- Configuring LinuxCNC
- Configuration Tools
- PnCConf Wizard
- Anilam CrusaderM to Linuxcnc Mesa 7i77 + 5i25
- punking
19 Apr 2015 06:08 - 18 Jan 2016 18:07 #57884
by punking
Anilam CrusaderM to Linuxcnc Mesa 7i77 + 5i25 was created by punking
My 3 axis mill was working fine except my communication board in the controller stopped working and I no longer could drip feed large amounts of code. I know everything with the amps + servos + tachometers + glass slides are all operating ,as I can still plug everything in and hand enter code into the controller and it operates fine.
I tuned the amps per the manual with a oscilloscope and have that portion of the machine seemingly tip-top shape.
I have Ubuntu running on a capable machine. I have linuxcnc 2.6 installed and all working. I have a Mesa 5i25 board feeding a 7i77 board - all seems fine. I have the Demo version of Linuxcnc working.
last weekend I connected the 3 axia encoders to the 7i77 and ran 12volts for field power. the encoders on my machine are single ended not differential( I jumpered the 7i77 accordingly for the 3 axis for single ended)
I was able to calibrate each axis beautifully with a plunge indicator and adjusted the resolution in pcconf so they work perfect.
Question
my problem is wiring the output in TB5
I don't know what to do.
in the photo the connections circled in red come from anilam cpu (sig, common)
so to mimak the old controller I just wired the
7i77 GND to Common in the red circle
7i77 AOUT0 to Sig in the red circle
* I don't know what to do with ENA0- and ENA0+
The info below is how the amplifiers themselves are wired:
pins on the amplifiers listed below are fed off of the wires circled in yellow
Pin 2,3,4
of Connector J-1
on Page 6 of westamp manual
these three are the only pins wired
pin2 = sig
pin3 = tach
pin4 = common
Manual for my westamp amplifier:
www.ormec.com/LinkClick.aspx?fileticket=...3d&tabid=168&mid=757
right now if I start up the mill and have Linux cnc idling all the axis drift in the negative direction.
any help would be greatly appreciated
Question
Pin 2,3,4
of Connector J-1
pin2 = sig
pin3 = tach
pin4 = common
Last edit: 18 Jan 2016 18:07 by punking. Reason: updated Photograph
- Thank you received: 5192
19 Apr 2015 10:43 #57885
Replied by PCW on topic Anilam CrusaderM to Linuxcnc Mesa 7i77 + 5i25
Its a bit awkward because the Westamp drives are normally enabled and you have to ground
a pin on the drive to _disable_ the drive.
One option is to tie each inhibit input (J1 pin 8) to common (J1 pin 9)
with a 1K resistor. This will have the effect of disabling all axis by pulling pin 8 down to ground.
Then connect the ENA+ pins on the 7I77 to the drives J1 pins 10 (+15V)
and the ENA- pins to the drives inhibit input (J1 pin 8 ).
This will pullup the inhibit lines and enable the drives when analog enable is true in the hal file
The following user(s) said Thank You: punking
- punking
19 Apr 2015 17:24 #57888
by punking
Replied by punking on topic Anilam CrusaderM to Linuxcnc Mesa 7i77 + 5i25
ok i will work through with your idea. thank you so much.
chris
chris
- punking
19 Apr 2015 23:13 #57898
by punking
OK i have the ENA- on pin 8 with resister jumping pins 8 & 9 on amplifiers and ENA+ on pin 10 .
I can now energize the mill with the original reset button and the servos dont wander.
i have not completed the open loop test on any axis.
I noticed in PnCConf that i could set number of encoders to 3 but number of PWM generators was greyed out. shouldn't that be where i indicate how many amplifiers im running?
if i try to run the current setup in LinuxCnC i get the following error:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.6.7
Machine configuration directory is '/home/chrismoll/linuxcnc/configs/my_LinuxCNC_mill'
Machine configuration file is 'my_LinuxCNC_mill.ini'
INIFILE=/home/chrismoll/linuxcnc/configs/my_LinuxCNC_mill/my_LinuxCNC_mill.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=9892
Debug file information:
my_LinuxCNC_mill.hal:51: parameter or pin 'hm2_5i25.0.7i77.0.1.analogout0-scalemax' not found
9892
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernal Information I didn't include.
any help is greatly appreciated!
chris
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.7
TASK=milltask
HALUI=halui
DISPLAY=axis
9892
chris
20 Apr 2015 02:31 #57907
unless you have some other configuration problem in your hal or ini files,
the above often indicates that the 7I77 5V power is marginal or off
(so the analog I/O section is not running)
- punking
20 Apr 2015 06:50 #57917
by punking
i'll try feeding from an external powersupply rather than from the 5i25
thank you
chris
thank you
chris
20 Apr 2015 07:28 #57918
If you change the 7I77s 5V power source. make sure you change both the 7I77 and the 5I25s jumpers
- punking
20 Apr 2015 10:01 #57920
by punking
yes, will do
chris
yes, will do
chris
- punking
25 Apr 2015 23:07 - 03 May 2015 00:54 #58119
by punking
i had quite the week (fighting a flu) and the hard drive in my computer quit working...duh.
resolved computer issue almost, and now get an error still when starting linuxcnc
i copied error message below:
Warning: Spoiler!
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.7
Machine configuration directory is '/home/chrismoll/linuxcnc/configs/SuperMax_Anilam_SERVO'
Machine configuration file is 'SuperMax_Anilam_SERVO.ini'
INIFILE=/home/chrismoll/linuxcnc/configs/SuperMax_Anilam_SERVO/SuperMax_Anilam_SERVO.ini
TASK=milltask
HALUI=halui
DISPLAY=axis
Killing task linuxcncsvr, PID=2897
insmod: error inserting '/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko': -1 Invalid parameters
SuperMax_Anilam_SERVO.hal:9: exit value: 1
SuperMax_Anilam_SERVO.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
2897
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.6.7
TASK=milltask
HALUI=halui
DISPLAY=axis
2897
Last edit: 03 May 2015 00:54 by punking. Reason: consolidate error message
25 Apr 2015 23:23 #58122
[ 603.987467] hm2_pci: discovered 5i25 at 0000:01:06.0
[ 603.987514] hm2/hm2_5i25.0: invalid cookie, got 0xFFFFFFFF, expected 0x55AACAFE
[ 603.987518] hm2/hm2_5i25.0: FPGA failed to initialize, or unexpected firmware?
[ 603.987522] hm2_5i25.0: board fails HM2 regis
This indicates a hardware problem with the 5I25, most likely related to the PCI
interface.
The card was found (via slot addressing) but looks like perhaps the cookie address was wrong
= most likely unconnected pins on PCI bus
I would try cleaning the PCI slot and 5I25 contact fingers with 99% Isopropyl alcohol or
try another slot on the motherboard if one is available
interface.
- PnCConf Wizard
Time to create page: 0.121 seconds
