- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Mesa 5i20, Hostmot, can I trade stepgen for PWM?
- greenbuggy
05 Feb 2014 15:01 #43569
by greenbuggy
Mesa 5i20, Hostmot, can I trade stepgen for PWM? was created by greenbuggy
Machine is a Lagun FTV-3 mill, currently have x/y/z all hooked up and tuned and its been working great with me just manually switching on the spindle, but of course I can't leave well enough alone. So I got myself a VFD for it and I am trying to get it integrated so the computer can run it all.
Right now I've got a 5i20 FPGA running 2x 7i29 motor drives on P2, a 7i37TA IO board on P3 and nothing yet on P4.
I got myself a Spinx1 the other day and hooked it up on P4 tonight, and realized that if I run the default configuration firmware in PNCConf I'm out of PWM channels to run the spinx1 for my VFD speed. But, I've got leftover stepgen channels that I don't think I'll ever use and don't want to give up any of my extra GPIO.
Do I just need to manually change this in my HAL file? I wasn't sure if it was PNCConf being out of PWM channels or what but I'd like to have 4 PWM channels on P2 and a single PWM on P4 to run the Spinx1, and even if I deselect a PWM channel (since I don't yet have a rotab for the 4th motor controller) on P2 I couldn't select one on P4. Just looking for some insight before I go editing my Hal file again and screw something up.
- Thank you received: 2164
05 Feb 2014 16:03 #43570
Replied by cmorley on topic Mesa 5i20, Hostmot, can I trade stepgen for PWM?
What firmware are you using?
The firmware defines what and where components are.
If may be that you can deselect the steppers (turning them to GPIO)
and change your current GPIO into PWM.
Otherwise you would require custom firmware - which is possible - Peter often does requests.
Chris M
Chris M
- Thank you received: 5005
05 Feb 2014 21:42 #43584
You might be able to control a SpinX with a velocity-mode stepgen, though this would be a bit of a kludge.
SV12 firmware has only PWM and encoders, You could probably use that firmware with 5x PWM, put the 7i37 on P4, and use the single PWM on P3 for the SPINX. (Assuming that you don't actually need any stepgens).
Replied by andypugh on topic Mesa 5i20, Hostmot, can I trade stepgen for PWM?
No, the allocation of functions to pins is set by the firmware.Do I just need to manually change this in my HAL file?.
- Thank you received: 5283
06 Feb 2014 02:12 #43592
Replied by PCW on topic Mesa 5i20, Hostmot, can I trade stepgen for PWM?
If you are using a standard bitfile just give me the name of the bitfile and I can add a PWMgen to P4
- greenbuggy
06 Feb 2014 14:45 #43598
by greenbuggy
I already switched it around in hardware, now need to get all my GPIO pins corrected and rewrite my HAL since I no longer need to enable the buttons & contactors I was using to run my spindle forwards/reverse. I was using SVST8_4 with the servos turned down to 4. I couldn't figure out if there was something I was doing wrong or just a limit of PNCConf, just could not get the last PWM to go anywhere but IO pin 031 on P3.
Replied by greenbuggy on topic Mesa 5i20, Hostmot, can I trade stepgen for PWM?
06 Feb 2014 16:33 #43601
the firmware defines how the components are laid out.
The only option is to de-select components and then they can be used as GPIO.
This de-selection starts at the highest number component and works down.
The 5th PWM is defined to be on connector P3, pin 15
If you look at the output page on the help dialog, while on the mesa page, it should show you a run down of the firmware.
SO PNCconf was displaying it correctly. If you wish to have components in a different order/number custom firmware is required.
Chris M
Chris M
06 Feb 2014 20:50 #43604
Do you need any steppers at all?
Anyway, with SVST8_4 you have 8 PWM channels, so should be able to just shuffle daughter boards around to get access to an extra PWM.
- PnCConf Wizard
