run PncConf from source
- jtc
- Thank you received: 13
04 Mar 2015 21:10 #56462
by jtc
run PncConf from source was created by jtc
Hi.
How can I run the PncConf wizard from a RunInPlace installation?
João
João
- Thank you received: 5312
05 Mar 2015 01:20 #56473
Replied by PCW on topic run PncConf from source
if you have built a run-in-place version of linuxcnc you should be able to run
from the directory one level above the linuxcnc source directory
and then run pncconf from the command line:
. scripts/rip-environment
pncconf
The following user(s) said Thank You: jtc
- jtc
05 Mar 2015 02:04 #56475
by jtc
Replied by jtc on topic run PncConf from source
Yes it works,
Thank you.
Thank you.
