Well that went poorly....
OK, so installed linux/linuxcnc from a new download Seems to have installed fine although there is a few thing in the boot-up I'll need to remove later (which config etc) I wonder if I should have let it partition the drive. It's a new 120G SSD
Had a sepearete laptop beside the machine beign worked on so I could step trhough the guides as I went.
Copied the bitfile from the c11.zip and realized I have no idea where it should actually go
Created a SM2000 folder (standard modern series 2000) in the linuxcnc/config dir
Copied the bit file there and used the mesaflash to update, then rebooted
Ran the stepper config program and saw it allowed for an import of the mach xml file so I grabbed than and tried to import it. Looks like it picked up a couple of the step/dir pins but nothing else.
Set the rest of the stuff as best as I could and tried the text-axis functions, nothing. Figured maybe I needed to complete a setup first so I kept going.
Ran the PNCconf app and I got totally lost so stuck to defaults
Reboot and when launching linuxcnc got an several errors about sim pins not existing and one about the paraport not existing. Changed the address of the paraport (this computer doesn't have one) to the default 0x3...) and finally got into linuxcnc
But nothing on the machine moves or even tries to blink on the BOB
I think I'll start from scratch tomorrow and reinstall everything again
M
