6i25Mesa did not connect to 7i76
8 years 9 months ago #104046 by Chriscore
Hi Guys,
my Mesa 6i25 Plug and Go does not connect to mesa 6i76
the field power on the mesa is on ( the 2 leds shine)
i configurated with pncconf i switched the jumper to 5i25 compatible mode.
i have a standard firmware compatible to the 7i76 when i do a readhmid.
this is what dmesg shows
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.9
Machine configuration directory is '/home/christoph/linuxcnc/configs/my_LinuxCNC_machine'
Machine configuration file is 'my_LinuxCNC_machine.ini'
INIFILE=/home/christoph/linuxcnc/configs/my_LinuxCNC_machine/my_LinuxCNC_machine.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./my_LinuxCNC_machine.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3945
Debug file information:
./my_LinuxCNC_machine.hal:52: parameter or pin 'hm2_5i25.0.stepgen.00.dirsetup' not found
3945
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007fe0ac00 (usable)
[ 0.000000] BIOS-e820: 000000007fe0ac00 - 000000007fe0cc00 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007fe0ec00 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000f0000000 - 00000000f4000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Inc. Precision WorkStation 390 /0DN075, BIOS 2.6.0 05/19/2008
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7fe0a max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-D3FFF write-protect
[ 0.000000] D4000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 000000000 write-back
[ 0.000000] 1 base 07FF00000 mask FFFF00000 uncachable
[ 0.000000] 2 base 080000000 mask F80000000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 000000007ff00000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36526000 - 3728b000
[ 0.000000] ACPI: RSDP 000febf0 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fcedc 0006C (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: FACP 000fd004 000F4 (v03 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: DSDT fff53074 036E3 (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 7fe0ac00 00040
[ 0.000000] ACPI: SSDT fff56757 00099 (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fd0f8 00092 (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd18a 00028 (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fd1b2 00092 (v32 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fd244 0003E (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: HPET 000fd282 00038 (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fd4de 00032 (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fd2ba 00176 (v01 DELL B8K 00000015 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1158MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007fe0a
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007fe0a
[ 0.000000] On node 0 totalpages: 523673
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5526200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2317 pages used for memmap
[ 0.000000] HighMem zone: 294143 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:70000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7769000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519580
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=b090bf54-2442-4a44-8f69-f2dc4a1618ff ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4190160 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007fe0a)
[ 0.000000] Memory: 2053244k/2095144k available (3495k kernel code, 41448k reserved, 1237k data, 416k init, 1185840k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2127.968 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 4255.93 BogoMIPS (lpj=8511872)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.008047] Security Framework initialized
[ 0.008052] AppArmor: AppArmor disabled by boot time parameter
[ 0.008072] Mount-cache hash table entries: 512
[ 0.008315] Initializing cgroup subsys cpuacct
[ 0.008318] Initializing cgroup subsys memory
[ 0.008327] Initializing cgroup subsys devices
[ 0.008329] Initializing cgroup subsys freezer
[ 0.008332] Initializing cgroup subsys net_cls
[ 0.008334] Initializing cgroup subsys blkio
[ 0.008341] Initializing cgroup subsys perf_event
[ 0.008372] CPU: Physical Processor ID: 0
[ 0.008374] CPU: Processor Core ID: 0
[ 0.008376] mce: CPU supports 6 MCE banks
[ 0.008383] CPU0: Thermal monitoring enabled (TM2)
[ 0.008438] ACPI: Core revision 20120320
[ 0.084864] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.085227] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.124924] CPU0: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz stepping 02
[ 0.128007] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.128007] PEBS disabled due to CPU errata.
[ 0.128007] ... version: 2
[ 0.128007] ... bit width: 40
[ 0.128007] ... generic registers: 2
[ 0.128007] ... value mask: 000000ffffffffff
[ 0.128007] ... max period: 000000007fffffff
[ 0.128007] ... fixed-purpose events: 3
[ 0.128007] ... event mask: 0000000700000003
[ 0.136121] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.148032] CPU 1 irqstacks, hard=f5114000 soft=f5116000
[ 0.148036] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.160043] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.160090] Brought up 2 CPUs
[ 0.160094] Total of 2 processors activated (8511.87 BogoMIPS).
