- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- axis drops...is rthere a guide to isolate the bug?
- mario_rl
22 Oct 2014 00:58 #52250
by mario_rl
axis drops...is rthere a guide to isolate the bug? was created by mario_rl
Hi there, I tried to lauch axis but after some errors I solved using google, I crashed on this one. May be a modbus problem?. the axis and classicladder shows up, but inmeditely drop. Thanks in advance.
- mario_rl
22 Oct 2014 00:59 #52251
by mario_rl
Replied by mario_rl on topic axis drops...is rthere a guide to isolate the bug?
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.1
Machine configuration directory is '/home/mario/linuxcnc/configs/oerlikon1'
Machine configuration file is 'oerlikon1.ini'
INIFILE=/home/mario/linuxcnc/configs/oerlikon1/oerlikon1.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting DISPLAY program: axis
Running HAL shutdown script
Killing task linuxcncsvr, PID=4407
Killing task milltask, PID=4461
INFO CLASSICLADDER---I/O modbus master closed!
INFO CLASSICLADDER---I/O modbus master Data bits 8 Stop bits 1 Parity 0
INFO CLASSICLADDER---I/O modbus master (Serial) init ok !
INFO CLASSICLADDER- Modbus I/O module to send: Lgt=8 <- Slave address-1 Function code-2 Data-0 0 0 1 B9 CA
ERROR CLASSICLADDER- MODBUS NO RESPONSE (Errs=1/1) !?
INFO CLASSICLADDER- Modbus I/O module received: Lgt=0 ->
ERROR CLASSICLADDER- MODBUS-LOW LEVEL ERROR IN RESPONSE!!!
ERROR CLASSICLADDER- MODBUS NO RESPONSE (Errs=2/2) !?
ERROR CLASSICLADDER- MODBUS NO RESPONSE (Errs=3/3) !?
INFO CLASSICLADDER- Modbus I/O module to send: Lgt=10 <- Slave address-2 Function code-F Data-0 0 0 5 1 0 2F 43
ERROR CLASSICLADDER- MODBUS NO RESPONSE (Errs=4/4) !?
ERROR CLASSICLADDER- Error intializing classicladder user module.
Debug file information:
python: swrast/s_renderbuffer.c:588: map_attachment: Assertion `srb->Map' failed.
/usr/bin/linuxcnc: lĂnea 766: 4462 Abortado $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
4407
PID TTY STAT TIME COMMAND
4461
Stopping realtime threads
Unloading hal components
ULAPI: WARNING: module 'HAL_classicladder' failed to delete shmem 03
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-3linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-3linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000005fe74000 (usable)
[ 0.000000] BIOS-e820: 000000005fe74000 - 000000005fe76000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000005fe76000 - 000000005fe97000 (ACPI data)
[ 0.000000] BIOS-e820: 000000005fe97000 - 000000005ff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Computer Corporation Dimension 2400 /0F5949, BIOS A05 12/02/2003
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x5fe74 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 base 040000000 mask FE0000000 write-back
[ 0.000000] 2 base 05FF00000 mask FFFF00000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3642e000 - 3720f000
[ 0.000000] ACPI: RSDP 000feb80 00014 (v00 DELL )
[ 0.000000] ACPI: RSDT 000fd22a 00034 (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: FACP 000fd25e 00074 (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: DSDT fffcc0f1 02404 (v01 DELL dt_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 5fe74000 00040
[ 0.000000] ACPI: SSDT fffce4f5 000A7 (v01 DELL st_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: APIC 000fd2d2 0006C (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd33e 00028 (v01 DELL 2400 00000007 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 646MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0005fe74
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0005fe74
[ 0.000000] On node 0 totalpages: 392708
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f582e200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3952 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 1293 pages used for memmap
[ 0.000000] HighMem zone: 164201 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 5ff00000 (gap: 5ff00000:9ed00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77b0000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 389639
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=fdb1b163-d2e2-4304-a04e-247e276f5fd2 ro initrd=/install/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3142432 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0005fe74)
[ 0.000000] Memory: 1534284k/1571280k available (3495k kernel code, 36548k reserved, 1237k data, 416k init, 661976k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d0a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d0a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5408000 soft=f540a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2791.046 MHz processor.
[ 0.008004] Calibrating delay loop (skipped), value calculated using timer frequency.. 5582.09 BogoMIPS (lpj=11164184)
[ 0.008011] pid_max: default: 32768 minimum: 301
[ 0.008091] Security Framework initialized
[ 0.008103] AppArmor: AppArmor disabled by boot time parameter
[ 0.008135] Mount-cache hash table entries: 512
[ 0.008473] Initializing cgroup subsys cpuacct
[ 0.008479] Initializing cgroup subsys memory
[ 0.008495] Initializing cgroup subsys devices
[ 0.008499] Initializing cgroup subsys freezer
[ 0.008503] Initializing cgroup subsys net_cls
[ 0.008506] Initializing cgroup subsys blkio
[ 0.008518] Initializing cgroup subsys perf_event
[ 0.008570] CPU0: Hyper-Threading is disabled
[ 0.008575] mce: CPU supports 4 MCE banks
[ 0.008588] CPU0: Thermal monitoring enabled (TM1)
[ 0.008682] SMP alternatives: switching to UP code
[ 0.015415] ACPI: Core revision 20120320
[ 0.040040] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.040403] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.080100] CPU0: Intel(R) Pentium(R) 4 CPU 2.80GHz stepping 09
[ 0.084004] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.084004] ... version: 0
[ 0.084004] ... bit width: 40
[ 0.084004] ... generic registers: 18
[ 0.084004] ... value mask: 000000ffffffffff
[ 0.084004] ... max period: 0000007fffffffff
[ 0.084004] ... fixed-purpose events: 0
[ 0.084004] ... event mask: 000000000003ffff
[ 0.092048] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.092109] Brought up 1 CPUs
[ 0.092114] Total of 1 processors activated (5582.09 BogoMIPS).
