5i25+7i77 clonezilla
10 years 10 months ago #67020 by PCW
Replied by PCW on topic 5i25+7i77 clonezilla
The "#" should be fine to make comments out of active HAL lines (you may have to comment out multiple lines),
_but_ i don't think the index lines are harmful in any way even if left in the HAL file since unless you enable
homing on index or use spindle synchronized motion, the joint.X.index-enable pins will never be set
true so the index logic is never enabled.
The following user(s) said Thank You: bkt
Time to create page: 0.240 seconds