[ 0.161212] devtmpfs: initialized
[ 0.161212] PM: Registering ACPI NVS region [mem 0x7fe0ac00-0x7fe0cbff] (8192 bytes)
[ 0.161212] dummy:
[ 0.161212] NET: Registered protocol family 16
[ 0.161212] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.161212] ACPI: bus type pci registered
[ 0.161212] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf0000000-0xf3ffffff] (base 0xf0000000)
[ 0.161212] PCI: MMCONFIG at [mem 0xf0000000-0xf3ffffff] reserved in E820
[ 0.161212] PCI: Using MMCONFIG for extended config space
[ 0.161212] PCI: Using configuration type 1 for base access
[ 0.164065] bio: create slab <bio-0> at 0
[ 0.164112] ACPI: Added _OSI(Module Device)
[ 0.164112] ACPI: Added _OSI(Processor Device)
[ 0.164112] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.164112] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.164146] ACPI: EC: Look up EC in DSDT
[ 0.184158] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.199488] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x88 (20120320/tbutils-323)
[ 0.199684] ACPI: Interpreter enabled
[ 0.199702] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.199740] ACPI: Using IOAPIC for interrupt routing
[ 0.301516] ACPI: No dock devices found.
[ 0.301525] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.308043] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.318027] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7]
[ 0.318027] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0xf4000000-0xfec00000]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xefffffff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0xff980800-0xff980bff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff]
[ 0.318027] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff]
[ 0.318027] PCI host bridge to bus 0000:00
[ 0.318027] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.318027] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000effff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0xf4000000-0xfec00000]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0x80000000-0xefffffff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0xff980800-0xff980bff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0xff97c000-0xff97ffff]
[ 0.318027] pci_bus 0000:00: root bus resource [mem 0xfed20000-0xfed9ffff]
[ 0.318027] pci 0000:00:00.0: [8086:277c] type 00 class 0x060000
[ 0.318027] pci 0000:00:01.0: [8086:277d] type 01 class 0x060400
[ 0.318027] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.318027] pci 0000:00:1b.0: [8086:27d8] type 00 class 0x040300
[ 0.318027] pci 0000:00:1b.0: reg 10: [mem 0xfdffc000-0xfdffffff 64bit]
[ 0.318027] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.318027] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.318027] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.318027] pci 0000:00:1c.4: [8086:27e0] type 01 class 0x060400
[ 0.318027] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.318027] pci 0000:00:1c.5: [8086:27e2] type 01 class 0x060400
[ 0.318027] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[ 0.318027] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.318027] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.318027] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.318027] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.318027] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.318027] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.318027] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.320038] pci 0000:00:1d.3: reg 20: [io 0xff20-0xff3f]
[ 0.320081] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.320102] pci 0000:00:1d.7: reg 10: [mem 0xff980800-0xff980bff]
[ 0.320177] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.320199] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.320262] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.320349] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[ 0.320354] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