[ 0.092757] devtmpfs: initialized
[ 0.093155] PM: Registering ACPI NVS region [mem 0x5fe74000-0x5fe75fff] (8192 bytes)
[ 0.093331] dummy:
[ 0.093422] NET: Registered protocol family 16
[ 0.093619] ACPI: bus type pci registered
[ 0.093958] PCI: PCI BIOS revision 2.10 entry at 0xfbbbf, last bus=1
[ 0.093962] PCI: Using configuration type 1 for base access
[ 0.094981] bio: create slab <bio-0> at 0
[ 0.095138] ACPI: Added _OSI(Module Device)
[ 0.095143] ACPI: Added _OSI(Processor Device)
[ 0.095147] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.095151] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.096130] ACPI: EC: Look up EC in DSDT
[ 0.114007] ACPI: Interpreter enabled
[ 0.114029] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.114084] ACPI: Using IOAPIC for interrupt routing
[ 0.148173] ACPI: No dock devices found.
[ 0.148188] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.149755] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.152824] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.152829] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.152835] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.152839] pci_root PNP0A03:00: host bridge window [mem 0x80860000-0xfebfffff] (ignored)
[ 0.152844] PCI: root bus 00: using default resources
[ 0.152911] PCI host bridge to bus 0000:00
[ 0.152916] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.152921] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.152945] pci 0000:00:00.0: [8086:2560] type 00 class 0x060000
[ 0.152959] pci 0000:00:00.0: reg 10: [mem 0xf0000000-0xf7ffffff pref]
[ 0.153035] pci 0000:00:02.0: [8086:2562] type 00 class 0x030000
[ 0.153055] pci 0000:00:02.0: reg 10: [mem 0xe8000000-0xefffffff pref]
[ 0.153067] pci 0000:00:02.0: reg 14: [mem 0xfeb80000-0xfebfffff]
[ 0.153177] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300
[ 0.153231] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.153277] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300
[ 0.153332] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.153375] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300
[ 0.153429] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.153487] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320
[ 0.153514] pci 0000:00:1d.7: reg 10: [mem 0xffa80800-0xffa80bff]
[ 0.153610] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.153637] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[ 0.153692] pci 0000:00:1f.0: [8086:24c0] type 00 class 0x060100
[ 0.153698] * The chipset may have PM-Timer Bug. Due to workarounds for a bug,
[ 0.153700] * this clock source is slow. If you are sure your timer does not have
[ 0.153701] * this bug, please use "acpi_pm_good" to disable the workaround
[ 0.153797] pci 0000:00:1f.1: [8086:24cb] type 00 class 0x01018a
[ 0.153816] pci 0000:00:1f.1: reg 10: [io 0x01f0-0x01f7]
[ 0.153828] pci 0000:00:1f.1: reg 14: [io 0x03f4-0x03f7]
[ 0.153841] pci 0000:00:1f.1: reg 18: [io 0x0170-0x0177]
[ 0.153854] pci 0000:00:1f.1: reg 1c: [io 0x0374-0x0377]
[ 0.153867] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.153880] pci 0000:00:1f.1: reg 24: [mem 0xfeb7fc00-0xfeb7ffff]
[ 0.153919] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500
[ 0.153973] pci 0000:00:1f.3: reg 20: [io 0xeda0-0xedbf]
[ 0.154021] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100
[ 0.154041] pci 0000:00:1f.5: reg 10: [io 0xee00-0xeeff]
[ 0.154054] pci 0000:00:1f.5: reg 14: [io 0xedc0-0xedff]
[ 0.154066] pci 0000:00:1f.5: reg 18: [mem 0xfeb7fa00-0xfeb7fbff]
[ 0.154078] pci 0000:00:1f.5: reg 1c: [mem 0xfeb7f900-0xfeb7f9ff]
[ 0.154126] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.154183] pci 0000:01:05.0: [10b5:9054] type 00 class 0x068000
[ 0.154210] pci 0000:01:05.0: reg 10: [mem 0xfe9edf00-0xfe9edfff]
[ 0.154223] pci 0000:01:05.0: reg 14: [io 0xdd00-0xddff]
[ 0.154235] pci 0000:01:05.0: reg 18: [io 0xde00-0xdeff]
[ 0.154248] pci 0000:01:05.0: reg 1c: [mem 0xfe9f0000-0xfe9fffff]
[ 0.154278] pci 0000:01:05.0: reg 30: [mem 0xfea00000-0xfea0ffff pref]
[ 0.154339] pci 0000:01:09.0: [14e4:4401] type 00 class 0x020000
[ 0.154360] pci 0000:01:09.0: reg 10: [mem 0xfe9ee000-0xfe9effff]
[ 0.154414] pci 0000:01:09.0: reg 30: [mem 0xfea00000-0xfea03fff pref]
[ 0.154437] pci 0000:01:09.0: supports D1 D2
[ 0.154441] pci 0000:01:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.154481] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.154488] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.154495] pci 0000:00:1e.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.154502] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.154507] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.154519] pci_bus 0000:00: on NUMA node 0
[ 0.154526] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.155116] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.155670] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.309286] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.309653] ACPI: PCI Interrupt Link [LNKB] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.310020] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.310383] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.310743] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.311104] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.311465] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.311831] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.312243] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.312257] vgaarb: loaded
[ 0.312260] vgaarb: bridge control possible 0000:00:02.0
[ 0.312311] PCI: Using ACPI for IRQ routing
[ 0.312317] PCI: pci_cache_line_size set to 64 bytes
[ 0.312391] reserve RAM buffer: 000000005fe74000 - 000000005fffffff
[ 0.312731] pnp: PnP ACPI init
[ 0.312751] ACPI: bus type pnp registered
[ 0.316346] pnp 00:00: [mem 0x00000000-0x0009ffff]
[ 0.316351] pnp 00:00: [mem 0x00100000-0x00ffffff]
[ 0.316355] pnp 00:00: [mem 0x01000000-0x5fe73fff]
[ 0.316360] pnp 00:00: [mem 0x000c0000-0x000fffff]
[ 0.316364] pnp 00:00: [mem 0xfec00000-0xfec0ffff]
