Migrating buildlog laser from pport to 5i25
03 Sep 2014 07:02 #50659
by sliptonic
Migrating buildlog laser from pport to 5i25 was created by sliptonic
I have a retrofit 40W laser that uses
Bart Dring's buildlog breakout board
for controlling the laser and step/direction. I've been using this with software stepping on a parallel port for a while but I want to move it to a 5i25 without a daughter board. The pin assignment on the board roughly matches the prob_rfx2 configuration but not exactly. From the manual:
in # Function (goes to)
1 Output 1 (Relay Driver 1)
2 X Step
3 X Dir
4 Y Step
5 Y Dir
6 Z Step
7 Z Dir
8 Output 8 (Relay Driver 2)
9
10 X Limit Switch Input (J3-6)
11 Y Limit Switch Input (J3-8)
12 Z Limit Switch Input (J3-1)
13 Input 13 (J3-2)
14 PWM 14
15 PWM 15
16 Motor Enable Output
17 Laser On
18-25 Ground
Will I need a custom bit file for this?
Also, just experimenting, I tried to get pncconf to see the other config XML files downloaded from mesa's site. Based on posts in this forum, I copied those to /lib/firmware/hm2/5i25/ and restarted pncconf but they were not seen. Has the correct location for these changed?
2 X Step
3 X Dir
4 Y Step
5 Y Dir
6 Z Step
7 Z Dir
9
13 Input 13 (J3-2)
14 PWM 14
15 PWM 15
17 Laser On
18-25 Ground
03 Sep 2014 07:43 #50661
Replied by cmorley on topic Migrating buildlog laser from pport to 5i25
no.
check the permissions of the folder and file.
Chris M
Chris M
03 Sep 2014 10:45 #50663
Replied by PCW on topic Migrating buildlog laser from pport to 5i25
The only thing thats looks incompatible with probrfx2 is the two PWMs
Are these 2 independent PWM outputs?
03 Sep 2014 19:28 #50680
by sliptonic
Replied by sliptonic on topic Migrating buildlog laser from pport to 5i25
@cmorley: All the files are owned by root with no one else having permission. What should it be?
@PCW: It's looking for a PWM source to control the laser power. It's select-able with a jumper for either pin 14 or 15.
I guess I'm not clear on how to use pncconf to set this up. The I/O connector 3 tab has me confused and when I try to launch the test panel, it appears for a second then disappears with this error:
File "/usr/bin/pncconf", line 5579, in on_mesapanel_clicked
a.kill()
AttributeError: 'file' object has no attribute 'kill'
03 Sep 2014 21:10 #50689
Looks like just changing one pin definition (removing the PWM direction on DB25 pin16)
will make the probrfx2 config fully compatible
03 Sep 2014 22:47 - 03 Sep 2014 22:49 #50692
by sliptonic
I'm sorry. I don't understand how to do that. pncconf is making more sense, but I still don't understand the mapping of the 'num' columns to the I/O and pins from the .pin file.
Last edit: 03 Sep 2014 22:49 by sliptonic. Reason: image attachment
03 Sep 2014 23:04 #50694
by cncbasher
Replied by cncbasher on topic Migrating buildlog laser from pport to 5i25
yea dont use the test panel in pncconf , and you be ok
make your configuration as near as you can then i'd edit it by hand
or shout if it's a problem
Dave
Dave
03 Sep 2014 23:37 #50697
To be able to use pin DB25 pin 16 as a output bit and use the PWM pin on DB25 pin 14,
a special modified bitfile would be needed (since the PWM part of the driver will claim pin 16 as a PWM direction pin)
04 Sep 2014 04:59 #50713
by sliptonic
O.k. Is that within the scope of a strong-back/weak-minded (but willing) amateur or is it something I can get from you?
04 Sep 2014 05:16 #50718
freeby.mesanet.com/dring.zip
Has a simplified prob_rxf2 config with the PWM direction pin removed so should work with your BOB
The following user(s) said Thank You: sliptonic
Time to create page: 0.526 seconds
