Mesa 5i25 PCI Issue sporadically need #Help#
- Chriscore
- Topic Author
8 years 9 months ago #104007
by Chriscore
Mesa 5i25 PCI Issue sporadically need #Help# was created by Chriscore
Hi Guys,
i am new in this Group.
I hope u can help me out. i converted a Manual Mill to CNC and run it quite a while no faults or problems until last week.
Standard 5i25 /7i76 Config.
When i started Linux CNC it shows me " no mesa found.." so i typed in mesa flash and it shows me that theres a card in but no config.
-> empty FPGA ?!
After that i unplugged plugged back -> started EMC -> worked until yesterday.
Yesterday was the same and i repeated everything and worked good, i run a cycle and in the middle of it serial errors and stuff popped up and no communication was given, after that the machine stopped. There are no lights on the 5i25 and the Cable is good.
Is it more a PC Problem or a Card Issue?!?
Thx for help!!!
Chris
-> empty FPGA ?!
Thx for help!!!
Chris
- Thank you received: 2181
8 years 9 months ago #104008
Replied by cmorley on topic Mesa 5i25 PCI Issue sporadically need #Help#
Got a spare power supply? some of the mesa cards are sensitive to low power.
i had a system that ran put the card didn't work properly. on suggestion I changed the power supply and that was the issue.
If you have a spare - easy check.
Chris M
Chris M
- Chriscore
- Topic Author
8 years 9 months ago #104009
by Chriscore
Replied by Chriscore on topic Mesa 5i25 PCI Issue sporadically need #Help#
Thx, that could be possibly.
for field power i got a industrial 24v power supply.
do u mean the computer spare power supply??
8 years 9 months ago #104010
Computer.
Field power can influence missing pins on launch (field power is required for the pins to be made).
Chris M
Chris M
- Chriscore
- Topic Author
8 years 9 months ago #104011
by Chriscore
ok - yes this is an old dell i guess it has a spare power supply .. what is better ?.. what to look for ?
maybe i upgrade the pc to a NUC or something...
regards chris
regards chris
8 years 9 months ago #104012
I would just temporarily swap out the power supply if you have one handy just to see if that helps.
It could be many other things.
Chris M
Chris M
- Chriscore
- Topic Author
8 years 9 months ago #104013
by Chriscore
ok thx i do. i post the dmsg next time
- Chriscore
- Topic Author
8 years 9 months ago #104019
by Chriscore
this is what ive got
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.11
Machine configuration directory is '/home/christoph/linuxcnc/configs/MAS_Fraese'
Machine configuration file is 'MAS_Fraese.ini'
INIFILE=/home/christoph/linuxcnc/configs/MAS_Fraese/MAS_Fraese.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./MAS_Fraese.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3478
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: Invalid parameters
./MAS_Fraese.hal:8: exit value: 1
./MAS_Fraese.hal:8: insmod for hm2_pci failed, returned -1
See the output of 'dmesg' for more information.
3478
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 00000000000a0000 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000003ff74000 (usable)
[ 0.000000] BIOS-e820: 000000003ff74000 - 000000003ff76000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000003ff76000 - 000000003ff97000 (ACPI data)
[ 0.000000] BIOS-e820: 000000003ff97000 - 0000000040000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved)
[ 0.000000] BIOS-e820: 00000000fecf0000 - 00000000fecf1000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000fed90000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee10000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Computer Corporation Precision WorkStation 360 /0H1639, BIOS A01 04/28/2003
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x3ff74 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C3FFF write-protect
[ 0.000000] C4000-C7FFF uncachable
[ 0.000000] C8000-CBFFF write-protect
[ 0.000000] CC000-CFFFF uncachable
[ 0.000000] D0000-D3FFF write-protect
[ 0.000000] D4000-D7FFF uncachable
[ 0.000000] D8000-DBFFF write-protect
[ 0.000000] DC000-DFFFF uncachable
[ 0.000000] E0000-E3FFF write-protect
[ 0.000000] E4000-E7FFF uncachable
[ 0.000000] E8000-EBFFF write-protect
[ 0.000000] EC000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FC0000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 3652a000 - 3728d000
[ 0.000000] ACPI: RSDP 000feb90 00014 (v00 DELL )
[ 0.000000] ACPI: RSDT 000fd163 00038 (v01 DELL WS 360 00000006 ASL 00000061)
[ 0.000000] ACPI: FACP 000fd19b 00074 (v01 DELL WS 360 00000006 ASL 00000061)
[ 0.000000] ACPI: DSDT fffc5e3c 026B6 (v01 DELL dt_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 3ff74000 00040
[ 0.000000] ACPI: SSDT fffc862f 000BA (v01 DELL st_ex 00001000 MSFT 0100000D)
[ 0.000000] ACPI: APIC 000fd20f 0006C (v01 DELL WS 360 00000006 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd27b 00028 (v01 DELL WS 360 00000006 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fd2a3 00067 (v16 DELL WS 360 00000006 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 135MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0003ff74
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x000000a0
[ 0.000000] 0: 0x00000100 -> 0x0003ff74
[ 0.000000] On node 0 totalpages: 261892
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5d2a200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3952 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 271 pages used for memmap
[ 0.000000] HighMem zone: 34407 pages, LIFO batch:7
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] disabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 3 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:bec00000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77b2000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259845
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=f2bc9cc3-aea5-4fa4-8c17-23bced7a80f7 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2095904 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0003ff74)
[ 0.000000] Memory: 1016652k/1048016k available (3495k kernel code, 30916k reserved, 1237k data, 416k init, 138712k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f5808000 soft=f580a000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2394.065 MHz processor.