[ 0.316369] pnp 00:00: [mem 0xfee00000-0xfee0ffff]
[ 0.316373] pnp 00:00: [mem 0xfecf0000-0xfecf0fff]
[ 0.316377] pnp 00:00: [mem 0xffb00000-0xffbfffff]
[ 0.316382] pnp 00:00: [mem 0xffc00000-0xffffffff]
[ 0.316451] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.316457] system 00:00: [mem 0x00100000-0x00ffffff] could not be reserved
[ 0.316463] system 00:00: [mem 0x01000000-0x5fe73fff] could not be reserved
[ 0.316469] system 00:00: [mem 0x000c0000-0x000fffff] could not be reserved
[ 0.316475] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[ 0.316480] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.316485] system 00:00: [mem 0xfecf0000-0xfecf0fff] has been reserved
[ 0.316491] system 00:00: [mem 0xffb00000-0xffbfffff] has been reserved
[ 0.316496] system 00:00: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.316502] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.318045] pnp 00:01: [bus 00-ff]
[ 0.318050] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.318056] pnp 00:01: [io 0x0000-0x0cf7 window]
[ 0.318059] pnp 00:01: [io 0x0d00-0xffff window]
[ 0.318063] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.318067] pnp 00:01: [mem 0x80860000-0xfebfffff window]
[ 0.318126] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.320508] pnp 00:02: [io 0x0080-0x009f]
[ 0.320513] pnp 00:02: [io 0x0000-0x001f]
[ 0.320517] pnp 00:02: [io 0x00c0-0x00df]
[ 0.320522] pnp 00:02: [dma 4]
[ 0.320561] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.320666] pnp 00:03: [io 0x00f0-0x00ff]
[ 0.320687] pnp 00:03: [irq 13]
[ 0.320726] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.320831] pnp 00:04: [io 0x0061]
[ 0.320873] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.320978] pnp 00:05: [io 0x0070-0x007f]
[ 0.320987] pnp 00:05: [irq 8]
[ 0.321027] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.324125] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.324130] pnp 00:06: [io 0x03f7]
[ 0.324139] pnp 00:06: [irq 6]
[ 0.324143] pnp 00:06: [dma 2]
[ 0.324393] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.325353] pnp 00:07: [io 0x0060]
[ 0.325358] pnp 00:07: [io 0x0064]
[ 0.325366] pnp 00:07: [irq 1]
[ 0.325417] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.329256] pnp 00:08: [io 0x03f8-0x03ff]
[ 0.329266] pnp 00:08: [irq 4]
[ 0.329475] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.332859] pnp 00:09: [io 0x0378-0x037f]
[ 0.332863] pnp 00:09: [io 0x0778-0x077f]
[ 0.332872] pnp 00:09: [irq 7]
[ 0.332877] pnp 00:09: [dma 0 disabled]
[ 0.333395] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.335099] pnp 00:0a: [io 0x0062-0x0063]
[ 0.335104] pnp 00:0a: [io 0x0065-0x006f]
[ 0.335109] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.335113] pnp 00:0a: [io 0x0800-0x085f]
[ 0.335116] pnp 00:0a: [io 0x0c00-0x0c7f]
[ 0.335119] pnp 00:0a: [io 0x0860-0x08ff]
[ 0.335190] system 00:0a: [io 0x0800-0x085f] has been reserved
[ 0.335196] system 00:0a: [io 0x0c00-0x0c7f] has been reserved
[ 0.335200] system 00:0a: [io 0x0860-0x08ff] has been reserved
[ 0.335205] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.336054] pnp: PnP ACPI: found 11 devices
[ 0.336058] ACPI: ACPI bus type pnp unregistered
[ 0.336066] PnPBIOS: Disabled by ACPI PNP
[ 0.373467] Switching to clocksource acpi_pm
[ 0.373515] pci 0000:01:09.0: address space collision: [mem 0xfea00000-0xfea03fff pref] conflicts with 0000:01:05.0 [mem 0xfea00000-0xfea0ffff pref]
[ 0.373547] pci 0000:00:1e.0: BAR 15: assigned [mem 0x60000000-0x600fffff pref]
[ 0.373553] pci 0000:01:09.0: BAR 6: assigned [mem 0x60000000-0x60003fff pref]
[ 0.373559] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[ 0.373565] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.373574] pci 0000:00:1e.0: bridge window [mem 0xfe900000-0xfeafffff]
[ 0.373580] pci 0000:00:1e.0: bridge window [mem 0x60000000-0x600fffff pref]
[ 0.373603] pci 0000:00:1e.0: setting latency timer to 64
[ 0.373609] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.373614] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.373618] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 0.373622] pci_bus 0000:01: resource 1 [mem 0xfe900000-0xfeafffff]
[ 0.373626] pci_bus 0000:01: resource 2 [mem 0x60000000-0x600fffff pref]
[ 0.373630] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.373634] pci_bus 0000:01: resource 5 [mem 0x00000000-0xffffffff]
[ 0.373753] NET: Registered protocol family 2
[ 0.373880] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.374330] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.375850] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.375850] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.375850] TCP: reno registered
[ 0.375850] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.375850] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.375850] NET: Registered protocol family 1
[ 0.375853] pci 0000:00:02.0: Boot video device
[ 0.376131] PCI: CLS 64 bytes, default 64
[ 0.376251] Unpacking initramfs...
[ 0.808491] Freeing initrd memory: 14212k freed
[ 0.839069] Simple Boot Flag value 0x87 read from CMOS RAM was invalid
[ 0.839078] Simple Boot Flag at 0x7a set to 0x1
[ 0.839807] audit: initializing netlink socket (disabled)
[ 0.839852] type=2000 audit(1413905659.836:1): initialized
[ 0.852090] highmem bounce pool size: 64 pages
[ 0.852101] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.852318] VFS: Disk quotas dquot_6.5.2
[ 0.852358] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.852475] msgmni has been set to 1731
[ 0.852752] alg: No test for stdrng (krng)
[ 0.852803] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.852808] io scheduler noop registered
[ 0.852811] io scheduler deadline registered
[ 0.852834] io scheduler cfq registered (default)
[ 0.852963] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.852993] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.852997] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.853436] GHES: HEST is not enabled!
[ 0.853456] isapnp: Scanning for PnP cards...