[ 0.320389] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.320403] pci 0000:00:1f.1: reg 10: [io 0x01f0-0x01f7]
[ 0.320413] pci 0000:00:1f.1: reg 14: [io 0x03f4-0x03f7]
[ 0.320424] pci 0000:00:1f.1: reg 18: [io 0x0170-0x0177]
[ 0.320434] pci 0000:00:1f.1: reg 1c: [io 0x0374-0x0377]
[ 0.320445] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.320484] pci 0000:00:1f.2: [8086:27c1] type 00 class 0x010601
[ 0.320501] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.320511] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.320520] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.320529] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.320538] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfecf]
[ 0.320548] pci 0000:00:1f.2: reg 24: [mem 0xff970000-0xff9703ff]
[ 0.320578] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.320596] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.320651] pci 0000:00:1f.3: reg 20: [io 0xece0-0xecff]
[ 0.320729] pci 0000:01:00.0: [10de:029e] type 00 class 0x030000
[ 0.320741] pci 0000:01:00.0: reg 10: [mem 0xfb000000-0xfbffffff]
[ 0.320753] pci 0000:01:00.0: reg 14: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.320766] pci 0000:01:00.0: reg 1c: [mem 0xfc000000-0xfcffffff 64bit]
[ 0.320775] pci 0000:01:00.0: reg 24: [io 0xdc80-0xdcff]
[ 0.320784] pci 0000:01:00.0: reg 30: [mem 0xfde00000-0xfde1ffff pref]
[ 0.328035] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.328041] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 0.328046] pci 0000:00:01.0: bridge window [mem 0xfb000000-0xfdefffff]
[ 0.328054] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.328105] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.328114] pci 0000:00:1c.0: bridge window [mem 0xfaf00000-0xfaffffff]
[ 0.328198] pci 0000:03:00.0: [104c:8240] type 01 class 0x060400
[ 0.328318] pci 0000:03:00.0: supports D1 D2
[ 0.336039] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[ 0.336048] pci 0000:00:1c.4: bridge window [mem 0xfae00000-0xfaefffff]
[ 0.336158] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.336183] pci 0000:04:00.0: reg 10: [mem 0xfaef0000-0xfaefffff]
[ 0.336358] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.336372] pci 0000:03:00.0: bridge window [mem 0xfae00000-0xfaefffff]
[ 0.336459] pci 0000:05:00.0: [14e4:167a] type 00 class 0x020000
[ 0.336484] pci 0000:05:00.0: reg 10: [mem 0xfadf0000-0xfadfffff 64bit]
[ 0.336589] pci 0000:05:00.0: PME# supported from D3hot D3cold
[ 0.344039] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[ 0.344047] pci 0000:00:1c.5: bridge window [mem 0xfad00000-0xfadfffff]
[ 0.344098] pci 0000:06:02.0: [11c1:5811] type 00 class 0x0c0010
[ 0.344120] pci 0000:06:02.0: reg 10: [mem 0xfacf3000-0xfacf3fff]
[ 0.344201] pci 0000:06:02.0: supports D1 D2
[ 0.344205] pci 0000:06:02.0: PME# supported from D0 D1 D2 D3hot
[ 0.344231] pci 0000:06:04.0: [9710:9865] type 00 class 0x070002
[ 0.344254] pci 0000:06:04.0: reg 10: [io 0xccc0-0xccc7]
[ 0.344277] pci 0000:06:04.0: reg 14: [mem 0xfacf4000-0xfacf4fff]
[ 0.344306] pci 0000:06:04.0: reg 20: [mem 0xfacf5000-0xfacf5fff]
[ 0.344345] pci 0000:06:04.0: PME# supported from D0 D3cold
[ 0.344368] pci 0000:06:04.1: [9710:9865] type 00 class 0x070002
[ 0.344387] pci 0000:06:04.1: reg 10: [io 0xccc8-0xcccf]
[ 0.344399] pci 0000:06:04.1: reg 14: [mem 0xfacf6000-0xfacf6fff]
[ 0.344428] pci 0000:06:04.1: reg 20: [mem 0xfacf7000-0xfacf7fff]
[ 0.344467] pci 0000:06:04.1: PME# supported from D0 D3cold
[ 0.344488] pci 0000:06:04.2: [9710:9865] type 00 class 0x070103
[ 0.344508] pci 0000:06:04.2: reg 10: [io 0xccd0-0xccd7]
[ 0.344519] pci 0000:06:04.2: reg 14: [io 0xccd8-0xccdf]
[ 0.344530] pci 0000:06:04.2: reg 18: [mem 0xfacf8000-0xfacf8fff]