[ 0.004004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4788.13 BogoMIPS (lpj=9576260)
[ 0.004012] pid_max: default: 32768 minimum: 301
[ 0.004096] Security Framework initialized
[ 0.004104] AppArmor: AppArmor disabled by boot time parameter
[ 0.004140] Mount-cache hash table entries: 512
[ 0.004470] Initializing cgroup subsys cpuacct
[ 0.004476] Initializing cgroup subsys memory
[ 0.004492] Initializing cgroup subsys devices
[ 0.004497] Initializing cgroup subsys freezer
[ 0.004501] Initializing cgroup subsys net_cls
[ 0.004504] Initializing cgroup subsys blkio
[ 0.004517] Initializing cgroup subsys perf_event
[ 0.004567] CPU0: Hyper-Threading is disabled
[ 0.004572] mce: CPU supports 4 MCE banks
[ 0.004585] CPU0: Thermal monitoring enabled (TM1)
[ 0.004665] SMP alternatives: switching to UP code
[ 0.012015] ACPI: Core revision 20120320
[ 0.038050] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.038400] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.078097] CPU0: Intel(R) Pentium(R) 4 CPU 2.40GHz stepping 09
[ 0.080004] Performance Events: Netburst events, Netburst P4/Xeon PMU driver.
[ 0.080004] ... version: 0
[ 0.080004] ... bit width: 40
[ 0.080004] ... generic registers: 18
[ 0.080004] ... value mask: 000000ffffffffff
[ 0.080004] ... max period: 0000007fffffffff
[ 0.080004] ... fixed-purpose events: 0
[ 0.080004] ... event mask: 000000000003ffff
[ 0.088036] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.088095] Brought up 1 CPUs
[ 0.088101] Total of 1 processors activated (4788.13 BogoMIPS).
[ 0.088618] devtmpfs: initialized
[ 0.089046] PM: Registering ACPI NVS region [mem 0x3ff74000-0x3ff75fff] (8192 bytes)
[ 0.089221] dummy:
[ 0.089318] NET: Registered protocol family 16
[ 0.089535] ACPI: bus type pci registered
[ 0.090537] PCI: PCI BIOS revision 2.10 entry at 0xfba8a, last bus=2
[ 0.090541] PCI: Using configuration type 1 for base access
[ 0.091643] bio: create slab <bio-0> at 0
[ 0.091803] ACPI: Added _OSI(Module Device)
[ 0.091809] ACPI: Added _OSI(Processor Device)
[ 0.091813] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.091818] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.092940] ACPI: EC: Look up EC in DSDT
[ 0.114423] ACPI: Interpreter enabled
[ 0.114446] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.114510] ACPI: Using IOAPIC for interrupt routing
[ 0.148341] ACPI: No dock devices found.
[ 0.148354] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.149908] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.152901] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.152907] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.152912] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.152917] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xfebfffff] (ignored)
[ 0.152922] PCI: root bus 00: using default resources
[ 0.152992] PCI host bridge to bus 0000:00
[ 0.152999] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.153004] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.153025] pci 0000:00:00.0: [8086:2578] type 00 class 0x060000
[ 0.153032] pci 0000:00:00.0: Enabling MCH 'Overflow' Device
[ 0.153045] pci 0000:00:00.0: reg 10: [mem 0xe8000000-0xefffffff pref]
[ 0.153119] pci 0000:00:01.0: [8086:2579] type 01 class 0x060400
[ 0.153169] pci 0000:00:06.0: [8086:257e] type 00 class 0x088000
[ 0.153183] pci 0000:00:06.0: reg 10: [mem 0xfecf0000-0xfecf0fff]
[ 0.153281] pci 0000:00:1d.0: [8086:24d2] type 00 class 0x0c0300
[ 0.153337] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.153380] pci 0000:00:1d.1: [8086:24d4] type 00 class 0x0c0300
[ 0.153436] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.153482] pci 0000:00:1d.2: [8086:24d7] type 00 class 0x0c0300
[ 0.153538] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.153581] pci 0000:00:1d.3: [8086:24de] type 00 class 0x0c0300
[ 0.153637] pci 0000:00:1d.3: reg 20: [io 0xff20-0xff3f]
[ 0.153694] pci 0000:00:1d.7: [8086:24dd] type 00 class 0x0c0320
[ 0.153723] pci 0000:00:1d.7: reg 10: [mem 0xffa80800-0xffa80bff]
[ 0.153822] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.153849] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060400
[ 0.153905] pci 0000:00:1f.0: [8086:24d0] type 00 class 0x060100
[ 0.153982] pci 0000:00:1f.0: HPET at 0xfed00000
[ 0.154008] pci 0000:00:1f.1: [8086:24db] type 00 class 0x01018a
[ 0.154027] pci 0000:00:1f.1: reg 10: [io 0x01f0-0x01f7]
[ 0.154041] pci 0000:00:1f.1: reg 14: [io 0x03f4-0x03f7]
