ppncconf error msg 5i25/7i77 combo
- Thank you received: 5283
20 Dec 2013 10:40 #41855
Replied by PCW on topic ppncconf error msg 5i25/7i77 combo
The 7I77 spindle control _must_ be on channel 5,
its the only individually settable enable.
(channels 0..4 are enabled or disabled all at once in hardware)
- PKM
- Thank you received: 3
20 Dec 2013 14:51 - 20 Dec 2013 14:51 #41859
by PKM
Replied by PKM on topic ppncconf error msg 5i25/7i77 combo
I understand that. But it looks like PnCConf doesn't use spinena pin and the spindle can not be tested from PnCConf.The 7I77 spindle control _must_ be on channel 5
Last edit: 20 Dec 2013 14:51 by PKM.
- Thank you received: 2164
20 Dec 2013 16:55 #41862
if you use a GPIO for enable and your spindle drive ignores the analog signal when the enable is false then you can use any channel.
It just wastes a pin.
Is there any other reason you must use channel 5?
Chris M
Replied by cmorley on topic ppncconf error msg 5i25/7i77 combo
7The 7I77 spindle control _must_ be on channel 5,
Chris M
21 Dec 2013 01:54 #41878
The main issues is that it makes a logical connection between spindle-on and axis enable that you may not want.
Also the enable OPTO is more flexible than the field I/O in that it works with any voltage and can source or sink as desired (VFDs often have ground-to-enable inputs).
Since theres no disadvantage in using channel 5 for spindle control and there are disadvantages to using analogena for this (analogenea controls axis 0..4), I cant see any reason to use anything but channel 5 for spindle control on the 7I77 as it was intended. (actually we would have preferred individual enables but ran out of uProc pins)
22 Dec 2013 13:30 #41922
I pushed a fix for the spindle enable problem to 2.5.3 and master.
Thanks for the report.
Chris M
Chris M
The following user(s) said Thank You: PKM
Time to create page: 0.156 seconds
