7i76E with 7i74
18 Aug 2015 02:34 - 18 Aug 2015 03:21 #61490 by ftree
7i76E with 7i74 was created by ftree
I've been looking through the source to see if there is any support for the 7i74 DB25 daughter cards for the 7i76E.
I can't see any code reference. Are these daughter cards to be supported in the near future? I'm looking to add a few rs422 to my machine.
Maybe I should speak with Andy.
Thanks!
Last edit: 18 Aug 2015 03:21 by ftree.
18 Aug 2015 03:22 - 18 Aug 2015 03:23 #61491 by PCW
Replied by PCW on topic 7i76E with 7i74
You wont see any mention of the 7I74 (or sserial daugtercards in general) in the linuxcnc source
as the remotes are all autodetected via discovery, specifically so the driver _does not_
have to have any card specific information
You would need 7I76e firmware that had the desired 7I74 pinout and modules
(The 7I74 is generic full duplex RS-422 interface so can be used for sserial,SSI,BISS,UART,FANUC-ABS modules etc )
Last edit: 18 Aug 2015 03:23 by PCW.
The following user(s) said Thank You: ftree
18 Aug 2015 03:31 #61492 by ftree
Replied by ftree on topic 7i76E with 7i74
Thanks PCW.
When I looked around pcconf I noticed that other boards could be added to the 7i76e conf tabs like on I/O Conn 1 such as the 7i84. I thought I might find the 7i74 in there somewhere.
Time to create page: 0.054 seconds