[ 0.154055] pci 0000:00:1f.1: reg 18: [io 0x0170-0x0177]
[ 0.154068] pci 0000:00:1f.1: reg 1c: [io 0x0374-0x0377]
[ 0.154082] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.154096] pci 0000:00:1f.1: reg 24: [mem 0xfebffc00-0xfebfffff]
[ 0.154133] pci 0000:00:1f.2: [8086:24d1] type 00 class 0x01018f
[ 0.154151] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.154163] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.154176] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.154188] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.154200] pci 0000:00:1f.2: reg 20: [io 0xfea0-0xfeaf]
[ 0.154240] pci 0000:00:1f.3: [8086:24d3] type 00 class 0x0c0500
[ 0.154295] pci 0000:00:1f.3: reg 20: [io 0xeda0-0xedbf]
[ 0.154346] pci 0000:00:1f.5: [8086:24d5] type 00 class 0x040100
[ 0.154367] pci 0000:00:1f.5: reg 10: [io 0xee00-0xeeff]
[ 0.154380] pci 0000:00:1f.5: reg 14: [io 0xedc0-0xedff]
[ 0.154395] pci 0000:00:1f.5: reg 18: [mem 0xfebffa00-0xfebffbff]
[ 0.154410] pci 0000:00:1f.5: reg 1c: [mem 0xfebff900-0xfebff9ff]
[ 0.154460] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold
[ 0.154499] pci 0000:01:00.0: [10de:032b] type 00 class 0x030000
[ 0.154520] pci 0000:01:00.0: reg 10: [mem 0xfd000000-0xfdffffff]
[ 0.154532] pci 0000:01:00.0: reg 14: [mem 0xf0000000-0xf7ffffff pref]
[ 0.154572] pci 0000:01:00.0: reg 30: [mem 0xfea00000-0xfea1ffff pref]
[ 0.154638] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.154647] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfeafffff]
[ 0.154655] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf7ffffff pref]
[ 0.154690] pci 0000:02:03.0: [2718:5125] type 00 class 0x110000
[ 0.154708] pci 0000:02:03.0: reg 10: [mem 0xfcfd0000-0xfcfdffff]
[ 0.154802] pci 0000:02:0c.0: [8086:100e] type 00 class 0x020000
[ 0.154826] pci 0000:02:0c.0: reg 10: [mem 0xfcfe0000-0xfcffffff]
[ 0.154848] pci 0000:02:0c.0: reg 18: [io 0xdf40-0xdf7f]
[ 0.154915] pci 0000:02:0c.0: PME# supported from D0 D3hot D3cold
[ 0.154959] pci 0000:00:1e.0: PCI bridge to [bus 02-02] (subtractive decode)
[ 0.154966] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.154973] pci 0000:00:1e.0: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.154981] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.154986] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.155002] pci_bus 0000:00: on NUMA node 0
[ 0.155009] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.155644] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.156466] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.277916] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.278308] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.278692] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.279077] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.279455] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.279838] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.280234] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 0.280622] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.280849] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.280857] vgaarb: loaded
[ 0.280860] vgaarb: bridge control possible 0000:01:00.0
[ 0.280914] PCI: Using ACPI for IRQ routing
[ 0.280921] PCI: pci_cache_line_size set to 64 bytes
[ 0.281017] reserve RAM buffer: 000000003ff74000 - 000000003fffffff
[ 0.281355] hpet clockevent registered
[ 0.281363] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.281375] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.283399] Switching to clocksource hpet
[ 0.283496] pnp: PnP ACPI init
[ 0.283520] ACPI: bus type pnp registered
[ 0.283820] pnp 00:00: [mem 0x00000000-0x0009ffff]
[ 0.283826] pnp 00:00: [mem 0x00100000-0x00ffffff]
[ 0.283831] pnp 00:00: [mem 0x01000000-0x3ff73fff]
[ 0.283836] pnp 00:00: [mem 0x000c0000-0x000fffff]
[ 0.283840] pnp 00:00: [mem 0xfec00000-0xfec0ffff]
[ 0.283844] pnp 00:00: [mem 0xfee00000-0xfee0ffff]
[ 0.283849] pnp 00:00: [mem 0xfed20000-0xfed8ffff]
[ 0.283853] pnp 00:00: [mem 0xfecf0000-0xfecf0fff]
[ 0.283857] pnp 00:00: [mem 0xffb00000-0xffbfffff]
[ 0.283861] pnp 00:00: [mem 0xffc00000-0xffffffff]
[ 0.283939] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.283947] system 00:00: [mem 0x00100000-0x00ffffff] could not be reserved
[ 0.283954] system 00:00: [mem 0x01000000-0x3ff73fff] could not be reserved
[ 0.283960] system 00:00: [mem 0x000c0000-0x000fffff] could not be reserved
