Mesa 5i25 step by step configuration
10 years 10 months ago #67263 by Ozcnc
Aha,
I've just learnt something.
I have never looked at the card its a 6i25 with 7i77x2.bit loaded.
I have attached the mach 3 xml file but please have a look at the zero3 manual attached.
I would like to use the pins 14,15,16, and 17 as well.
I want to use the additional cable/bracket hardware kit connector for reading my encoders on a second port that I still need to fit.
Thanks allot.
Oz
10 years 10 months ago #67266 by PCW
The first step required is to reprogram the FPGA with the appropriate bitfile for the DMM BOB:
5i25_dmmbob1x2.bit
This is done with the mesaflash utility:
sudo mesaflash --device 5i25 --write 5i25_dmmbob1x2.bit
sudo mesaflash --device 5i25 --reload
then you can check the pinout with:
sudo mesaflash --device 5i25 --readhmid
if not there already, mesaflash is installed with
sudo apt-get install mesaflash
and 5i25_dmmbob1x2.bit is available in the 5i25.zip support file from Mesa
( in configs/hostmot2/ )
10 years 10 months ago #67283 by Ozcnc
Ok if flashed the card.
What's next.
Regards,
Oz
10 years 10 months ago #67292 by PCW
The next step is to make a hal/ini file suited to the 5I25 card/daughtercard
There are a couple of different ways to do this
one is to start with a close pncconf created file pair
( The DMM bob is not directly supported but the probrfx2 is quite close so a pncconf created file set
using the 5i25/probrfx2 template should be close enough to get started with )
The other way is to start with the hm2-stepper sample config (and ini file)
I dont think there is a 5i25.ini file sample but you can take a 5i20.ini sample and just change the
card and file names.
10 years 10 months ago #67294 by Ozcnc
I'll give it a go.
I'll let you know in a 12 hours.
Oz
10 years 10 months ago #67314 by Ozcnc
Nope no luck.
Time to create page: 0.292 seconds
