Getiing a 5i25 with g540 going
11 years 1 week ago #64212 by blacksmith
My System:
Linux debian 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
Debian Debian GNU/Linux 7.9 (wheezy) 7.9 wheezy
LINUXCNCVERSION: 2.7.1
gecko has 4 steppers connected, charge pump switch is off.
Gecko G540
hal & ini file for g540 = freeby.mesanet.com/g540.zip
sudo mesaflash --device 5i25 --readhmid, Configuration Name: HOSTMOT2, BoardName : MESA5I25
Errors:
Watchdog error; I figured out the watchdog error was related to version 2.7.1 so I commented it out.
then I get this error:
Found file(REL): ./hm2-g540-stepper.hal
./hm2-g540-stepper.hal:180: parameter or pin 'hm2_5i25.0.stepgen.04.control_type' not found
I read a thread about stepgen.04 being incorrect, so I changed all to stepgen.03. That didn't help.
Any thoughts on this error?
Is there a fileset like freeby.mesanet.com/g540.zip that works?
11 years 1 week ago #64216 by PCW
Replied by PCW on topic Getiing a 5i25 with g540 going
Have you flashed the 5I25 with g540 firmware?
11 years 1 week ago #64222 by cncbasher
why are you changing , what config are you looking for , something special etc ?
stepgen 4 is used for the chargepump , their is no stepgen 3
stepgens start at 0 x axis =0 y axis -1 z axis =2 etc
have you tried using pncconf to construct a config ?
11 years 1 week ago #64228 by blacksmith
PCW wrote: Have you flashed the 5I25 with g540 firmware?
Yes I did however if there is a way to verify the fact I would be happy to do so.
11 years 1 week ago #64229 by PCW
You can verify a pinout with this mesaflash command:
11 years 1 week ago #64231 by blacksmith
cncbasher wrote: why are you changing , what config are you looking for , something special etc ?
I changed the watchdog addf as that was my first error and the 2.7.1 release notes say that should be commented out.
The mesa site has the configuration files and I figured they were the definitive source as they made the board and should know how to write a config -> freeby.mesanet.com/g540.zip
The mesa site configuration files have the "stepgen.04" lines so I can only assume they were tested and guaranteed to work exactly as written. As a test I did change them from 04 to 03, which didn't make a difference.
Time to create page: 0.062 seconds