[ 0.283966] system 00:00: [mem 0xfec00000-0xfec0ffff] could not be reserved
[ 0.283971] system 00:00: [mem 0xfee00000-0xfee0ffff] has been reserved
[ 0.283976] system 00:00: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.283982] system 00:00: [mem 0xfecf0000-0xfecf0fff] has been reserved
[ 0.283987] system 00:00: [mem 0xffb00000-0xffbfffff] has been reserved
[ 0.283992] system 00:00: [mem 0xffc00000-0xffffffff] has been reserved
[ 0.284017] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.285558] pnp 00:01: [bus 00-ff]
[ 0.285564] pnp 00:01: [io 0x0cf8-0x0cff]
[ 0.285569] pnp 00:01: [io 0x0000-0x0cf7 window]
[ 0.285573] pnp 00:01: [io 0x0d00-0xffff window]
[ 0.285578] pnp 00:01: [mem 0x000a0000-0x000bffff window]
[ 0.285582] pnp 00:01: [mem 0x80000000-0xfebfffff window]
[ 0.285640] pnp 00:01: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.288633] pnp 00:02: [io 0x0080-0x009f]
[ 0.288638] pnp 00:02: [io 0x0000-0x001f]
[ 0.288643] pnp 00:02: [io 0x00c0-0x00df]
[ 0.288649] pnp 00:02: [dma 4]
[ 0.288696] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.288808] pnp 00:03: [io 0x00f0-0x00ff]
[ 0.288823] pnp 00:03: [irq 13]
[ 0.288868] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.288979] pnp 00:04: [io 0x0061]
[ 0.289026] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.289136] pnp 00:05: [io 0x0070-0x007f]
[ 0.289146] pnp 00:05: [irq 8]
[ 0.289195] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.292210] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.292216] pnp 00:06: [io 0x03f7]
[ 0.292228] pnp 00:06: [irq 6]
[ 0.292234] pnp 00:06: [dma 2]
[ 0.292499] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.297093] pnp 00:07: [io 0x03f8-0x03ff]
[ 0.297103] pnp 00:07: [irq 4]
[ 0.297336] pnp 00:07: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.299655] pnp 00:08: [io 0x02f8-0x02ff]
[ 0.299665] pnp 00:08: [irq 3]
[ 0.299889] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.303328] pnp 00:09: [io 0x0378-0x037f]
[ 0.303334] pnp 00:09: [io 0x0778-0x077f]
[ 0.303343] pnp 00:09: [irq 7]
[ 0.303348] pnp 00:09: [dma 0 disabled]
[ 0.303896] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.305564] pnp 00:0a: [io 0x0060]
[ 0.305570] pnp 00:0a: [io 0x0064]
[ 0.305574] pnp 00:0a: [io 0x0062-0x0063]
[ 0.305579] pnp 00:0a: [io 0x0065-0x006f]
[ 0.305583] pnp 00:0a: [io 0x00e0-0x00ef]
[ 0.305587] pnp 00:0a: [io 0x0800-0x085f]
[ 0.305591] pnp 00:0a: [io 0x0c00-0x0c7f]
[ 0.305595] pnp 00:0a: [io 0x0860-0x08ff]
[ 0.305679] system 00:0a: [io 0x0800-0x085f] has been reserved
[ 0.305688] system 00:0a: [io 0x0c00-0x0c7f] has been reserved
[ 0.305694] system 00:0a: [io 0x0860-0x08ff] has been reserved
[ 0.305700] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.306588] pnp: PnP ACPI: found 11 devices
[ 0.306593] ACPI: ACPI bus type pnp unregistered
[ 0.306599] PnPBIOS: Disabled by ACPI PNP
[ 0.344269] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.344280] pci 0000:00:01.0: bridge window [mem 0xfd000000-0xfeafffff]
[ 0.344287] pci 0000:00:01.0: bridge window [mem 0xf0000000-0xf7ffffff pref]
[ 0.344297] pci 0000:00:1e.0: PCI bridge to [bus 02-02]
[ 0.344303] pci 0000:00:1e.0: bridge window [io 0xd000-0xdfff]
[ 0.344311] pci 0000:00:1e.0: bridge window [mem 0xfcf00000-0xfcffffff]
[ 0.344339] pci 0000:00:1e.0: setting latency timer to 64
[ 0.344347] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.344351] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.344357] pci_bus 0000:01: resource 1 [mem 0xfd000000-0xfeafffff]
[ 0.344361] pci_bus 0000:01: resource 2 [mem 0xf0000000-0xf7ffffff pref]
[ 0.344366] pci_bus 0000:02: resource 0 [io 0xd000-0xdfff]
[ 0.344371] pci_bus 0000:02: resource 1 [mem 0xfcf00000-0xfcffffff]
[ 0.344375] pci_bus 0000:02: resource 4 [io 0x0000-0xffff]
[ 0.344380] pci_bus 0000:02: resource 5 [mem 0x00000000-0xffffffff]
[ 0.344484] NET: Registered protocol family 2
[ 0.344591] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.344890] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.345455] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.345926] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.345931] TCP: reno registered
[ 0.345940] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.345954] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.346120] NET: Registered protocol family 1
[ 0.346355] pci 0000:01:00.0: Boot video device
[ 0.346369] PCI: CLS 64 bytes, default 64
[ 0.346460] Unpacking initramfs...
