7i76 Spindle config
- eman5oh
- Thank you received: 11
29 Mar 2016 01:03 #72283
by eman5oh
7i76 Spindle config was created by eman5oh
I have a vfd controlled spindle and was wondering if it can be configured in pncconf. I see where to set the analog pot for TB4 but do not know what io corresponds to the spindle direction and enable pins on TB4.
- Thank you received: 4648
29 Mar 2016 16:00 #72341
Replied by andypugh on topic 7i76 Spindle config
Which pin is which rather depends on where you connect the wires.
- eman5oh
29 Mar 2016 19:07 - 29 Mar 2016 19:55 #72344
by eman5oh
Replied by eman5oh on topic 7i76 Spindle config
I have the wires connected to TB4 pins as follows
1 ->vfd analog gnd
2->vfd analog control
3->vfd +10 vdc analog supply
4 nc
5->vfd digital control common
6->vfd->Motor on/off
7->vfd digital control common
8->vfd fwd/rev
I see how to set the digital pot up in pncconf but do not see or know how to assign the spindle enable or direction so it will work with m3,m4,m5 codes.
1 ->vfd analog gnd
4 nc
8->vfd fwd/rev
Last edit: 29 Mar 2016 19:55 by eman5oh.
- eman5oh
30 Mar 2016 02:26 #72356
by eman5oh
I got it working by adding a custom panel with pncconf with a spindle meter on it, this is a work around I found that adds the proper hal pins to the config.
30 Mar 2016 09:13 #72370
You can probably manually delete the mete from the config and leave the pins if you want.
Time to create page: 0.097 seconds