[ 1.207577] isapnp: No Plug & Play device found
[ 1.207659] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.228027] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.248739] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.248946] Linux agpgart interface v0.103
[ 1.249050] agpgart-intel 0000:00:00.0: Intel 845G Chipset
[ 1.249085] agpgart-intel 0000:00:00.0: detected gtt size: 131072K total, 131072K mappable
[ 1.249232] agpgart-intel 0000:00:00.0: detected 1024K stolen memory
[ 1.249408] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 1.249595] i8042: PNP: PS/2 Controller [PNP0303:KBD] at 0x60,0x64 irq 1
[ 1.249599] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 1.250529] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.250680] mousedev: PS/2 mouse device common for all mice
[ 1.250758] rtc_cmos 00:05: RTC can wake from S4
[ 1.250901] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.250929] rtc0: alarms up to one day, 242 bytes nvram
[ 1.251116] TCP: cubic registered
[ 1.251179] NET: Registered protocol family 10
[ 1.251501] Mobile IPv6
[ 1.251506] NET: Registered protocol family 17
[ 1.251514] Registering the dns_resolver key type
[ 1.251596] Using IPI No-Shortcut mode
[ 1.251759] PM: Hibernation image not present or could not be loaded.
[ 1.251782] registered taskstats version 1
[ 1.252232] rtc_cmos 00:05: setting system clock to 2014-10-21 15:34:20 UTC (1413905660)
[ 1.252396] Freeing unused kernel memory: 416k freed
[ 1.253091] Write protecting the kernel text: 3496k
[ 1.253117] Write protecting the kernel read-only data: 984k
[ 1.271062] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.284444] udevd[45]: starting version 175
[ 1.379698] usbcore: registered new interface driver usbfs
[ 1.379743] usbcore: registered new interface driver hub
[ 1.394341] usbcore: registered new device driver usb
[ 1.404984] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.405087] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.405094] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.405144] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.405195] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.408583] SCSI subsystem initialized
[ 1.412304] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.447196] Floppy drive(s): fd0 is 1.44M
[ 1.456829] libata version 3.00 loaded.
[ 1.468137] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.468183] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xffa80800
[ 1.475625] FDC 0 is a post-1991 82077
[ 1.480154] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.480244] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.480249] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.480254] usb usb1: Product: EHCI Host Controller
[ 1.480257] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.480261] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.480467] hub 1-0:1.0: USB hub found
[ 1.480478] hub 1-0:1.0: 6 ports detected
[ 1.481539] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.481547] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.481572] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.481636] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000ff80
[ 1.481711] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.481715] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.481719] usb usb2: Product: UHCI Host Controller
[ 1.481723] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.481726] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.482195] hub 2-0:1.0: USB hub found
[ 1.482207] hub 2-0:1.0: 2 ports detected
[ 1.482367] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.482373] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.482390] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.482441] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000ff60
[ 1.482503] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.482508] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.482511] usb usb3: Product: UHCI Host Controller
[ 1.482515] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.482518] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.482711] hub 3-0:1.0: USB hub found
[ 1.482720] hub 3-0:1.0: 2 ports detected
[ 1.482851] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.482857] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.482870] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.482916] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.482978] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.482983] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.482986] usb usb4: Product: UHCI Host Controller
[ 1.482990] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.482994] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.483157] hub 4-0:1.0: USB hub found
[ 1.483166] hub 4-0:1.0: 2 ports detected
[ 1.483281] ata_piix 0000:00:1f.1: version 2.13
[ 1.483370] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.486971] scsi0 : ata_piix
[ 1.490303] microcode: CPU0 sig=0xf29, pf=0x4, revision=0x17
[ 1.490392] scsi1 : ata_piix
[ 1.490481] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.490487] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.496377] ssb: Found chip with id 0x4401, rev 0x01 and package 0x00
[ 1.496387] ssb: Core 0 found: Fast Ethernet (cc 0x806, rev 0x04, vendor 0x4243)
[ 1.496395] ssb: Core 1 found: V90 (cc 0x807, rev 0x01, vendor 0x4243)
[ 1.496402] ssb: Core 2 found: PCI (cc 0x804, rev 0x02, vendor 0x4243)
[ 1.536294] ssb: Sonics Silicon Backplane found on PCI device 0000:01:09.0
[ 1.536345] b44: Broadcom 44xx/47xx 10/100 PCI ethernet driver version 2.0
[ 1.556684] b44 ssb0:0: eth0: Broadcom 44xx/47xx 10/100 PCI ethernet driver 00:0f:1f:58:d9:f6
[ 1.570958] microcode: CPU0 updated to revision 0x2e, date = 2004-08-11
[ 1.571525] microcode: Microcode Update Driver: v2.00 <This email address is being protected from spambots. You need JavaScript enabled to view it.>, Peter Oruba
[ 1.656931] ata2.00: ATAPI: JLMS DVD-ROM XJ-HD166, DD05, max UDMA/33
[ 1.656941] ata2.01: ATAPI: Philips DVD+RW DVD8601, 6D11, max UDMA/33
[ 1.657365] ata2.00: configured for UDMA/33
[ 1.660469] ata1.00: ATA-7: HDS728080PLAT20, PF2OA21B, max UDMA/133
[ 1.660474] ata1.00: 160836480 sectors, multi 8: LBA48
[ 1.672427] ata2.01: configured for UDMA/33
[ 1.684372] ata1.00: configured for UDMA/100
[ 1.684567] scsi 0:0:0:0: Direct-Access ATA HDS728080PLAT20 PF2O PQ: 0 ANSI: 5
[ 1.685125] scsi 1:0:0:0: CD-ROM JLMS DVD-ROM XJ-HD166 DD05 PQ: 0 ANSI: 5
[ 1.687241] scsi 1:0:1:0: CD-ROM Philips DVD+RW DVD8601 6D11 PQ: 0 ANSI: 5
[ 1.715435] sd 0:0:0:0: [sda] 160836480 512-byte logical blocks: (82.3 GB/76.6 GiB)
[ 1.715544] sd 0:0:0:0: [sda] Write Protect is off
[ 1.715549] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.715594] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.718072] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 1.718081] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 1.718932] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.722559] sr1: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[ 1.722938] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 1.724335] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.724460] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.724573] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 1.742036] sda: sda1 sda2 < sda5 >
[ 1.742611] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.848122] Refined TSC clocksource calibration: 2790.995 MHz.