[ 0.795691] Freeing initrd memory: 13708k freed
[ 0.807108] Simple Boot Flag value 0x87 read from CMOS RAM was invalid
[ 0.807114] Simple Boot Flag at 0x7a set to 0x1
[ 0.807654] audit: initializing netlink socket (disabled)
[ 0.807684] type=2000 audit(1515072200.800:1): initialized
[ 0.822165] highmem bounce pool size: 64 pages
[ 0.822176] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.822404] VFS: Disk quotas dquot_6.5.2
[ 0.822446] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.822562] msgmni has been set to 1741
[ 0.822825] alg: No test for stdrng (krng)
[ 0.822873] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.822879] io scheduler noop registered
[ 0.822882] io scheduler deadline registered
[ 0.822908] io scheduler cfq registered (default)
[ 0.823064] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.823097] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.823101] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.823519] GHES: HEST is not enabled!
[ 0.823541] isapnp: Scanning for PnP cards...
[ 1.177546] isapnp: No Plug & Play device found
[ 1.177623] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.197955] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.218301] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.238945] 00:07: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.259355] 00:08: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.259564] Linux agpgart interface v0.103
[ 1.259773] agpgart-intel 0000:00:00.0: Intel i875 Chipset
[ 1.264882] agpgart-intel 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 1.265091] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 1.268326] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.268385] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.268536] mousedev: PS/2 mouse device common for all mice
[ 1.268626] rtc_cmos 00:05: RTC can wake from S4
[ 1.268771] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.268800] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.268978] TCP: cubic registered
[ 1.269049] NET: Registered protocol family 10
[ 1.269383] Mobile IPv6
[ 1.269389] NET: Registered protocol family 17
[ 1.269397] Registering the dns_resolver key type
[ 1.269477] Using IPI No-Shortcut mode
[ 1.269636] PM: Hibernation image not present or could not be loaded.
[ 1.269664] registered taskstats version 1
[ 1.270053] rtc_cmos 00:05: setting system clock to 2018-01-04 13:23:21 UTC (1515072201)
[ 1.270194] Freeing unused kernel memory: 416k freed
[ 1.270560] Write protecting the kernel text: 3496k
[ 1.270591] Write protecting the kernel read-only data: 984k
[ 1.300403] udevd[45]: starting version 175
[ 1.370532] usbcore: registered new interface driver usbfs
[ 1.370574] usbcore: registered new interface driver hub
[ 1.417419] usbcore: registered new device driver usb
[ 1.449984] Floppy drive(s): fd0 is 1.44M
[ 1.450829] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.450916] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.450923] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.450962] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.451002] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.454154] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.454906] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.454942] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xffa80800
[ 1.457047] SCSI subsystem initialized
[ 1.464142] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.464225] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.464231] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.464235] usb usb1: Product: EHCI Host Controller
[ 1.464239] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.464243] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.466178] FDC 0 is a post-1991 82077
[ 1.467452] hub 1-0:1.0: USB hub found
[ 1.467464] hub 1-0:1.0: 8 ports detected
[ 1.467691] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.467698] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.467714] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.467767] uhci_hcd 0000:00:1d.0: irq 16, io base 0x0000ff80
[ 1.467827] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.467833] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.467837] usb usb2: Product: UHCI Host Controller
[ 1.467840] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.467844] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.468061] hub 2-0:1.0: USB hub found
[ 1.468072] hub 2-0:1.0: 2 ports detected
[ 1.468223] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.468230] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.468244] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.468287] uhci_hcd 0000:00:1d.1: irq 19, io base 0x0000ff60
[ 1.468342] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.468348] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.468352] usb usb3: Product: UHCI Host Controller
[ 1.468356] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.468360] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.468537] hub 3-0:1.0: USB hub found
[ 1.468547] hub 3-0:1.0: 2 ports detected
[ 1.470956] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.470964] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.470988] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.471045] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.471109] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.471114] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.471118] usb usb4: Product: UHCI Host Controller
[ 1.471122] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.471126] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.471336] hub 4-0:1.0: USB hub found
[ 1.471350] hub 4-0:1.0: 2 ports detected
[ 1.479025] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.479034] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.479052] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.479085] uhci_hcd 0000:00:1d.3: irq 16, io base 0x0000ff20
[ 1.479152] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.479157] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.479162] usb usb5: Product: UHCI Host Controller
[ 1.479165] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.479169] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.479364] hub 5-0:1.0: USB hub found
[ 1.479375] hub 5-0:1.0: 2 ports detected
[ 1.483005] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 1.483011] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.491307] microcode: CPU0 sig=0xf29, pf=0x4, revision=0x11
[ 1.493037] libata version 3.00 loaded.
