- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Lathe Spindle Control Help Needed in PNCCONF
- Mr. Technical
17 Oct 2014 03:53 #52149
by Mr. Technical
Replied by Mr. Technical on topic Lathe Spindle Control Help Needed in PNCCONF
Just tried it. Still getting an error message:
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/scale.ko': -1 Unknown symbol in module
PUMAplay.hal:15: exit value: 1
PUMAplay.hal:15: insmod failed, returned -1
See the output of 'dmesg' for more information.
28151
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Mr. Technical
28151
Mr. Technical
- Thank you received: 4968
17 Oct 2014 06:46 #52150
Sorry, lose the space on line 15.
Replied by andypugh on topic Lathe Spindle Control Help Needed in PNCCONF
The following user(s) said Thank You: Mr. Technical
- Mr. Technical
17 Oct 2014 07:18 #52152
by Mr. Technical
Thanks, I'll try that tomorrow when I'm back in front of the lathe. I really appreciate all of the help.
Mr. Technical
Mr. Technical
- Mr. Technical
18 Oct 2014 02:24 #52163
by Mr. Technical
Thanks Andy, that did it!
After a couple of tweaks to the math of the scales, it's working great. I manually put it in the gear that I want, then when I set a spindle speed, it hits that number just like it should.
Only problem is that the spindle arrive signal doesn't seem to be working any more. I'd like to be able to use that in the future. Is there a simple way to fix that?
Mr. Technical
Mr. Technical
18 Oct 2014 02:40 #52164
Do you mean spindle-at-speed?
That looked a bit over-complicated before. I think all you need to use is a "near" component to compare motion.spindle-speed-cmd-rps with the encoder velocity. (no need for scaling, just use rps throughout)
- Mr. Technical
18 Oct 2014 03:41 #52165
by Mr. Technical
andypugh wrote:
Yes, sorry about that. The way that it was originally written is directly from the PNCCONF program. I would like to make the file you provided match what PNCCONF creates as closely as possible. I actually plan to move the loadrt mux8 and addf mux8.0 servo-thread lines to the custom post gui file when I get the chance.
The reason is that I still have some pins to set up, and PNCCONF makes it a lot easier to do that than hand editing the HAL (for me anyway). As you know, every time I run through PNCCONF it kills any edits made to the HAL in the meantime.
I know that I'll probably always have to make some hand edits to retain the scaling that you wrote, and that's worth it, but first I have more pins to map.
The weird thing about the spindle-at-speed pin is that those sections look the same from my HAL file to yours. The only thing that changed that looks like it would have a direct bearing is the "net spindle-vel-cmd => hm2_5i25.0.7i77.0.1.analogout5" line (from my HAL) vs. the "net scaled-spindle-cmd scale.gear.out => hm2_5i25.0.7i77.0.1.analogout5" line (from your HAL).
I'll try to track down the way to use the same conventions that PNCCONF used to save me from excessive future editing. Thanks again!
Mr. Technical
Mr. Technical
- Thank you received: 2160
18 Oct 2014 11:10 - 18 Oct 2014 12:54 #52166
That's how pncconf sets it up. the scaling and filtering is for the RPM display.
I wonder - is your encoder on the 'motor' side of the gearing or the 'spindle' side of the gearing?
if it's on the motor side then you must scale the encoder for each gear change too.
that would also mean the index wouldn't work properly .. so unlikely you set it up this way...
Chris M
Replied by cmorley on topic Lathe Spindle Control Help Needed in PNCCONF
Chris M
Last edit: 18 Oct 2014 12:54 by cmorley. Reason: re-thought
- Mr. Technical
19 Oct 2014 10:01 #52182
by Mr. Technical
Hi Chris,
The encoder is on the spindle side of things which is why I was surprised that the spindle-at-speed notification was affected by the edits to the drive signal scaling. The way I thought it worked was that it would compare the signal from the encoder to the S value I entered and see if it was within the tolerance. Apparently, it's not that simple.
Mr. Technical
P.S. Please excuse the general terms, since I'm not in front of the lathe at the moment, and can't recall the signal
and pin names.
Mr. Technical
and pin names.
19 Oct 2014 10:17 #52183
Thats pretty close.
It compares the spindle command in RPS to spindle velocity feedback (encoder) RPS.
I am surprised it doesn't work. Please post your latest config files when you get a chance.
Chris M
Chris M
29 Oct 2014 14:52 #52520
Andy is there a good reason those pins are params? could we change them?
this is going to come up again each time there is multiple geared spindles.
In fact someone else just asked me the same sort of question but it was from the 5i20.
Chris M
Ooops! I just realised that this is all my fault....
Looking at the source-code, scalemax, minlim and maxlim are _parameters_.
This is why they don't show up in the pin list, and why you can't make them part of a net.
Chris M
- PnCConf Wizard
Time to create page: 0.071 seconds
