5i25+7i77 clonezilla
10 years 10 months ago #66927 by bkt
5i25+7i77 clonezilla was created by bkt
A little question:
I have a fresh 5i25 fgpa and fresh 7i77 (never used and buy as new) ... I clone with filezilla a HDD for two identical pc. In the first my project run perfect. In the second one ... It seems That Analog outputs 1 and 4 do not work .... I have to perform a new installation or clone with clonezilla should work ?
I use ubuntu10.04 and LCNC2.7.1 (with JA9)....
Regards
Giorgio
10 years 10 months ago #66937 by PCW
Replied by PCW on topic 5i25+7i77 clonezilla
Its pretty difficult to get only partial analog outputs working on a 7I77 (except channel 5 which has a separate enable)
I would check that the hal/ini files are identical on the 2 machines
The following user(s) said Thank You: bkt
10 years 10 months ago #66977 by bkt
Replied by bkt on topic 5i25+7i77 clonezilla
today I have re-check the connection cable from drive to 7i77 .... for some reason these 2 cable not work .... i not understand why but the encoder cable from drive to mesa have It has some defect in filaments of copper .... probably they were crushed .... yesterday did not seem so ...
Regards
giorgio
10 years 10 months ago #67005 by bkt
#******************* # AXIS X #******************* setp pid.x.Pgain [JOINT_0]P setp pid.x.Igain [JOINT_0]I setp pid.x.Dgain [JOINT_0]D setp pid.x.bias [JOINT_0]BIAS setp pid.x.FF0 [JOINT_0]FF0 setp pid.x.FF1 [JOINT_0]FF1 setp pid.x.FF2 [JOINT_0]FF2 setp pid.x.deadband [JOINT_0]DEADBAND setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp pid.x.error-previous-target true #setp pid.x.maxerror .0005 #net x-index-enable <=> pid.x.index-enable --------commented net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [JOINT_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [JOINT_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [JOINT_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd joint.0.motor-pos-cmd net x-enable joint.0.amp-enable-out # enable _all_ sserial pwmgens net x-enable hm2_5i25.0.7i77.0.1.analogena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.00.counter-mode 0 setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [JOINT_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.00.position net x-vel-fb <= hm2_5i25.0.encoder.00.velocity net x-pos-fb => joint.0.motor-pos-fb #mux2.0.in0 #net x-index-enable joint.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable --------commented net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
I make a new cable but the issue is the same ... I try to chande 5i25 + LTP cable ieee + 7i77 with other tha worck for shure .... the issue is the same ... so is not a proble of cable or mesa card .....
I commented 2 row about index ... because in these config non cable and use encoder index. I have missing to make some other modification for run encoder without index??
10 years 10 months ago #67014 by PCW
Can you pinpoint the exact issue?
Is it an encoder problem?
You can check this by watching the raw encoder counts:
That is watching hm2_5i25.0.encoder.XX.rawcounts (XX being the encoder number)
while you rotate the motor shaft
10 years 10 months ago - 10 years 10 months ago #67018 by bkt
.... I ceck point to point the problem ... :evil: the analogue in of drive is definitevely fault ...... Yesterday run with some problem ... now not bring any input voltage ... :sick:
Any how ... my question is these:
misfortunes aside, my question was this : if you do not use the index signal coming from the drive , I can not connect it and add comment simbol in row with encoder signal as I make in these example or I must write some other command or comment?
#******************* # AXIS X #******************* setp pid.x.Pgain [JOINT_0]P setp pid.x.Igain [JOINT_0]I setp pid.x.Dgain [JOINT_0]D setp pid.x.bias [JOINT_0]BIAS setp pid.x.FF0 [JOINT_0]FF0 setp pid.x.FF1 [JOINT_0]FF1 setp pid.x.FF2 [JOINT_0]FF2 setp pid.x.deadband [JOINT_0]DEADBAND setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT setp pid.x.error-previous-target true #setp pid.x.maxerror .0005 #net x-index-enable <=> pid.x.index-enable [b]--------commented,... some other # or other command????[/b] net x-enable => pid.x.enable net x-pos-cmd => pid.x.command net x-vel-cmd => pid.x.command-deriv net x-pos-fb => pid.x.feedback net x-output => pid.x.output # ---PWM Generator signals/setup--- setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [JOINT_0]OUTPUT_SCALE setp hm2_5i25.0.7i77.0.1.analogout0-minlim [JOINT_0]OUTPUT_MIN_LIMIT setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [JOINT_0]OUTPUT_MAX_LIMIT net x-output => hm2_5i25.0.7i77.0.1.analogout0 net x-pos-cmd joint.0.motor-pos-cmd net x-enable joint.0.amp-enable-out # enable _all_ sserial pwmgens net x-enable hm2_5i25.0.7i77.0.1.analogena # ---Encoder feedback signals/setup--- setp hm2_5i25.0.encoder.00.counter-mode 0 setp hm2_5i25.0.encoder.00.filter 1 setp hm2_5i25.0.encoder.00.index-invert 0 setp hm2_5i25.0.encoder.00.index-mask 0 setp hm2_5i25.0.encoder.00.index-mask-invert 0 setp hm2_5i25.0.encoder.00.scale [JOINT_0]ENCODER_SCALE net x-pos-fb <= hm2_5i25.0.encoder.00.position net x-vel-fb <= hm2_5i25.0.encoder.00.velocity net x-pos-fb => joint.0.motor-pos-fb #mux2.0.in0 #net x-index-enable joint.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable [b]--------commented[/b] net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
And after clonezilla operation I must to do some other or I can simply star the pc as I just do?
Last edit: 10 years 10 months ago by bkt.
Time to create page: 0.063 seconds