[ 1.493359] ata_piix 0000:00:1f.1: version 2.13
[ 1.493436] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.497716] scsi0 : ata_piix
[ 1.501157] scsi1 : ata_piix
[ 1.501260] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.501266] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.501482] ata_piix 0000:00:1f.2: MAP [ P0 -- P1 -- ]
[ 1.501547] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.504974] scsi2 : ata_piix
[ 1.507912] scsi3 : ata_piix
[ 1.508069] ata3: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfea0 irq 18
[ 1.508075] ata4: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfea8 irq 18
[ 1.595134] microcode: CPU0 updated to revision 0x2e, date = 2004-08-11
[ 1.595624] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.670085] ata1.00: HPA detected: current 234375000, native 234441648
[ 1.670095] ata1.00: ATA-5: WDC WD1200JB-75CRA0, 16.06V16, max UDMA/100
[ 1.670100] ata1.00: 234375000 sectors, multi 8: LBA
[ 1.670873] ata2.00: ATAPI: SAMSUNG DVD-ROM SD-616T, F310, max UDMA/33
[ 1.670882] ata2.01: ATAPI: HL-DT-ST GCE-8481B, C102, max UDMA/33
[ 1.678737] ata2.00: configured for UDMA/33
[ 1.690148] ata1.00: configured for UDMA/100
[ 1.693954] ata2.01: configured for UDMA/33
[ 1.705157] scsi 0:0:0:0: Direct-Access ATA WDC WD1200JB-75C 16.0 PQ: 0 ANSI: 5
[ 1.717006] scsi 1:0:0:0: CD-ROM SAMSUNG DVD-ROM SD-616T F310 PQ: 0 ANSI: 5
[ 1.717511] scsi 1:0:1:0: CD-ROM HL-DT-ST CD-RW GCE-8481B C102 PQ: 0 ANSI: 5
[ 1.776434] usb 1-3: new high-speed USB device number 2 using ehci_hcd
[ 1.816533] Refined TSC clocksource calibration: 2393.999 MHz.
[ 1.816542] Switching to clocksource tsc
[ 1.861917] e1000 0000:02:0c.0: eth0: (PCI:33MHz:32-bit) 00:07:e9:4c:92:ec
[ 1.861938] e1000 0000:02:0c.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.912679] usb 1-3: New USB device found, idVendor=1a40, idProduct=0101
[ 1.912687] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.912691] usb 1-3: Product: USB 2.0 Hub
[ 1.912982] hub 1-3:1.0: USB hub found
[ 1.913050] hub 1-3:1.0: 4 ports detected
[ 2.024032] usb 1-4: new high-speed USB device number 3 using ehci_hcd
[ 2.156638] usb 1-4: New USB device found, idVendor=1a40, idProduct=0101
[ 2.156644] usb 1-4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.156648] usb 1-4: Product: USB 2.0 Hub
[ 2.156942] hub 1-4:1.0: USB hub found
[ 2.157008] hub 1-4:1.0: 4 ports detected
[ 2.244127] usb 1-3.4: new low-speed USB device number 4 using ehci_hcd
[ 2.358104] usb 1-3.4: New USB device found, idVendor=413c, idProduct=2003
[ 2.358110] usb 1-3.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.358115] usb 1-3.4: Product: Dell USB Keyboard
[ 2.358119] usb 1-3.4: Manufacturer: Dell
[ 2.444098] usb 1-4.4: new low-speed USB device number 5 using ehci_hcd
[ 2.557695] usb 1-4.4: New USB device found, idVendor=0c45, idProduct=0520
[ 2.557701] usb 1-4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.557706] usb 1-4.4: Product: USB Device
[ 2.557710] usb 1-4.4: Manufacturer: SONiX
[ 2.570888] input: Dell Dell USB Keyboard as /devices/pci0000:00/0000:00:1d.7/usb1/1-3/1-3.4/1-3.4:1.0/input/input0
[ 2.571061] generic-usb 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-0000:00:1d.7-3.4/input0
[ 2.575624] input: SONiX USB Device as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4.4/1-4.4:1.0/input/input1
[ 2.576794] generic-usb 0003:0C45:0520.0002: input,hidraw1: USB HID v1.00 Keyboard [SONiX USB Device] on usb-0000:00:1d.7-4.4/input0
[ 2.584752] input: SONiX USB Device as /devices/pci0000:00/0000:00:1d.7/usb1/1-4/1-4.4/1-4.4:1.1/input/input2
[ 2.585051] generic-usb 0003:0C45:0520.0003: input,hidraw2: USB HID v1.00 Mouse [SONiX USB Device] on usb-0000:00:1d.7-4.4/input1
[ 2.585406] usbcore: registered new interface driver usbhid
[ 2.585412] usbhid: USB HID core driver
[ 5.736629] sd 0:0:0:0: [sda] 234375000 512-byte logical blocks: (120 GB/111 GiB)
[ 5.736754] sd 0:0:0:0: [sda] Write Protect is off
[ 5.736760] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 5.736812] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 5.737676] sr0: scsi3-mmc drive: 1x/48x cd/rw xa/form2 cdda tray
[ 5.737684] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 5.738381] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 5.739873] sr1: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
[ 5.740862] sr 1:0:1:0: Attached scsi CD-ROM sr1
[ 5.744060] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 5.744190] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 5.744305] sr 1:0:1:0: Attached scsi generic sg2 type 5
[ 5.778508] sda: sda1 sda2 < sda5 >
[ 5.779087] sd 0:0:0:0: [sda] Attached SCSI disk
[ 11.207369] PM: Starting manual resume from disk
[ 11.207377] PM: Hibernation image partition 8:5 present
[ 11.207380] PM: Looking for hibernation image.