[ 1.848134] Switching to clocksource tsc
[ 1.976041] usb 3-2: new low-speed USB device number 2 using uhci_hcd
[ 2.150398] usb 3-2: New USB device found, idVendor=0461, idProduct=4d0f
[ 2.150406] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.150411] usb 3-2: Product: USB Optical Mouse
[ 2.150414] usb 3-2: Manufacturer: PixArt
[ 2.177395] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1d.1/usb3/3-2/3-2:1.0/input/input1
[ 2.177628] generic-usb 0003:0461:4D0F.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1d.1-2/input0
[ 2.177980] usbcore: registered new interface driver usbhid
[ 2.177985] usbhid: USB HID core driver
[ 7.111480] PM: Starting manual resume from disk
[ 7.111489] PM: Hibernation image partition 8:5 present
[ 7.111492] PM: Looking for hibernation image.
[ 7.111838] PM: Image not found (code -22)
[ 7.111841] PM: Hibernation image not present or could not be loaded.
[ 7.154869] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.295870] udevd[312]: starting version 175
[ 9.624988] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 9.625004] ACPI: Power Button [VBTN]
[ 9.625113] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.625119] ACPI: Power Button [PWRF]
[ 9.750481] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 9.832645] parport_pc 00:09: reported by Plug and Play ACPI
[ 9.832701] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 9.978428] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.023893] intel_rng: FWH not detected
[ 10.231933] [drm] Initialized drm 1.1.0 20060810
[ 10.331707] iTCO_vendor_support: vendor-support=0
[ 10.392421] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.392543] iTCO_wdt: Found a ICH4 TCO device (Version=1, TCOBASE=0x0860)
[ 10.394043] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.589741] i915 0000:00:02.0: setting latency timer to 64
[ 10.602283] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 10.602290] [drm] Driver supports precise vblank timestamp query.
[ 10.602364] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 10.607385] [drm] initialized overlay support
[ 10.694214] fbcon: inteldrmfb (fb0) is primary device
[ 10.813582] Console: switching to colour frame buffer device 128x48
[ 10.817762] fb0: inteldrmfb frame buffer device
[ 10.817767] drm: registered panic notifier
[ 10.817781] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 10.817911] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 11.248032] intel8x0_measure_ac97_clock: measured 54318 usecs (2617 samples)
[ 11.248039] intel8x0: clocking to 48000
[ 12.638287] Adding 3139580k swap on /dev/sda5. Priority:-1 extents:1 across:3139580k
[ 12.670781] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.967962] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.134688] loop: module loaded
[ 15.547562] RPC: Registered named UNIX socket transport module.
[ 15.547570] RPC: Registered udp transport module.
[ 15.547574] RPC: Registered tcp transport module.
[ 15.547577] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.580364] FS-Cache: Loaded
[ 15.615567] NFS: Registering the id_resolver key type
[ 15.615613] FS-Cache: Netfs 'nfs' registered for caching
[ 15.633235] Installing knfsd (copyright (C) 1996 This email address is being protected from spambots. You need JavaScript enabled to view it.).
[ 17.831645] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input4
[ 19.870585] Bluetooth: Core ver 2.16
[ 19.871025] NET: Registered protocol family 31
[ 19.871031] Bluetooth: HCI device and connection manager initialized
[ 19.871037] Bluetooth: HCI socket layer initialized
[ 19.871040] Bluetooth: L2CAP socket layer initialized
[ 19.871051] Bluetooth: SCO socket layer initialized
[ 19.944997] Bluetooth: RFCOMM TTY layer initialized
[ 19.945010] Bluetooth: RFCOMM socket layer initialized
[ 19.945014] Bluetooth: RFCOMM ver 1.11
[ 20.058658] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.058665] Bluetooth: BNEP filters: protocol multicast
[ 20.188091] lp0: using parport0 (interrupt-driven).
[ 20.262429] ppdev: user-space parallel port driver
[ 22.402343] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.184951] [drm] capturing error event; look for more information in /debug/dri/0/i915_error_state
[ 26.188400] render error detected, EIR: 0x00000010
[ 26.188400] [drm:i915_report_and_clear_eir] *ERROR* EIR stuck: 0x00000010, masking
[ 948.656017] [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung
[ 948.672095] render error detected, EIR: 0x00000010
[ 948.672107] [drm:i915_report_and_clear_eir] *ERROR* EIR stuck: 0x00000010, masking
[ 948.672118] render error detected, EIR: 0x00000010
[ 950.388020] [drm:i915_hangcheck_elapsed] *ERROR* Hangcheck timer elapsed... GPU hung
[ 950.388410] [drm:i915_reset] *ERROR* GPU hanging too fast, declaring wedged!
[ 950.388417] [drm:i915_reset] *ERROR* Failed to reset chip.
