Closed loop spindle control
- DavidNicholls
01 Feb 2014 20:53 #43398
by DavidNicholls
Closed loop spindle control was created by DavidNicholls
I am looking for a way to drive the pncconf utility to configure my spindle for closed loop PID control. I can output a PWM signal to 'suggest' a speed to the controller and I can monitor the speed of the spindle via encoder feedback. Both of these signal paths use a MESA 7i43 interface card. I would just like to introduce a PID loop to manage the 'suggestions' made by the PWM signal and the 'observations' made by the encoder signals. i.e. if the spindle slows under load, I would like the PWM signal to 'suggest' that it try harder.
I can see the image on linuxcnc.org/docs/html/config/pncconf.ht...pindle_configuration along with the 'tip' that indicates that this option will not be visible unless "the proper option was selected on previous pages". Does anyone know what the "proper options" would be?
I know there are examples of configuring the HAL files manually but I find that avenue daunting. I like the ease of use provided by the PNCconf utility but I would also like my spindle to maintain speed under load. Can I have both?
I should mention that I'm running LinuxCNC version 2.5.3 (in case a later version has the functionality I'm after)
David Nicholls
David Nicholls
- Thank you received: 2167
02 Feb 2014 02:22 #43404
Replied by cmorley on topic Closed loop spindle control
Im sorry I believe I removed that option during a bug fix session and forgot to put it back in.
You will have to add it manually.
If you look at how pncconf connects PID to an axis it should help you figure out how to do it.
Chris M
Chris M
The following user(s) said Thank You: DavidNicholls
- DavidNicholls
02 Feb 2014 17:27 #43424
by DavidNicholls
Replied by DavidNicholls on topic Closed loop spindle control
Thanks for the response. I found a couple of places in the code and I have been able to see the screen that allows a PID loop control for the spindle. I needed to manually connect the pid.s.enable signal but the spindle now turns. It doesn't yet turn at the requested speed so I imagine I have some of the other settings wrong still but the PNCconf question is settled. If I come up with a complete solution to my problem I will post any PNCconf changes here but it might take me a little while.
In any case, thanks for the help.
- Thank you received: 5017
03 Feb 2014 20:59 #43490
Any PID will need to be tuned. I would suggest getting as close as you cam with P, I, D all zero and adjusting only FF0 at about the middle speed, then add in some I to make it correct everywhere, then perhaps a bit of P to make it work faster. (but you might well not need the P).
A spindle will typically mainly be controlled by FF0, which is largely identical to the original open-loop config.
Replied by andypugh on topic Closed loop spindle control
- DavidNicholls
04 Feb 2014 04:33 #43517
by DavidNicholls
Thanks for the suggestion. Although I do have servo motors on the axes I have used the Gecko drivers so I haven't had to manually tune them except for a couple of trim pots on the controllers.
- bottleworks
11 Mar 2014 08:12 #44646
by bottleworks
Any plans to reintroduce it? In time, I would like to do this to a second machine I'm working on. I'm not going to do it until I remove the variable speed belt drive and that will be a while. If this can be configured via a GUI, the better!
Replied by bottleworks on topic Closed loop spindle control
11 Mar 2014 12:59 #44650
probably not for the 2.5,x series, but for 2.6 yes.
Chris M
Chris M
