External mpg jogging
- andradela
23 Dec 2014 03:24 #54233
by andradela
External mpg jogging was created by andradela
Hi folks.
I have some question about external mpg and pncconf.
I build my own mpg for old mpg parts, it has 2 rotary switches to select axis and feedrate, one input for each selection. I would like to know how do i config it using pncconf?
I started with.
I selected external mpg jogging
Shared mpg
Selectable mpg increments.
I'm using mesa board 7143, my problem is that i don't know witch function i need select in that page do config the mpg.
I started with.
Shared mpg
- Thank you received: 2159
23 Dec 2014 10:09 #54245
Replied by cmorley on topic External mpg jogging
on the mesa page pick an GPIO input and select 'Axis selection' and 'Joint select A'
Do the same for whatever amount of AXES you need. eg joint b, joint c
joint-select-a is for X axis
joint-select-b is for y axis
joint-select-c is for Z axis
now on the mesa page select 'Overrides', 'jog select a'
again add more inputs depending on how many jog speeds you may want.
in this case the signal can be multiplexed for more selections (up to 16)
If you don't want to multiplex then 4 speeds is the max
if you don't multiplex then only the bold faced speeds on the external page are available.
finally find an encoder counter on the mesa page and select multi hand wheel
hopefully that should do it
Chris M
Chris M
23 Dec 2014 10:13 #54246
did you try the help button on the external page?
I see I didn't explain how the axis selection worked...
Chris M
Chris M
The following user(s) said Thank You: andradela
- andradela
23 Dec 2014 17:15 #54255
by andradela
Replied by andradela on topic External mpg jogging
Thanks Chris, i will test today and tell you the results.
- andradela
31 Dec 2014 21:23 #54448
by andradela
I finished the test today. It worked fine.
Thanks again.
Thanks again.
01 Jan 2015 05:09 #54456
Great! Thanks for letting me know.
If there is something i could add to the help file let me know.
Chris M
Chris M
Time to create page: 0.051 seconds
