Motion Problem
10 years 5 months ago #74462
It is possible that that the "," is confusing the parts of the underlying Python code that calculates step scale.
manually editing the INI file is likely to be the best way to be sure, but you might also be able to change the number in the Test Axis dialog box. Just set it to 40.
Replied by andypugh on topic Motion Problem
ommar wrote: Yes, We use "," for a decimal place. What's your advise about this ?
10 years 5 months ago #74498
by ommar
Replied by ommar on topic Motion Problem
I set the step scale value for 40 step/mm. I set the max velocity value for 5000 mm/min and acceleration value for 200 mm/sn2 in the Pncconfig interface. Here my ini file ; Is this values correct ? And is the P means pitch ? I set pitch value for 5mm/rev but ini file 50 ???
# Generated by PNCconf at Wed May 11 14:47:58 2016
# overwritten when you run PNCconf again
[EMC]
MACHINE = çift_motor
DEBUG = 0
[DISPLAY]
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/egmach/linuxcnc/nc_files
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i25
[HAL]
HALUI = halui
HALFILE = çift_motor.hal
HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 10.00
MAX_LINEAR_VELOCITY = 100.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.05
MIN_FERROR = 0.05
MAX_VELOCITY = 100.0
MAX_ACCELERATION = 200.0
STEPGEN_MAXVEL = 125.00
STEPGEN_MAXACCEL = 250.00
P = 50.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP = 5000
DIRHOLD = 5000
STEPLEN = 1500
STEPSPACE = 1500
STEP_SCALE = 40.0
MIN_LIMIT = -0.01
MAX_LIMIT = 200000.0
HOME_OFFSET = 0.0
- Thank you received: 1480
10 years 5 months ago - 10 years 5 months ago #74505
Replied by Todd Zuercher on topic Motion Problem
No, P is part of the PID feedback loop, and I think it should be set to 1000 for your stepper setup (It should be calculated from your servo thread period). The only thing relating to the pitch of your screws in the ini file is the STEP_SCALE.
Last edit: 10 years 5 months ago by Todd Zuercher.
Time to create page: 0.153 seconds
