hostmot2 FW download
11 Oct 2014 19:37 #51962 by mario_rl
hostmot2 FW download was created by mario_rl
Hi there,
I created a very simple test config for my 5i23, using the wizard... but in the 5i23 manual does't give
much information on how to write the hostmot2 fw to the board, just tells it must be done. I've seen
the support package and there's some files for DOS and WIN, and one for Linux... Is there any topic
already explainig how to do the FW download from linux?
Thanks, Mario.
11 Oct 2014 19:57 - 11 Oct 2014 21:00 #51963 by cncbasher
Replied by cncbasher on topic hostmot2 FW download
the configuration is loaded on startup by LCNC , you dont need to directly load the firmware
so long as the bit file resides in lib/firmware/hm2/5i23/ *.bit *.xml
( you will need to cp * bit & *xml files here using sudo , if not currently loaded )
pncconf makes your startup configuration files located in ~/home/linuxcnc/configs/<machinename>
at the top of your hal file you will have loadrt hm2_pci "configuration string incl bit file name "
Last edit: 11 Oct 2014 21:00 by cncbasher.
The following user(s) said Thank You: mario_rl
11 Oct 2014 20:40 #51964 by PCW
Replied by PCW on topic hostmot2 FW download
You may be mixing up card types
The 5I23 needs to have its firmware file loaded at startup
This is done in the HAL file in the
loadrt hm2_pci [config="str[,str...]"]
line
This line should be created by pncconf
Time to create page: 0.099 seconds
