5i25/7i76 pncconfig for gmoccapy
05 Nov 2014 00:18 #52773 by newbynobi
Replied by newbynobi on topic 5i25/7i76 pncconfig for gmoccapy
Shure you get the error, because:
N0030 G28 G91 Z0.0
says switch to incremental mode and
N0040 T00 M6
you call a tool change (better a remove tool, because toolno. = 0)
In your change.ngc you do use a G53 (IMHO; haven't seen the file)
That is not allowed, bevor using a G53 you need to change to G90.
Norbert
P.S. Without testing!
06 Nov 2014 12:39 #52863 by b2unit
Replied by b2unit on topic 5i25/7i76 pncconfig for gmoccapy
I changed G91 to G90 in N0030
I could remove the alert window which displaying "cannot use g53 incremental".
but
I got another problematic situation..
1.
I load program, move x,y axis for workpiece, input Block height, set x=0, y=0
(I set auto tool measurement in setting menu)
2.
program starts,
z axis moves downward to some position without moving x, y axis and then
z axis moves upward to z home position without moving x, y axis.
x, y axis move to x=10, y=10 postion(tool change position)
pops up manual tool change window and click OK.
3.
alert window which displaying nothing pops up
program stopped. e-stop button doesn't work, gmocappy UI freeze.
where I have to check for solving this situation? let me know..
My major purpose to using gmocappy is for auto tool measurement..
thanks,
Byoungil Choi
13 Nov 2014 11:18 - 13 Nov 2014 11:19 #53053 by b2unit
I removed old ini, hal etc. and then started from ground 0.
it's working! auto tool function is very convenient. :laugh:
Last edit: 13 Nov 2014 11:19 by b2unit.
14 Nov 2014 05:02 #53070 by newbynobi
Glad you got it working.
Wellcome in the beautifull gmoccapy world!
Norbert
Time to create page: 0.300 seconds
