Newb and 5i20 DOut don't mix
- Niko
- Thank you received: 5
12 Sep 2014 15:27 - 12 Sep 2014 15:33 #51109
by Niko
Replied by Niko on topic Newb and 5i20 DOut don't mix
OK
Now I am running Debian but it doesn't recognise the 5i20 in the pci slot . Any ideas?
Are there any dirvers othe than the ones found in Synaptic ?
Should the BIOS be configured in any way other than standart ?
mesaflash --list gives segmentation fault
Last edit: 12 Sep 2014 15:33 by Niko.
- Niko
12 Sep 2014 16:49 #51111
by Niko
Update,
linuxcnc couldn't find the card . probably a bad contact on the MB since contact cleaner helped . Other than that 2.6.1 works .
- Niko
12 Sep 2014 19:47 #51113
by Niko
I measured the voltage on the connector of 7i37 . 4.6v is the voltage when the ouputs are off, when LinuxCNC gives the enable signal the voltage drops to 4.4V . The board requires the pin to be driven to gnd . How do you set up the pullups ?
- Thank you received: 4966
12 Sep 2014 19:58 #51114
Exactly how did you connect the meter?
Is the -Ve terminal of the output connected to GND?
The 7i37 is an _isolated_ output device. That means that the ouputs are "floating" switches with two terminals each
Replied by andypugh on topic Newb and 5i20 DOut don't mix
- Niko
12 Sep 2014 20:09 #51115
by Niko
I traced pin 47 on the connector to pin 3 on th IC that is closest to the green connector . From there to gnd on c17 capacitor . Measured the same on the pin that actually worked the other day .
12 Sep 2014 22:05 #51123
I meant in _your_ wiring.
- Niko
15 Sep 2014 14:18 #51181
by Niko
That was measured directly on the ribbon cable . Today I changed over to P4 on the mesa and half of the outputs work . 0 2 4 and 6 work . Are there any additional steps after Pncconf ?
- Thank you received: 5204
15 Sep 2014 20:54 #51197
Replied by PCW on topic Newb and 5i20 DOut don't mix
Sounds like either you have the stepgens enabled
(you need a num_stepgens=0 token in your config string)
or you have a bad cable crimp on one end or the other
or possibly you have the wrong I/O bits
P3 outputs for 7I37 are GPIO 40 through 47
P4 outputs for 7I37 are GPIO 64 through 71
all 8 GPIO (40 through 47 or 64 through 72 depending on connector) must have
their is_output attribute set, and probably the invert_output attribute set as well
since the 7I37 signals at the FPGA pin level are active low
The following user(s) said Thank You: Niko
- Niko
16 Sep 2014 13:30 - 16 Sep 2014 13:31 #51228
by Niko
OK
problem solved. It was a mix of cable issues power issues and a few .hal mistakes . 1 3 5 7 on P4 didn't work because they wer Y enable and I am in lathe geometry . Recrimped the cable which was also problematic as it turns out and power now comes from the 5V output on the mesa card .
Thank you for your time !
Last edit: 16 Sep 2014 13:31 by Niko.
- wp6529
16 Sep 2014 23:40 #51240
by wp6529
Replied by wp6529 on topic Newb and 5i20 DOut don't mix
Testing if I can reply. I can't seem to get a new topic / question to post.
Time to create page: 0.087 seconds
