5i25 + 7i78 + g540
- Imrtoy
12 Sep 2014 22:53 #51124
by Imrtoy
5i25 + 7i78 + g540 was created by Imrtoy
Can you have parallel port on motherboard board control the g540 with the 5i25 + 7i78 controlling the THC with the thcad PCB in the same ini file?
- cncbasher
- Thank you received: 288
12 Sep 2014 23:26 #51127
by cncbasher
Replied by cncbasher on topic 5i25 + 7i78 + g540
the 5i25 has 2 ports, why use a lpt port when the 5i25 is far better to use
The following user(s) said Thank You: Imrtoy
- Imrtoy
13 Sep 2014 02:17 #51130
by Imrtoy
Replied by Imrtoy on topic 5i25 + 7i78 + g540
Very easy solution. Thank you.
Time to create page: 0.226 seconds
