mesa 5i25 and 7i76 stepgen and pwm
- absolut15
23 Apr 2014 00:59 #46225
by absolut15
mesa 5i25 and 7i76 stepgen and pwm was created by absolut15
Hello.
I use a mesa 5i25 and two 7i76. And on the onboard lpd port i have a breakout board with two
Relaise and a DAC 0-10 Volt.
But i can't set up the pncconf to use the stepgen and on the lpd port a pwm signal.
Is this posible?
Nice greedings
Florian
Is this posible?
Nice greedings
Florian
- Thank you received: 5283
23 Apr 2014 09:27 #46231
Replied by PCW on topic mesa 5i25 and 7i76 stepgen and pwm
Not sure that pncconf can do this, so I suspect you will have to add the LPT HAL code by hand
- Thank you received: 2164
23 Apr 2014 11:43 #46237
Replied by cmorley on topic mesa 5i25 and 7i76 stepgen and pwm
Peter is right, PNCconf doesn't support pwm or stepgens on the parallel port.
Use pncconf to build a basic mesa config then add the parport code after.
Chris M
Chris M
- absolut15
23 Apr 2014 12:16 #46238
by absolut15
Replied by absolut15 on topic mesa 5i25 and 7i76 stepgen and pwm
Thank you very much this helps me a lot. I have problems to add a vdf with an 0-10 Volt
Input. The mesa card is a lot smarter then me.
So i want to controller the Spindel in the lpd.
Perhaps on of you have an example code to add my Spindel on standart 376.... pin 16.
Thanks a lot and nice greedings Form austria.....
Florian
Florian
- Thank you received: 5005
23 Apr 2014 22:30 #46259
The 7i76 has a set of outputs specifially for driving a VFD. Why use a LPT board?
Replied by andypugh on topic mesa 5i25 and 7i76 stepgen and pwm
Input
- absolut15
24 Apr 2014 03:09 #46266
by absolut15
because i try a lot of things but i can get it to run with the analog spindel output from the mesa card....
24 Apr 2014 04:40 #46271
Do you mean that you can not get it to work with the spindle outputs?
Well, they do work, that is what they are for. Maybe it would be better to ask how to use them, and save yourself the trouble of using the LPT port (which will need you to add a base thread, amongst other things).
Time to create page: 0.267 seconds
