Help needed with Pendant Config
24 Mar 2016 13:08 #72087 by eman5oh
Help needed with Pendant Config was created by eman5oh
I am using a Mesa 5i25 with a 7i76 card for a Boss 5 retrofit and am trying to get everything configured, and am hung up at the moment on setting up my Pendant. I found I needed mode 2 for the serial to be able to config the encoder on TB5 16 and 17 and a estop on pin 25. The rest of the pins I am having trouble figuring out. I have as follows axis select x 18, y 19, z 20, A 21, 1x step 22, 10x step 23, 100x step 24. Any help with this would be appreciated. Thanks
29 Mar 2016 15:23 #72332 by andypugh
Replied by andypugh on topic Help needed with Pendant Config
Closed?
29 Mar 2016 15:34 #72334 by eman5oh
Replied by eman5oh on topic Help needed with Pendant Config
Yes closed, I have the config working as it should now pncconf was not setting mode two for the 7i76. Many thanks to all that helped out.
Time to create page: 0.269 seconds
