7i43 vs 5i25
15 Jan 2015 19:26 - 15 Jan 2015 19:31 #55024 by gandalf
7i43 vs 5i25 was created by gandalf
Hi All,
I'm planning to migrate from 5i25 + 7i76 (step gen, IO and spindle control) + 7i73 (pendant) to 7i43 (7i43-U-4 - USB/Parallel 48 I/O 400K FPGA) + 7i47 (step gen, IO) + 7i73 (pendant).
Pros of 7i43 is to use internal flat cable from mainboard (internal lpt connector) to 7i43 in the same enclosure and eliminate any pci cards to just fix the mainboard to plate.
But I'm losing the spindle control of the 7i76.
Here few questions:
1) Can I expect the same step gen performance of 5i25+7i76 using a 7i43 400k + ?
2) Is it possibile connect connect the 7i43 to the 7i76 to use its spindle control and then step gen and IO? Using adaptor?
3) I have a Inverter TOSHIBA VF-S11S 2007 PL-WP 0.75kW, is it supported by VFS11 VFD Driver (www.linuxcnc.org/docs/html/drivers/VFS11.html) ?
4) How to connect 7i73 to 7i47 and configure it?
Antonio
Last edit: 15 Jan 2015 19:31 by gandalf. Reason: 7i43 not 7i73
15 Jan 2015 22:55 #55031 by PCW
Replied by PCW on topic 7i43 vs 5i25
1. Yes
2. Yes (HDDB-ADPT or home made cable), another option is 7I47S
3. Dont know
4. You would need a 7I43 config for a 7I47/7I47S that includes a Sserial port
15 Jan 2015 23:19 #55034 by gandalf
Replied by gandalf on topic 7i43 vs 5i25
About point 2.
I bought a 7i47, my mistake. where can I find the correct pinout?
About point 4.
Where can I find examples how to modify 7i43 config?
16 Jan 2015 00:10 - 16 Jan 2015 00:14 #55035 by PCW
for the pinout, look at the 7I76 manual, This will require a custom 7I43 configuration
The HDDB adapter wires the HDR50 to DB25 pin in GPIO order which is the
simplest physical order:
HDR50	        DB25
1                       1
3                     14
5                       2
7                     15
for making your own configurations here is a brief introduction:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Editing_MESA_Bitfiles
Last edit: 16 Jan 2015 00:14 by PCW.
The following user(s) said Thank You: gandalf
16 Jan 2015 08:02 #55062 by gandalf
I will do a custom configuration for 7i43 to add 2 sserial on the second port (24 to 47)
I will try to connect just the 2 sserial (4 pins) from 7i43 to 7i76 (pin 7 to pin 10). The first sserial should work for 7i76 I/O and the second one should be the sserial exposed in screw terminal.
just to be sure, source code from 7i43.zip from mesanet.com is the correct source to use? It contains the hm2epp.xise. I did not found the hm2epp.xise in hostmot2-firmware.git (git.linuxcnc.org).
Time to create page: 0.127 seconds
