Brother tc-211 in pncConfig
- mblaszkiewicz
- Thank you received: 5
07 Jul 2014 01:17 #48466
by mblaszkiewicz
Brother tc-211 in pncConfig was created by mblaszkiewicz
Ok converting a Brother TC-211 from conversational to Linuxcnc. I ran the pncconfig and have 1 axis (z) hooked upto a 5i25-7i77 card. And got an error.
File "/usr/bin/pncconf", line 9479, in on_jogplus_pressed
self.update_axis_params()
File "/usr/bin/pncconf", line 9469, in update_axis_params
halrun.flush()
IOError: [Errno 32] Broken pipe
I am totally lost. New to linux and electronics. Just trying to update this machine.
You can see where I am in
www.linuxcnc.org/index.php/english/forum...ther-tc-211?start=80
any help would be appericated.
Also anyone in new england that might be interested in coming around to help, I may be able to afford some "Tech time"
halrun.flush()
- Thank you received: 2164
07 Jul 2014 14:50 #48473
Replied by cmorley on topic Brother tc-211 in pncConfig
What version of linuxcnc are you using?
- mblaszkiewicz
07 Jul 2014 16:21 #48480
by mblaszkiewicz
Replied by mblaszkiewicz on topic Brother tc-211 in pncConfig
2.5.4
08 Jul 2014 03:00 #48507
If you run pncconf from a terminal, then the true error will be displayed. broken pipes errors are usually HAL pin errors.
In this case I may just guess that you might not have the power to the 5i25/7i77 properly.
If the 7i77 is not powered some of the pins don't get created and then HAL/ Pncconf errors.
If you run from the terminal and paste the error message here I could confirm.
Chris M
Chris M
Time to create page: 0.058 seconds