[ 11.207654] PM: Image not found (code -22)
[ 11.207658] PM: Hibernation image not present or could not be loaded.
[ 11.221655] EXT4-fs (sda1): INFO: recovery required on readonly filesystem
[ 11.221662] EXT4-fs (sda1): write access will be enabled during recovery
[ 12.744153] EXT4-fs (sda1): orphan cleanup on readonly fs
[ 12.744170] EXT4-fs (sda1): ext4_orphan_cleanup: deleting unreferenced inode 2884234
[ 12.744283] EXT4-fs (sda1): 1 orphan inode deleted
[ 12.744288] EXT4-fs (sda1): recovery complete
[ 12.818923] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 14.827406] udevd[327]: starting version 175
[ 15.205913] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 15.205926] ACPI: Power Button [VBTN]
[ 15.206044] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 15.206052] ACPI: Power Button [PWRF]
[ 15.240512] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 15.302570] parport_pc 00:09: reported by Plug and Play ACPI
[ 15.302625] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 15.598944] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 15.644672] intel_rng: Firmware space is locked read-only. If you can't or
[ 15.644675] intel_rng: don't want to disable this in firmware setup, and if
[ 15.644677] intel_rng: you are certain that your system has a functional
[ 15.644679] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 15.937019] iTCO_vendor_support: vendor-support=0
[ 15.971855] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 15.971990] iTCO_wdt: Found a ICH5 or ICH5R TCO device (Version=1, TCOBASE=0x0860)
[ 15.973410] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 16.038838] [drm] Initialized drm 1.1.0 20060810
[ 16.089480] wmi: Mapper loaded
[ 16.180659] snd_intel8x0 0000:00:1f.5: setting latency timer to 64
[ 16.231412] [drm] nouveau 0000:01:00.0: Detected an NV30 generation card (0x034b00a2)
[ 16.235226] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 16.275484] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 16.275492] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 16.275623] [drm] nouveau 0000:01:00.0: BMP BIOS found
[ 16.275627] [drm] nouveau 0000:01:00.0: BMP version 5.38
[ 16.275632] [drm] nouveau 0000:01:00.0: Bios version 04.34.20.18
[ 16.275986] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 16.275992] [drm] nouveau 0000:01:00.0: DCB version 2.2
[ 16.276041] [drm] nouveau 0000:01:00.0: DCB outp 00: 02000310 000088b8
[ 16.276047] [drm] nouveau 0000:01:00.0: DCB outp 01: 01010300 000088b8
[ 16.276051] [drm] nouveau 0000:01:00.0: DCB outp 02: 03000312 00000000
[ 16.276158] [drm] nouveau 0000:01:00.0: Loading NV17 power sequencing microcode
[ 16.276163] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0x716A
[ 16.276198] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0x7365
[ 16.276208] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0x74AB
[ 16.276246] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0x7631
[ 16.276252] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0x764E
[ 16.276258] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 5 at offset 0x766B
[ 16.307731] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 6 at offset 0x77DC
[ 16.311688] [TTM] Zone kernel: Available graphics memory: 446032 kiB
[ 16.311694] [TTM] Zone highmem: Available graphics memory: 515388 kiB
[ 16.311698] [TTM] Initializing pool allocator
[ 16.311721] [drm] nouveau 0000:01:00.0: Detected 128MiB VRAM (DDR1)
[ 16.311911] agpgart-intel 0000:00:00.0: AGP 3.0 bridge
[ 16.311931] agpgart: modprobe tried to set rate=x12. Setting to AGP3 x8 mode.
[ 16.311943] agpgart-intel 0000:00:00.0: putting AGP V3 device into 8x mode
[ 16.312053] nouveau 0000:01:00.0: putting AGP V3 device into 8x mode
[ 16.312076] [drm] nouveau 0000:01:00.0: 128 MiB GART (aperture)
[ 16.312186] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 16.358729] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 16.358735] [drm] No driver support for vblank timestamp query.
