Interface between Mesa 7i77 and Granite Devices VSD-E servo amplifier
8 years 10 months ago #103229 by PCW
You cannot separate the output voltage from the input threshold on a 7I77
I suspect the easiest way to sense 5V is what Andy suggested, use the analog inputs for 5V sensing
and run the outputs at 24V for your relays
We do have some experimental firmware for the 7I84 which could be ported to the 7I77
that separates the input thresholds from the output voltage by making the input thresholds
settable from LinuxCNC but we don't have a time frame for porting this yet
8 years 10 months ago - 8 years 10 months ago #103238 by DeckelHead
Good thing I ran out of time and hadn't started to research the separating input from output thing.
The analog input idea is something I was never even aware I could do. I glossed over that part of the manual because it (at the time) didn't seem relevant to what I was trying to accomplish. As I really only need 3 inputs, I am happy to dedicate IN0, IN1, IN2 to my X, Y and Z fault inbound lines (7i77 perspective). If I'm reading it all correctly, I would want Mode 3 because I do want to have an MPG on my control panel. I don't quite know what "field voltage analog in" means in the context of the manual's description though. Mode 2, 3 spells that out explicitly...
Somewhere in the system (HAL or LinuxCNC configuration), the 5V value from the servo drive will how to be converted to a TRUE or FALSE. I don't quite know where that is accomplished yet but it seems reasonable to assume that such an ability exists....
Your comments on the MPG have made me question whether or not I have a looming problem there though... If I have a 24V field, is that going to be a problem for me? I'm guess not, but confirmation is always a good thing
Last edit: 8 years 10 months ago by DeckelHead. Reason: added info about usage of an MPG
8 years 10 months ago - 8 years 10 months ago #103249 by andypugh
DeckelHead wrote: Somewhere in the system (HAL or LinuxCNC configuration), the 5V value from the servo drive will how to be converted to a TRUE or FALSE. I don't quite know where that is accomplished yet but it seems reasonable to assume that such an ability exists....
Yes, you would use something like
loadrt comp count=3 ... addf comp.0 servo-thread addf comp.1 servo-thread addf comp.2 servo-thread ... net fault-0-analog hm2_5i25.0.7i77.0.0.analog0 => comp.0.in0 setp comp.0 in1 2.5 setp comp.0.hyst 0.25 net fault-0 comp.0.out => axis.0.amp-fault-in ...
linuxcnc.org/docs/2.7/html/man/man9/comp.9.html
linuxcnc.org/docs/2.7/html/man/man9/motion.9.html
You can power the MPG from the encoder 5V (or any other 5V sharing the same GND)
Last edit: 8 years 10 months ago by andypugh.
8 years 10 months ago #103252 by DeckelHead
Awesome...
Thank you both for all of the help. I have some reading, tinkering, and additional wiring to complete now, but I think I'm well on my way to having a viable solution.
Best regards and happy holidays,
Alan
8 years 9 months ago #103986 by emcPT
I have a documented implementation of a 7i77 with a Granite servo drive.
wiki.eusurplus.com/
The following user(s) said Thank You: DeckelHead
8 years 9 months ago #103996 by DeckelHead
Fantastic! Thank you emcPT. I'm pretty close to being done with my conversion, but there are a few areas that still need to be tidy'd up and such. I was good about drawing schematics and once everything is up and running, I'll document things here as well. I like your approach of using a Wiki. I hadn't really considered that, but as I perused everything very briefly, I think I may follow suit.
I'll be going through all of your site over the next few days. I may have some questions for you and I'm hopeful that this is OK with you. Either way, however, I am very appreciative that you have take the time to send me the link to conversion.
Best regards,
Alan
Time to create page: 0.206 seconds
