Stepper setup and pncconf
10 years 10 months ago #67548 by trilobyte
Replied by trilobyte on topic Stepper setup and pncconf
if i move the machine with the arrow key on the keyboard over a longer distance with fast speed (9000mm/min) the axis stops immediatley if i release the arrow key. but then the axis will move a little bit more with a very slow speed. distance is maybe 0.15mm. this takes 1-2 seconds.
is this ok?
would this be better if i change the P value from 100 to 1000?
10 years 10 months ago - 10 years 10 months ago #67552 by PCW
Replied by PCW on topic Stepper setup and pncconf
As I said P should be 1/servo period so 1000 at 1 ms servo thread period
Creeping after a fast move suggests some other bound setting is wrong
(insufficient velocity headroom somewhere for example)
Last edit: 10 years 10 months ago by PCW.
The following user(s) said Thank You: trilobyte
10 years 9 months ago #67664 by trilobyte
With P=1000 it works without creeping!
the machine is now working:
image missing http://www.trilobyte.ch/pix/gal/werkstatt/Laserplotter/DSC05667.JPG
max Velocity: 9000mm/min (150mm/s)
max acceleration: x axis 6m/s^2, y axis 3m/s^2
is it possible to edit pncconf in a way to be able to set the max velocity to 9000mm/min? the biggest value i can choose is 100 (mm/min)
is there another way as after every change with the pncconf to edit the ini file?
10 years 9 months ago #67669 by PCW
Once you have a working configuration , I would just
edit the INI and HAL files file directly and no longer use PNCCONF
Time to create page: 1.274 seconds
