Wiring connections for 7i43 and two 7i42TA boards
11 Feb 2016 05:38 #69975 by acondit
I generated a stepper lathe configuration using pncconf for a 7i43 based on SVST4-4.
Is there an easy way to figure out the wiring for connections from the 7i42TAs to the steppers and etc?
11 Feb 2016 12:44 #69990 by andypugh
When you start the config the pin allocations will be printed to dmesg.
So, start and exit LinuxCNC then type "dmesg" at a terminal, and look towards the bottom of the listing.
Then combine the info there with the info in the 7i42 manual.
The following user(s) said Thank You: acondit
11 Feb 2016 15:55 #69996 by acondit
Thanks Andy.
Time to create page: 0.511 seconds
