6i25 (5i25) + 7i85s + 7i85s PNCconf problems and questions
9 years 3 weeks ago - 9 years 3 weeks ago #100242 by Marcodi
I made a schematic of my connection. I am kind of scared to blow up the 7i85s or the 6i25.
Would this be a correct setup to start for one axis if in pncconf. as I/O connection 2 selected stepgen X axis on the 3rd dropdownbox?
Hope someone can review and let me know. Thx.
Stephane
Last edit: 9 years 3 weeks ago by Marcodi.
  • Ozzyrob
  • New Member
  • New Member
9 years 3 weeks ago #100247 by Ozzyrob
Do you have the 6i25 jumpers W7 & W8 set, as mention in the manual, for use with 5i25 bit files, if you are using 5i25 bit files ? (that's if this information is applicable)
Is the 6i25 jumpers set to supply power to the 7i85s ?
9 years 3 weeks ago - 9 years 3 weeks ago #100249 by Marcodi
Hi ozzyrob,
I have left all at default... (As they were on delivery) as I think those are the correct settings. The 5i25 is loaded with firmware 5i25_7i85sx2 the frequency is 33 . And mesaflash worked to flash as 5i25.
So I haven't touched the jumpers yet.
  • Ozzyrob
  • New Member
  • New Member
9 years 3 weeks ago #100250 by Ozzyrob
I'd be inclined to read the manual to make sure how the board is setup matches the way you want to use it. Always pays to check.
9 years 3 weeks ago #100253 by PCW
Also that seems like a confusing axis connection
Why would you not assign stepgens in the natural order:
X = Stepgen 0 = TX0,TX1
Y = Stepgen 1 = TX2,TX3
Z = Stepgen 2 = TX4,TX5
The following user(s) said Thank You: Marcodi
9 years 2 weeks ago #100258 by Marcodi
That's a good question. Because the first drop-down menu I choose X than Y than Z and that leads to Tx6 and 7. But I will change that. Makes more sense indeed.
How about my schematic for connecting the driver is that looking ok?
Time to create page: 0.377 seconds