[ 1046.964170] usb 1-6: new high-speed USB device number 3 using ehci_hcd
[ 1047.118585] usb 1-6: New USB device found, idVendor=148f, idProduct=5370
[ 1047.118592] usb 1-6: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1047.118597] usb 1-6: Product: 802.11 n WLAN
[ 1047.118601] usb 1-6: Manufacturer: Ralink
[ 1047.118604] usb 1-6: SerialNumber: 1.0
[ 1047.293088] cfg80211: Calling CRDA to update world regulatory domain
[ 1047.358319] cfg80211: World regulatory domain updated:
[ 1047.358329] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 1047.358334] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 1047.358338] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 1047.358342] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm)
[ 1047.358346] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 1047.358349] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 1047.358353] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[ 1047.544143] usb 1-6: reset high-speed USB device number 3 using ehci_hcd
[ 1047.750230] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[ 1047.751076] Registered led device: rt2800usb-phy0::radio
[ 1047.751149] Registered led device: rt2800usb-phy0::assoc
[ 1047.751598] Registered led device: rt2800usb-phy0::quality
[ 1047.752645] usbcore: registered new interface driver rt2800usb
[ 1048.335445] ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 1216.002401] wlan0: authenticate with d0:ae:ec:c5:d1:fc
[ 1216.033140] wlan0: send auth to d0:ae:ec:c5:d1:fc (try 1/3)
[ 1216.034915] wlan0: authenticated
[ 1216.060039] wlan0: associate with d0:ae:ec:c5:d1:fc (try 1/3)
[ 1216.063635] wlan0: RX AssocResp from d0:ae:ec:c5:d1:fc (capab=0xc31 status=0 aid=1)
[ 1216.093153] ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 1216.093566] wlan0: associated
[ 1216.093834] cfg80211: Calling CRDA for country: ES
[ 1216.166738] cfg80211: Regulatory domain changed to country: ES
[ 1216.166746] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 1216.166751] cfg80211: (2400000 KHz - 2483500 KHz @ 40000 KHz), (N/A, 2000 mBm)
[ 1216.166755] cfg80211: (5150000 KHz - 5250000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 1216.166759] cfg80211: (5250000 KHz - 5350000 KHz @ 80000 KHz), (N/A, 2000 mBm)
[ 1216.166763] cfg80211: (5470000 KHz - 5725000 KHz @ 80000 KHz), (N/A, 2698 mBm)
[ 1216.166766] cfg80211: (57240000 KHz - 65880000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[ 1227.904013] wlan0: no IPv6 routers present
[ 1898.043209] I-pipe: head domain RTAI registered.
[ 1898.043223] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1898.043233] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1898.043238] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8306480, CLK_FREQ 2791046000, CPU_FREQ 2791046000
[ 1898.043243] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1898.043248] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8306480, 8306480, 8246750
[ 1898.107772] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1898.107869] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1898.107877] RTAI[sched]: hard timer type/freq = APIC/8306480(Hz); default timing: oneshot; linear timed lists.
[ 1898.107882] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2791046000 hz.
[ 1898.107886] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 1898.140865] RTAI[math]: loaded.
[ 1898.511678] hm2: loading Mesa HostMot2 driver version 0.15
[ 1898.528101] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 1898.528172] hm2_pci: discovered 5i23 at 0000:01:05.0
[ 1898.533489] hm2/hm2_5i23.0: firmware hm2/5i23/5i23_svss6_8.BIT not found
[ 1898.533498] hm2/hm2_5i23.0: install the package containing the firmware.
[ 1898.533504] hm2_5i23.0: board fails HM2 registration
[ 1898.533572] hm2_pci: probe of 0000:01:05.0 failed with error -2
[ 1899.141959] hm2: unloading
[ 1899.280787] RTAI[math]: unloaded.
[ 1899.285597] SCHED releases registered named ALIEN PEDV$D
[ 1899.294918] RTAI[malloc]: unloaded.
[ 1899.392023] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1899.396783] I-pipe: head domain RTAI unregistered.
[ 1899.396801] RTAI[hal]: unmounted.
[ 4374.796616] I-pipe: head domain RTAI registered.
[ 4374.796630] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4374.796640] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4374.796646] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8306480, CLK_FREQ 2791046000, CPU_FREQ 2791046000
[ 4374.796650] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4374.796655] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8306480, 8306480, 8234000
[ 4374.821514] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4374.821625] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4374.821633] RTAI[sched]: hard timer type/freq = APIC/8306480(Hz); default timing: oneshot; linear timed lists.
[ 4374.821638] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2791046000 hz.
[ 4374.821641] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4374.839059] RTAI[math]: loaded.
[ 4375.073728] hm2: loading Mesa HostMot2 driver version 0.15
[ 4375.079219] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4375.079294] hm2_pci: discovered 5i23 at 0000:01:05.0
[ 4375.084555] hm2/hm2_5i23.0: firmware hm2/5i23/5i23_svss6_8.BIT not found
[ 4375.084563] hm2/hm2_5i23.0: install the package containing the firmware.
[ 4375.084569] hm2_5i23.0: board fails HM2 registration
[ 4375.084634] hm2_pci: probe of 0000:01:05.0 failed with error -2
[ 4375.601791] hm2: unloading
[ 4375.708452] RTAI[math]: unloaded.
[ 4375.713219] SCHED releases registered named ALIEN PEDV$D
[ 4375.722968] RTAI[malloc]: unloaded.
[ 4375.820024] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4375.824794] I-pipe: head domain RTAI unregistered.
[ 4375.824814] RTAI[hal]: unmounted.
[ 4842.243561] I-pipe: head domain RTAI registered.
[ 4842.243575] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4842.243585] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4842.243591] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8306480, CLK_FREQ 2791046000, CPU_FREQ 2791046000
[ 4842.243595] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4842.243600] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8306480, 8306480, 8244000
[ 4842.275135] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4842.275231] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4842.275238] RTAI[sched]: hard timer type/freq = APIC/8306480(Hz); default timing: oneshot; linear timed lists.
[ 4842.275244] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2791046000 hz.
[ 4842.275247] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4842.302888] RTAI[math]: loaded.
[ 4842.536305] hm2: loading Mesa HostMot2 driver version 0.15
[ 4842.541824] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4842.541901] hm2_pci: discovered 5i23 at 0000:01:05.0
[ 4842.547189] hm2/hm2_5i23.0: firmware hm2/5i23/5i23_svss6_8.BIT not found
[ 4842.547198] hm2/hm2_5i23.0: install the package containing the firmware.
[ 4842.547204] hm2_5i23.0: board fails HM2 registration
[ 4842.547271] hm2_pci: probe of 0000:01:05.0 failed with error -2
[ 4843.068467] hm2: unloading
[ 4843.175350] RTAI[math]: unloaded.
[ 4843.180124] SCHED releases registered named ALIEN PEDV$D
[ 4843.191106] RTAI[malloc]: unloaded.
[ 4843.288030] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4843.292795] I-pipe: head domain RTAI unregistered.
[ 4843.292814] RTAI[hal]: unmounted.
[ 4913.826897] I-pipe: head domain RTAI registered.
