5i25/7i76 pncconfig for gmoccapy
- b2unit
10 Oct 2014 07:43 #51934
by b2unit
5i25/7i76 pncconfig for gmoccapy was created by b2unit
could you help me out?
I thought it just copy and paste level..but it's quite complicate than I think.
it's quite different variables and structure between ini&hal setups for axis and gmoccapy..
here's ini&hal file for my axis..could anyone translate for gmoccapy? or instruction for it?
my condition is linuxcnc2.7 pre~0, gmoccapy 1.2.2, debian weezy and d525mw, 5i25, 7i76.
thanks,
Byoungil Choi
thanks,
Byoungil Choi
- newbynobi
- Thank you received: 415
10 Oct 2014 14:12 #51937
by newbynobi
Replied by newbynobi on topic 5i25/7i76 pncconfig for gmoccapy
Hallo Byoungil Choi,
the configs are not as different as you think.
I took a look at your INI and HAL files.
Change in your INI File:
DISPLAY = axis
to
DISPLAY = axis
As you did not supply your postgui hal file, I am not able to see if there will be made some connections to the pyVCP panel and if all the halui pin are needed.
So for the first test I recommend to comment in the INI File the following lines:
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
to
# HALFILE = custom.hal
# POSTGUI_HALFILE = postgui_call_list.hal
# SHUTDOWN = shutdown.hal
so they will not be used.
Then go to your hal File and change
net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
to
# loadusr -W hal_manualtoolchange
# net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
# net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
# net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
# net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
try to start your config and report.
There are many usefull informations in the WIKI
and as you use master, the information is also in the folder ~/linuxcnc-dev/docs if you did ./configure --enable-build-documentation
Norbert
DISPLAY = axis
to
DISPLAY = axis
to
to
Norbert
- akb1212
- Thank you received: 12
12 Oct 2014 04:41 #51971
by akb1212
I do think you mean to say change to:
DISPLAY = gmoccapy
Replied by akb1212 on topic 5i25/7i76 pncconfig for gmoccapy
DISPLAY = axis
to
DISPLAY = axis
DISPLAY = gmoccapy
- newbynobi
12 Oct 2014 16:57 - 13 Oct 2014 13:45 #51976
by newbynobi
of course DISPLAY = gmoccapy is correct.
Shame on me and copy and paste
Norbert
Norbert
Last edit: 13 Oct 2014 13:45 by newbynobi.
- b2unit
13 Oct 2014 09:59 #51992
by b2unit
Replied by b2unit on topic 5i25/7i76 pncconfig for gmoccapy
today morining I applied the setting which is edited by Mr. Nobert's advice.
it's working!
I just checked
emergency stop connected to pins via hal.
x, y, z movements & change velocity
spindle on/off & change rpm & direction,
physical limit switches conneted to pins via hal.
till now everything is fine. thanks!
I will test more and then ask something more details for setting. thanks again.
it's working!
I just checked
- newbynobi
13 Oct 2014 13:52 #51996
by newbynobi
glad that it is working.
If you want to use the manual toolchange option, please do not forget to place the following lines in your postgui_hal file.
# Use gmoccapy toolchanger..
net tool-prep-number gmoccapy.toolchange-number <= iocontrol.0.tool-prep-number
Norbert
Norbert
- b2unit
17 Oct 2014 06:57 #52151
by b2unit
now i'm working on spindle rpm meter & spindle at speed display on gmoccapy default UI.
but I cound not find name of halpin for hal connetion. could you let me know?
sorry for basic question..i'm a newbie for programing.
thanks,
Byoungil Choi
thanks,
Byoungil Choi
- newbynobi
18 Oct 2014 21:02 #52170
by newbynobi
Hallo, did you read the Wiki?
All hal pin are mentioned and displayed there.
To help more we do need more detailed information.
Norbert
Norbert
The following user(s) said Thank You: b2unit
- b2unit
21 Oct 2014 10:07 #52229
by b2unit
i was too hurry.
thanks!
thanks!
- b2unit
04 Nov 2014 20:08 #52760
by b2unit
I set auto tool measurement by following gmoccapy wiki.
right now I didn't make any change in source codes just copy and paste the code for auto tool measurement.
I loaded gcode program,
homed x, y, z axis,
moved to workpiece and set x=0, y=0,
machine started
but after z axis homed and I got "cannot use g53 incremental" alert window.
where I have to change? let me know..
thanks,
Byoungil Choi
homed x, y, z axis,
machine started
thanks,
Byoungil Choi
Time to create page: 0.258 seconds
