Spindle Speed Scaling
- tjones
06 Nov 2014 12:14 #52861
by tjones
Spindle Speed Scaling was created by tjones
Hello,
I have a 5i25 pared with a 7i77. I am using the PWM spindle output on the last output, so TB5 - 5. I am trying to scale my output for a max spindle speed of 2000 rpm. I have a limiter set on my VFD so it will not go over 2000 but it would be nice to use 1000rpm once in awhile. I have looked at the page describing how to do this but I keep getting errors after trying. I have uploaded the Error message screen. If it's help I am using an automation direct GS3-2010 and using the analog input Ai3, which reads a +/- 10v signal.
Thanks,
Tosh Jones
Thanks,
Tosh Jones
- Thank you received: 2135
06 Nov 2014 14:15 - 06 Nov 2014 14:18 #52867
Replied by cmorley on topic Spindle Speed Scaling
i don't see the error message posted.
Did you set the analog scaling as such?
min -2000
max 2000
scale 2000
Chris M
min -2000
max 2000
scale 2000
Chris M
Last edit: 06 Nov 2014 14:18 by cmorley. Reason: forgot sign
Time to create page: 0.061 seconds