[ 4913.826912] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 4913.826922] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 4913.826927] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8306480, CLK_FREQ 2791046000, CPU_FREQ 2791046000
[ 4913.826931] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 4913.826936] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8306480, 8306480, 8187750
[ 4913.852112] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 4913.852215] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 4913.852223] RTAI[sched]: hard timer type/freq = APIC/8306480(Hz); default timing: oneshot; linear timed lists.
[ 4913.852228] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2791046000 hz.
[ 4913.852232] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 4913.875405] RTAI[math]: loaded.
[ 4914.102802] hm2: loading Mesa HostMot2 driver version 0.15
[ 4914.108332] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 4914.108406] hm2_pci: discovered 5i23 at 0000:01:05.0
[ 4914.114033] hm2/hm2_5i23.0: firmware hm2/5i23/5i23_svss6_8.BIT not found
[ 4914.114042] hm2/hm2_5i23.0: install the package containing the firmware.
[ 4914.114048] hm2_5i23.0: board fails HM2 registration
[ 4914.114112] hm2_pci: probe of 0000:01:05.0 failed with error -2
[ 4914.633306] hm2: unloading
[ 4914.740947] RTAI[math]: unloaded.
[ 4914.745681] SCHED releases registered named ALIEN PEDV$D
[ 4914.755407] RTAI[malloc]: unloaded.
[ 4914.852026] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 4914.856755] I-pipe: head domain RTAI unregistered.
[ 4914.856775] RTAI[hal]: unmounted.
[ 5136.043329] I-pipe: head domain RTAI registered.
[ 5136.043344] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 5136.043354] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 5136.043359] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 8306480, CLK_FREQ 2791046000, CPU_FREQ 2791046000
[ 5136.043364] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 5136.043369] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 8306480, 8306480, 8190750
[ 5136.064883] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 5136.064983] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 5136.064990] RTAI[sched]: hard timer type/freq = APIC/8306480(Hz); default timing: oneshot; linear timed lists.
[ 5136.064995] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2791046000 hz.
[ 5136.064999] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 5136.085959] RTAI[math]: loaded.
[ 5136.315738] hm2: loading Mesa HostMot2 driver version 0.15
[ 5136.321187] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 5136.321250] hm2_pci: discovered 5i23 at 0000:01:05.0
[ 5136.485826] hm2/hm2_5i23.0: Smart Serial Firmware Version 43
[ 5136.547426] hm2/hm2_5i23.0: 72 I/O Pins used:
[ 5136.547435] hm2/hm2_5i23.0: IO Pin 000 (P2-01): PWMGen #0, pin Not-Enable (Output)
[ 5136.547440] hm2/hm2_5i23.0: IO Pin 001 (P2-03): Muxed Encoder #0, pin Muxed A (Input)
[ 5136.547445] hm2/hm2_5i23.0: IO Pin 002 (P2-05): Muxed Encoder #0, pin Muxed B (Input)
[ 5136.547449] hm2/hm2_5i23.0: IO Pin 003 (P2-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 5136.547453] hm2/hm2_5i23.0: IO Pin 004 (P2-09): Muxed Encoder #1, pin Muxed A (Input)
[ 5136.547458] hm2/hm2_5i23.0: IO Pin 005 (P2-11): Muxed Encoder #1, pin Muxed B (Input)
[ 5136.547462] hm2/hm2_5i23.0: IO Pin 006 (P2-13): Muxed Encoder #1, pin Muxed Index (Input)
[ 5136.547466] hm2/hm2_5i23.0: IO Pin 007 (P2-15): Muxed Encoder #2, pin Muxed A (Input)
[ 5136.547471] hm2/hm2_5i23.0: IO Pin 008 (P2-17): Muxed Encoder #2, pin Muxed B (Input)
[ 5136.547475] hm2/hm2_5i23.0: IO Pin 009 (P2-19): Muxed Encoder #2, pin Muxed Index (Input)
[ 5136.547480] hm2/hm2_5i23.0: IO Pin 010 (P2-21): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 5136.547484] hm2/hm2_5i23.0: IO Pin 011 (P2-23): PWMGen #0, pin Out0 (PWM or Up) (Output)
[ 5136.547488] hm2/hm2_5i23.0: IO Pin 012 (P2-25): PWMGen #0, pin Out1 (Dir or Down) (Output)
[ 5136.547493] hm2/hm2_5i23.0: IO Pin 013 (P2-27): PWMGen #1, pin Out0 (PWM or Up) (Output)
[ 5136.547497] hm2/hm2_5i23.0: IO Pin 014 (P2-29): PWMGen #1, pin Out1 (Dir or Down) (Output)
[ 5136.547502] hm2/hm2_5i23.0: IO Pin 015 (P2-31): PWMGen #2, pin Out0 (PWM or Up) (Output)
[ 5136.547506] hm2/hm2_5i23.0: IO Pin 016 (P2-33): PWMGen #2, pin Out1 (Dir or Down) (Output)
[ 5136.547510] hm2/hm2_5i23.0: IO Pin 017 (P2-35): PWMGen #3, pin Out0 (PWM or Up) (Output)
