6i24-16 + 7i52S + 7i37
8 years 10 months ago #102901 by kohli-vie
Hello all,
i bought 6i24-16 + 7i52S + 7i37 and have now the biggest troubles (after days of search in google) :-(
since i dont have a bit-file, i install ISE design suite 14.7 and i think, i build a bit-file, which i can upload in the card.
but with pncconf, there is no way to setup the card.
i can not choose 6i24 or 5i24.
i try also the tip to use a 5i20 + predifend software. so i got the encoders and the steppers.
but the steppers on interface 3, which is worng
any ideas, where i can find a tutorial or a manual, how i must change which files, thet i can configure ist?
or where i can find the fitting files?
electronic greetings from Vienna/Austria
Andreas
8 years 10 months ago #102904 by PCW
Replied by PCW on topic 6i24-16 + 7i52S + 7i37
I dont think pncconf can help much here except making a basic hal file which will then have
to be hand edited
The stepgen/encoder setup in the hal file should be correct except for
stepgen polarity options (they would be on the wrong GPIO pins)
8 years 10 months ago #102905 by kohli-vie
Replied by kohli-vie on topic 6i24-16 + 7i52S + 7i37
PCW wrote: I dont think pncconf can help much here except making a basic hal file
but if i understand linuxCNC and the tools around it correct, pncconf is the only way to make a good setup for the timing for the stepper motors (acceleration and max speed and ....?
8 years 10 months ago - 8 years 10 months ago #102909 by PCW
Not at all, you will almost always have to hand edit hal files to get final details right / added features you need
Also, the stepper settings (with the exception of polarity settings) created by pncconf will work on _any_
firmware (you just need to know where stepgen 0,1,2,3 etc connect on your hardware)
Last edit: 8 years 10 months ago by PCW.
8 years 10 months ago #103073 by andypugh
Replied by andypugh on topic 6i24-16 + 7i52S + 7i37
It seems odd that there is no firmware for the 6i24, but the link on mesanet goes nowhere
www.mesanet.com/software/parallel/6i24.zip
However you can almost certainly use the 5i24 firmware.
www.mesanet.com/software/parallel/5i24.zip
In fact, I am using a 6i24 so firmware must exist ;-)
8 years 9 months ago #105112 by lamandesigns
Replied by lamandesigns on topic 6i24-16 + 7i52S + 7i37
What is the firmware version on the bag of the 6i24 you got? I can see if I have an XML and bit file for it so you can put it in the hm2 folder to use the pncconf.
Time to create page: 0.319 seconds
