ligthmare wrote: Thank you so much! too easy....
So, I have no power supply on TB1 , CR1 CR3 CR6 and CR7 are yellow fix, CR16 is off and CR15 is blinking green at 1Hz when LinuxCNC is turning on.
I'm not shure but i have connected all the Vfield power and also Vin to the 12v on TB2, Can you confirm for Vin ?
bevins wrote: An example of power for Field power is attached:
Though possibly worth pointing out that that the actual limit-switch wiring there is a little unusual and should probably not be copied exactly.
