine nothing should happen! Even when PC is booted up. (if you use just parport then there is mess of signals in bootup process) NOTHING SHOULD HAPPEN UNTIL YOU PRES F1 AND/OR EXTERNAL POWERON BUTTON.
This cost one extra releay and few diodes to make chargepump. It cost nothing compared to fingers!
- kostas
14 Feb 2014 03:54 #43835
by kostas
This works as advertised. Thanks Peter!
Eslavko, that's why I'm worried of this small pulse at the beggining.
I probably should have an enable pin in my hardware somewhere but for the work I'm doing now it does not really matter and there are no safety issues.
This is a very small machine, actually a toy of mine. Anyway, this should work ok now.
- eslavko
14 Feb 2014 04:24 #43836
by eslavko
Even toy machine can drill trought a finger...
At least wire E-Stop properly. Don't rely on F1/ESC. The LinuxCnc window can lost focus and keyboard will not respond.
- vre
- Thank you received: 19
20 Jul 2014 06:29 #48957
by vre
Replied by vre on topic MESA PWM
What is max pwm frequency for driving spindle with mesa cards ?
Also can i change that frequency to 5khz or 10khz ?
20 Jul 2014 09:14 #48960
The PWM rate is settable to a few Hz up to ClockHigh/512
Clock high is either 100 MHz or 200 Mhz depending on FPGA card
This makes the maximum PWMrate ~192 KHz or ~384 KHz depending on FPGA card
The PWM rate is a global setting however so if you have multiple devices using the PWM,
they all have to use the same frequency. The PDM rate setting is separate however so if you
need different rates, and some devices can use PDM (7I48 and 7I33 can for example) this allows
an independent PWM rate to be set
The following user(s) said Thank You: vre
- vre
20 Jul 2014 11:32 #48961
by vre
I have only one device that takes input up to 10khz so that covers me completely.
Time to create page: 0.071 seconds
