- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Z axis servo "giving up" on position...help?
- greenbuggy
25 Jul 2014 10:32 #49114
by greenbuggy
Z axis servo "giving up" on position...help? was created by greenbuggy
Any help is appreciated!
I have a Lagun 3 axis CNC mill that I've retrofitted with a Mesa 5i25 and 2x 7i29 motor controllers. Also a 7i37 and SPINX1 but I don't think those are related to this problem.
About a year ago I did my PID tuning and haven't had any real problems with it. Right now my values on Z is P 7000 I 12 D 24 deadband .0001 no feed forward. Max output 95 output scale 100 encoder scale 20000. Today while drilling a few holes it would seem to give up on getting to the commanded position, to the point where a 3/8" deep hole was only drilled about 1/8" before the drill retracted and moved on to the next operation.
Now what seems weird about this axis compared to others is that with no obstruction it will go to any commanded position. However, if I pull the belt guard and manually move the pulleys it will resist my movement, but if I push it past about 5* rotation the motor will stay wherever its pushed to, it will not attempt to move back to the position it was initially at. On the AXIS interface the movement is registered - sorta. It does register movement but only a few thousandths which is why I suspect that its not trying to move back to the original position, it certainly isn't registering a movement of 1/8" or more. On my X/Y axis if I rotate against the servo it will spring back, almost violently to the position it started at and will register all movement past the position it was at until released and it goes back to that position.
I know that my encoder is functioning because it does accurately move to commanded positions, and shaft movement does register on the 7i29's encoder LED's.
Help!
Help!
- Thank you received: 5283
25 Jul 2014 11:29 #49115
Replied by PCW on topic Z axis servo "giving up" on position...help?
Sounds like an encoder noise issue
Are you using a differential output encoder?
if so, is the 7I29 jumpered for differential inputs?
Is the encoder filter bit turned on? (it should be)
Is the Z axis encoder 5V OK at the encoder?
If you are running master or some pre-release version of 2.6 you can
easily change the encoder digital filter time constant
- Thank you received: 5005
26 Jul 2014 00:14 #49134
Is there any chance that this is actually a pulley slipping on the shaft?
Replied by andypugh on topic Z axis servo "giving up" on position...help?
- greenbuggy
26 Jul 2014 04:19 #49148
by greenbuggy
It was. I feel like a big idiot, next time I'll use loctite. I checked for slippage on the ballscrew shaft but not the servo shaft, and after tearing the caps off the servo to double check all connections and wires I realized my error. Must be some of the chattery work I've been doing lately - I've never had a compression style lock pulley ever slip on a shaft before. I'm tempted to get one that has a keyway in the inside of the pulley swage to make *extra* sure it never happens again.
Replied by greenbuggy on topic Z axis servo "giving up" on position...help?
26 Jul 2014 05:09 #49149
It's not the first time it has happened. It is very hard to spot, which is why I mentioned it.
Taper couplings should be good enough to shear the actual shaft if tightened to the specified torque, so try cleaning the shaft and coupling and re-assembling to the manufacturer torque.
You will hate "you-from-the-past' if you Loctite it then need to dismantle it in the future.
- PnCConf Wizard
Time to create page: 0.148 seconds
