LinuxCNC Job CONTRACT - OFFER MEsaIO
- dewayne
9 years 5 months ago #93429
by dewayne
Replied by dewayne on topic LinuxCNC Job CONTRACT - OFFER MEsaIO
This is ther terminal Dump On Startup from the Command Line
DeWayne
DeWayne
- Thank you received: 4153
9 years 5 months ago #93431
Replied by rodw on topic LinuxCNC Job CONTRACT - OFFER MEsaIO
is home/jungle/.axisrc a custom file?
It does not seem to be in a standard LCNC location. It looks like in line 2 of that file, you are trying to split a string but the object is a tuple (a pair of values) not a string. I think it is an error of your doing, not a problem with LlnuxCNC.
9 years 5 months ago #93433
Looking at your error dump, you have also edited your files on a Windows machine and the line endings are wrong format. use dos2unix to convert your config files to Linux format. See
www.linuxcommand.org/man_pages/dos2unix1.html
See messages near the end of file for file names.
If you must edit on Windows download the free notepad++ text editor but it is better to do all editing on a Linux machine.
Clearly something wrong with font handling, but fix the obvious first.
- dewayne
9 years 5 months ago #93434
by dewayne
No custom file has been added as of yet. Install from SOurce compiled and edited the HAL and INI file that is all i have done thus far.
9 years 5 months ago #93438
Replied by andypugh on topic LinuxCNC Job CONTRACT - OFFER MEsaIO
It looks like you might have an (invisible) .axisrc file in your home folder.
ls -a
Will list all files, including invisible ones.
If the file exists, then rename it and try again. If it doesn't exist, something more interesting is going on.
ls -a
- Online
- Thank you received: 7491
9 years 5 months ago #93451
Replied by tommylight on topic LinuxCNC Job CONTRACT - OFFER MEsaIO
That is the error you get when you choose the "full screen" option in the pncconf. Deleting the .axisrc file should get rid of it, but you might need to run pncconf again, not choosing the full screen option this time and choosing to modify an existing config.
Time to create page: 0.541 seconds
