i installed a fresh 2.7.3 on a D945GCLF2 Mainboard together with a 5i20, 5i52s, 7i37TA, 7i37COM.
im working on 3axis stepper machine. i used the 5i52s to generat the 3 stepgens, and the 7i37com vor the limit switches.
pnccconf uses closed loop PIDs for my stepper setup! how can i force pnnconf to generat a open loop stepper setup?
some code from the ini file:
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 6000.0
STEPGEN_MAXVEL = 125.00
STEPGEN_MAXACCEL = 7500.00
P = 100.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 125.0
# these are in nanoseconds
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 2500
STEPSPACE = 2500
STEP_SCALE = 320.0
MIN_LIMIT = -200.0
MAX_LIMIT = 200.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -10.000000
HOME_LATCH_VEL = -0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
this is something from my other machine running with linuxcnc 2.5.4, generated with the older version of pncconf (same mesa cards)
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.005
MIN_FERROR = 0.0005
MAX_ACCELERATION = 500.0
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 2500
STEPSPACE = 2000
STEP_SCALE = 500.0
MIN_LIMIT = -10.0
MAX_LIMIT = 350.0
HOME_SEARCH_VEL = -8.316667
HOME_LATCH_VEL = 3.316667
HOME_FINAL_VEL = 1.666667
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
any idea?
My English is not the best, I hope you understand it anyway
thanks
Peter
