cncbasher wrote: the major problem you have is if you want encoders
as i say it's a learning curve and at time may be steep , but their is an active crew here , that will help you through if needed
so dont worry , i'll stick a matching config together in the next day or two for you , for your configuration , along with a basic hal and ini
cncbasher wrote: use it as a piece of the learning puzzle for now
i'll sort out the firmware shorlty , you'll have it before the board anyhow !