[ 5136.547514] hm2/hm2_5i23.0: IO Pin 018 (P2-37): PWMGen #3, pin Out1 (Dir or Down) (Output)
[ 5136.547519] hm2/hm2_5i23.0: IO Pin 019 (P2-39): PWMGen #4, pin Out0 (PWM or Up) (Output)
[ 5136.547523] hm2/hm2_5i23.0: IO Pin 020 (P2-41): PWMGen #4, pin Out1 (Dir or Down) (Output)
[ 5136.547527] hm2/hm2_5i23.0: IO Pin 021 (P2-43): IOPort
[ 5136.547531] hm2/hm2_5i23.0: IO Pin 022 (P2-45): IOPort
[ 5136.547535] hm2/hm2_5i23.0: IO Pin 023 (P2-47): PWMGen #0, pin Not-Enable (Output)
[ 5136.547539] hm2/hm2_5i23.0: IO Pin 024 (P3-01): IOPort
[ 5136.547542] hm2/hm2_5i23.0: IO Pin 025 (P3-03): IOPort
[ 5136.547546] hm2/hm2_5i23.0: IO Pin 026 (P3-05): IOPort
[ 5136.547549] hm2/hm2_5i23.0: IO Pin 027 (P3-07): IOPort
[ 5136.547553] hm2/hm2_5i23.0: IO Pin 028 (P3-09): IOPort
[ 5136.547556] hm2/hm2_5i23.0: IO Pin 029 (P3-11): IOPort
[ 5136.547560] hm2/hm2_5i23.0: IO Pin 030 (P3-13): IOPort
[ 5136.547563] hm2/hm2_5i23.0: IO Pin 031 (P3-15): IOPort
[ 5136.547567] hm2/hm2_5i23.0: IO Pin 032 (P3-17): IOPort
[ 5136.547570] hm2/hm2_5i23.0: IO Pin 033 (P3-19): IOPort
[ 5136.547574] hm2/hm2_5i23.0: IO Pin 034 (P3-21): IOPort
[ 5136.547577] hm2/hm2_5i23.0: IO Pin 035 (P3-23): IOPort
[ 5136.547581] hm2/hm2_5i23.0: IO Pin 036 (P3-25): IOPort
[ 5136.547584] hm2/hm2_5i23.0: IO Pin 037 (P3-27): IOPort
[ 5136.547588] hm2/hm2_5i23.0: IO Pin 038 (P3-29): IOPort
[ 5136.547591] hm2/hm2_5i23.0: IO Pin 039 (P3-31): IOPort
[ 5136.547595] hm2/hm2_5i23.0: IO Pin 040 (P3-33): IOPort
[ 5136.547598] hm2/hm2_5i23.0: IO Pin 041 (P3-35): IOPort
[ 5136.547602] hm2/hm2_5i23.0: IO Pin 042 (P3-37): IOPort
[ 5136.547605] hm2/hm2_5i23.0: IO Pin 043 (P3-39): IOPort
[ 5136.547609] hm2/hm2_5i23.0: IO Pin 044 (P3-41): IOPort
[ 5136.547612] hm2/hm2_5i23.0: IO Pin 045 (P3-43): IOPort
[ 5136.547616] hm2/hm2_5i23.0: IO Pin 046 (P3-45): IOPort
[ 5136.547619] hm2/hm2_5i23.0: IO Pin 047 (P3-47): IOPort
[ 5136.547623] hm2/hm2_5i23.0: IO Pin 048 (P4-01): IOPort
[ 5136.547626] hm2/hm2_5i23.0: IO Pin 049 (P4-03): IOPort
[ 5136.547630] hm2/hm2_5i23.0: IO Pin 050 (P4-05): IOPort
[ 5136.547633] hm2/hm2_5i23.0: IO Pin 051 (P4-07): IOPort
[ 5136.547637] hm2/hm2_5i23.0: IO Pin 052 (P4-09): IOPort
[ 5136.547640] hm2/hm2_5i23.0: IO Pin 053 (P4-11): IOPort
[ 5136.547644] hm2/hm2_5i23.0: IO Pin 054 (P4-13): IOPort
[ 5136.547647] hm2/hm2_5i23.0: IO Pin 055 (P4-15): IOPort
[ 5136.547651] hm2/hm2_5i23.0: IO Pin 056 (P4-17): IOPort
[ 5136.547654] hm2/hm2_5i23.0: IO Pin 057 (P4-19): IOPort
[ 5136.547658] hm2/hm2_5i23.0: IO Pin 058 (P4-21): IOPort
[ 5136.547661] hm2/hm2_5i23.0: IO Pin 059 (P4-23): IOPort
[ 5136.547665] hm2/hm2_5i23.0: IO Pin 060 (P4-25): IOPort
[ 5136.547668] hm2/hm2_5i23.0: IO Pin 061 (P4-27): IOPort
[ 5136.547672] hm2/hm2_5i23.0: IO Pin 062 (P4-29): IOPort
[ 5136.547675] hm2/hm2_5i23.0: IO Pin 063 (P4-31): IOPort
[ 5136.547679] hm2/hm2_5i23.0: IO Pin 064 (P4-33): IOPort
[ 5136.547682] hm2/hm2_5i23.0: IO Pin 065 (P4-35): IOPort
[ 5136.547686] hm2/hm2_5i23.0: IO Pin 066 (P4-37): IOPort
[ 5136.547689] hm2/hm2_5i23.0: IO Pin 067 (P4-39): IOPort
[ 5136.547693] hm2/hm2_5i23.0: IO Pin 068 (P4-41): IOPort
[ 5136.547696] hm2/hm2_5i23.0: IO Pin 069 (P4-43): IOPort
[ 5136.547700] hm2/hm2_5i23.0: IO Pin 070 (P4-45): IOPort
[ 5136.547703] hm2/hm2_5i23.0: IO Pin 071 (P4-47): IOPort
[ 5136.547850] hm2/hm2_5i23.0: registered
[ 5136.547856] hm2_5i23.0: initialized AnyIO board at 0000:01:05.0
[ 5136.591789] classicladder_rt: module license 'LGPL' taints kernel.
[ 5136.591799] Disabling lock debugging due to kernel taint
[ 5136.593570] creating ladder-state
[ 5142.073366] hm2_5i23.0: dropping AnyIO board at 0000:01:05.0
[ 5142.073378] hm2/hm2_5i23.0: unregistered
[ 5142.074052] hm2_pci: driver unloaded
[ 5142.084989] hm2: unloading
[ 5144.340802] RTAI[math]: unloaded.
[ 5144.345574] SCHED releases registered named ALIEN PEDV$D
[ 5144.355215] RTAI[malloc]: unloaded.
[ 5144.452053] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 5144.456773] I-pipe: head domain RTAI unregistered.
[ 5144.456792] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.1
TASK=milltask
HALUI=halui
DISPLAY=axis
4407
4461
[ 0.093331] dummy:
- Thank you received: 5101
22 Oct 2014 01:15 #52253
Replied by PCW on topic axis drops...is rthere a guide to isolate the bug?
I dont know much about modbus but it sure looks like a modbus error
(never got any response from the device)
so maybe wrong port/baudrate/rs-485 adapter troubles/protocol for device etc
The following user(s) said Thank You: mario_rl
- PnCConf Wizard
