5i25 + 7i76 +7i84
- z3gn
10 Feb 2015 19:32 #55856
by z3gn
5i25 + 7i76 +7i84 was created by z3gn
Hello.
My first post here. This forum has been quite few times useful to me, but now I need help which I can't find anywhere in forum.
I am building cnc mill with mesa card 5i25 and 7i76. Today I ordered 7i84 card which will be connected to 7i76 rs422 port.
Pncconf wizard doesn't show me option for selecting smart serial card 7i84. I saw that is hard coded in python pncconf file(unlike firmware-s which you can add into /lib/firwmare/hm2/xx).
How to add 7i84 card to pncconf ? Do I many have to edit python pncconf script to be able to select 7i84 in pncconf? I will use all inputs and one mpg encoder input.
Thank you.
Thank you.
- Thank you received: 5205
10 Feb 2015 23:07 #55865
Replied by PCW on topic 5i25 + 7i76 +7i84
Currently Its probably easier to make a working config for the
7I76 and then add the 7I84 I/O connections directly to the hal file
The following user(s) said Thank You: z3gn
- z3gn
10 Feb 2015 23:53 #55868
by z3gn
Replied by z3gn on topic 5i25 + 7i76 +7i84
Thank you for your answer. When I'll get 7i84 I will try it and post here if I am successful.
- Thank you received: 2157
11 Feb 2015 10:31 #55884
Replied by cmorley on topic 5i25 + 7i76 +7i84
If some on can post the hal pins of the 7i84 in the regular mode and the encoder mode I will add it in a future version.
Chris M
Chris M
11 Feb 2015 12:08 #55885
The 7I84 pin names are identical to the 7I76 or 7I77 field I/O pin names
(well other than possible channel and port numbers and the 7I84 name)
- z3gn
17 Feb 2015 22:33 - 17 Feb 2015 22:34 #56055
by z3gn
Here is all output: pastie.org/9956737
Does someone knows how to set 7i84 to mode 2? I need to use mpg encoder input?
I finaly got 7i84 card. Here is halcmd show pin relevant to 7i84If some on can post the hal pins of the 7i84 in the regular mode and the encoder mode I will add it in a future version.
Chris M
7 float OUT 0 hm2_5i25.0.7i84.0.1.analogin0
7 float OUT 0 hm2_5i25.0.7i84.0.1.analogin1
7 float OUT 0 hm2_5i25.0.7i84.0.1.analogin2
7 float OUT 0 hm2_5i25.0.7i84.0.1.analogin3
7 float OUT 0 hm2_5i25.0.7i84.0.1.fieldvoltagea
7 float OUT 0 hm2_5i25.0.7i84.0.1.fieldvoltageb
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-00
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-00-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-01
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-01-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-02
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-02-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-03
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-03-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-04
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-04-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-05
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-05-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-06
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-06-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-07
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-07-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-08
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-08-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-09
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-09-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-10
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-10-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-11
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-11-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-12
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-12-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-13
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-13-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-14
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-14-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-15
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-15-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-16
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-16-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-17
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-17-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-18
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-18-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-19
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-19-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-20
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-20-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-21
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-21-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-22
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-22-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-23
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-23-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-24
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-24-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-25
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-25-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-26
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-26-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-27
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-27-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-28
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-28-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-29
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-29-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-30
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-30-not
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-31
7 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-31-not
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-00
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-01
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-02
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-03
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-04
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-05
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-06
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-07
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-08
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-09
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-10
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-11
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-12
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-13
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-14
7 bit IN FALSE hm2_5i25.0.7i84.0.1.output-15
Last edit: 17 Feb 2015 22:34 by z3gn.
- z3gn
17 Feb 2015 23:44 - 17 Feb 2015 23:45 #56056
by z3gn
I found how to change mode now. With
loadrt hm2_pci config=" num_encoders=2 num_pwmgens=0 num_3pwmgens=0 num_stepgens=10 sserial_port_0=0200x " in HAL file I got:
14 float OUT 0 hm2_5i25.0.7i84.0.1.analogin0
14 float OUT 0 hm2_5i25.0.7i84.0.1.analogin1
14 float OUT 0 hm2_5i25.0.7i84.0.1.analogin2
14 float OUT 0 hm2_5i25.0.7i84.0.1.analogin3
14 s32 OUT 0 hm2_5i25.0.7i84.0.1.enc0.count
14 bit I/O FALSE hm2_5i25.0.7i84.0.1.enc0.index-enable
14 float OUT 0 hm2_5i25.0.7i84.0.1.enc0.position
14 s32 OUT 0 hm2_5i25.0.7i84.0.1.enc0.rawcounts
14 bit I/O FALSE hm2_5i25.0.7i84.0.1.enc0.reset
14 s32 OUT 0 hm2_5i25.0.7i84.0.1.enc1.count
14 bit I/O FALSE hm2_5i25.0.7i84.0.1.enc1.index-enable
14 float OUT 0 hm2_5i25.0.7i84.0.1.enc1.position
14 s32 OUT 0 hm2_5i25.0.7i84.0.1.enc1.rawcounts
14 bit I/O FALSE hm2_5i25.0.7i84.0.1.enc1.reset
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-00
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-00-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-01
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-01-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-02
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-02-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-03
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-03-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-04
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-04-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-05
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-05-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-06
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-06-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-07
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-07-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-08
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-08-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-09
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-09-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-10
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-10-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-11
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-11-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-12
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-12-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-13
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-13-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-14
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-14-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-15
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-15-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-16
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-16-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-17
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-17-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-18
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-18-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-19
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-19-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-20
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-20-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-21
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-21-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-22
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-22-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-23
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-23-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-24
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-24-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-25
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-25-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-26
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-26-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-27
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-27-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-28
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-28-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-29
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-29-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-30
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-30-not
14 bit OUT FALSE hm2_5i25.0.7i84.0.1.input-31
14 bit OUT TRUE hm2_5i25.0.7i84.0.1.input-31-not
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-00
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-01
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-02
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-03
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-04
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-05
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-06
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-07
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-08
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-09
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-10
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-11
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-12
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-13
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-14
14 bit IN FALSE hm2_5i25.0.7i84.0.1.output-15
Last edit: 17 Feb 2015 23:45 by z3gn.
20 Feb 2015 16:23 #56143
Thanks for the print out - I will try to work on this soon
Chris M
Chris M