[ 16.371708] [drm] nouveau 0000:01:00.0: 1 available performance level(s)
[ 16.371715] [drm] nouveau 0000:01:00.0: 0:
[ 16.371720] [drm] nouveau 0000:01:00.0: c: core 270MHz memory 486MHz
[ 16.373757] [drm] nouveau 0000:01:00.0: 0xDB68: Parsing digital output script table
[ 16.489090] [drm] nouveau 0000:01:00.0: allocated 1280x1024 fb: 0x49000, bo f6e66400
[ 16.489297] fbcon: nouveaufb (fb0) is primary device
[ 16.500824] [drm] nouveau 0000:01:00.0: 0xDB68: Parsing digital output script table
[ 16.502870] Console: switching to colour frame buffer device 160x64
[ 16.504475] fb0: nouveaufb frame buffer device
[ 16.504479] drm: registered panic notifier
[ 16.504488] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 16.604028] intel8x0_measure_ac97_clock: measured 52282 usecs (2519 samples)
[ 16.604035] intel8x0: clocking to 48000
[ 18.492375] Adding 2093052k swap on /dev/sda5. Priority:-1 extents:1 across:2093052k
[ 18.521173] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 18.768575] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 18.922062] loop: module loaded
[ 20.921271] RPC: Registered named UNIX socket transport module.
[ 20.921278] RPC: Registered udp transport module.
[ 20.921281] RPC: Registered tcp transport module.
[ 20.921285] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 20.965988] FS-Cache: Loaded
[ 21.012735] NFS: Registering the id_resolver key type
[ 21.012770] FS-Cache: Netfs 'nfs' registered for caching
[ 21.040919] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 23.208709] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 24.944128] Bluetooth: Core ver 2.16
[ 24.944548] NET: Registered protocol family 31
[ 24.944554] Bluetooth: HCI device and connection manager initialized
[ 24.944559] Bluetooth: HCI socket layer initialized
[ 24.944562] Bluetooth: L2CAP socket layer initialized
[ 24.944574] Bluetooth: SCO socket layer initialized
[ 24.977190] Bluetooth: RFCOMM TTY layer initialized
[ 24.977201] Bluetooth: RFCOMM socket layer initialized
[ 24.977205] Bluetooth: RFCOMM ver 1.11
[ 25.015965] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 25.015971] Bluetooth: BNEP filters: protocol multicast
[ 25.086157] lp0: using parport0 (interrupt-driven).
[ 25.201352] ppdev: user-space parallel port driver
[ 27.232561] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.236573] e1000: eth0 NIC Link is Up 100 Mbps Full Duplex, Flow Control: RX/TX
[ 27.236838] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 38.016015] eth0: no IPv6 routers present
[ 536.026978] I-pipe: head domain RTAI registered.
[ 536.026989] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 536.027000] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 536.027006] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 12468630, CLK_FREQ 2394065000, CPU_FREQ 2394065000
[ 536.027011] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 536.027017] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 12468630, 12468630, 10961250
[ 536.114883] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 536.114939] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 536.114947] RTAI[sched]: hard timer type/freq = APIC/12468630(Hz); default timing: oneshot; linear timed lists.
[ 536.114954] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2394065000 hz.
[ 536.114958] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[ 536.139069] RTAI[math]: loaded.
[ 536.582125] hm2: loading Mesa HostMot2 driver version 0.15
[ 536.594394] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 536.594439] hm2_pci 0000:02:03.0: enabling device (0000 -> 0002)
[ 536.594454] hm2_pci: discovered 5i25 at 0000:02:03.0
[ 536.594518] hm2/hm2_5i25.0: invalid cookie, got 0xFFFFFFFF, expected 0x55AACAFE
[ 536.594525] hm2/hm2_5i25.0: FPGA failed to initialize, or unexpected firmware?
[ 536.594531] hm2_5i25.0: board fails HM2 registration
[ 536.594558] hm2_pci: probe of 0000:02:03.0 failed with error -22
[ 537.160740] hm2: unloading
[ 539.366002] RTAI[math]: unloaded.
[ 539.369659] SCHED releases registered named ALIEN PEDV$D
[ 539.379499] RTAI[malloc]: unloaded.
[ 539.476028] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 539.479006] I-pipe: head domain RTAI unregistered.
[ 539.479022] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.11
TASK=milltask
HALUI=halui
DISPLAY=axis
3478
[ 0.089221] dummy:
- Chriscore
- Topic Author
8 years 9 months ago #104020
by Chriscore
christoph@MAS-VDF-CNC-Steuerung:~$ sudo mesaflash --device 5i25 --readhmid
[sudo] password for christoph:
ERROR: no HOSTMOT2 firmware found. FFFFFFFF
Configuration Name:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
Number of IO Ports: 0
Width of one I/O port: 0
Clock Low frequency: 0.0000 MHz
Clock High frequency: 0.0000 MHz
IDROM Type: 0
Instance Stride 0: 0
Instance Stride 1: 0
Register Stride 0: 0
Register Stride 1: 0
Modules in configuration:
Configuration pin-out:
Configuration Name:
BoardName :
FPGA Size: 0 KGates
FPGA Pins: 0
IDROM Type: 0
- Thank you received: 5334
8 years 9 months ago #104021
Replied by PCW on topic Mesa 5i25 PCI Issue sporadically need #Help#
That sounds like either a bad 5I25 or bad PCI slot since the card is found but
is not accessible with normal PCI commands (only IDSEL)
This usually means a stuck or open high order data/address line
I would first try cleaning the card/slot, trying an alternate slot
and then trying a different PC (just move the hard disk temporarily)
to see if its a 5I25 or PCI slot issue
The following user(s) said Thank You: Chriscore
Time to create page: 0.080 seconds