[ 0.344551] pci 0000:06:04.2: reg 20: [mem 0xfacf9000-0xfacf9fff]
[ 0.344590] pci 0000:06:04.2: PME# supported from D0 D3cold
[ 0.344619] pci 0000:06:05.0: [9710:9865] type 00 class 0x070002
[ 0.344638] pci 0000:06:05.0: reg 10: [io 0xcce0-0xcce7]
[ 0.344650] pci 0000:06:05.0: reg 14: [mem 0xfacfa000-0xfacfafff]
[ 0.344679] pci 0000:06:05.0: reg 20: [mem 0xfacfb000-0xfacfbfff]
[ 0.344718] pci 0000:06:05.0: PME# supported from D0 D3cold
[ 0.344739] pci 0000:06:05.1: [9710:9865] type 00 class 0x070002
[ 0.344759] pci 0000:06:05.1: reg 10: [io 0xcce8-0xccef]
[ 0.344770] pci 0000:06:05.1: reg 14: [mem 0xfacfc000-0xfacfcfff]
[ 0.344799] pci 0000:06:05.1: reg 20: [mem 0xfacfd000-0xfacfdfff]
[ 0.344838] pci 0000:06:05.1: PME# supported from D0 D3cold
[ 0.344861] pci 0000:06:05.2: [9710:9865] type 00 class 0x070103
[ 0.344880] pci 0000:06:05.2: reg 10: [io 0xccf0-0xccf7]
[ 0.344891] pci 0000:06:05.2: reg 14: [io 0xccf8-0xccff]
[ 0.344903] pci 0000:06:05.2: reg 18: [mem 0xfacfe000-0xfacfefff]
[ 0.344923] pci 0000:06:05.2: reg 20: [mem 0xfacff000-0xfacfffff]
[ 0.344962] pci 0000:06:05.2: PME# supported from D0 D3cold
[ 0.345014] pci 0000:00:1e.0: PCI bridge to [bus 06-06] (subtractive decode)
[ 0.345019] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[ 0.345024] pci 0000:00:1e.0: bridge window [mem 0xfac00000-0xfacfffff]
[ 0.345031] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.345034] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.345037] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.345040] pci 0000:00:1e.0: bridge window [mem 0x000c0000-0x000effff] (subtractive decode)
[ 0.345044] pci 0000:00:1e.0: bridge window [mem 0x000f0000-0x000fffff] (subtractive decode)
[ 0.345047] pci 0000:00:1e.0: bridge window [mem 0xf4000000-0xfec00000] (subtractive decode)
[ 0.345050] pci 0000:00:1e.0: bridge window [mem 0x80000000-0xefffffff] (subtractive decode)
[ 0.345053] pci 0000:00:1e.0: bridge window [mem 0xff980800-0xff980bff] (subtractive decode)
[ 0.345056] pci 0000:00:1e.0: bridge window [mem 0xff97c000-0xff97ffff] (subtractive decode)
[ 0.345059] pci 0000:00:1e.0: bridge window [mem 0xfed20000-0xfed9ffff] (subtractive decode)
[ 0.345082] pci_bus 0000:00: on NUMA node 0
[ 0.345087] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.345686] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.346249] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.346553] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.346793] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI5._PRT]
[ 0.347038] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI6._PRT]
[ 0.347290] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.954375] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 0.954759] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.955184] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 0.955574] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.956257] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.956685] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 0.957066] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 0.957469] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 0.957603] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.957603] vgaarb: loaded
[ 0.957603] vgaarb: bridge control possible 0000:01:00.0
[ 0.957603] PCI: Using ACPI for IRQ routing
[ 0.957603] PCI: pci_cache_line_size set to 64 bytes
[ 0.957637] pci 0000:00:1f.2: no compatible bridge window for [mem 0xff970000-0xff9703ff]
[ 0.957725] Expanded resource reserved due to conflict with PCI Bus 0000:00
[ 0.957729] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.957732] reserve RAM buffer: 000000007fe0ac00 - 000000007fffffff
[ 0.957892] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.957900] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.961086] Switching to clocksource hpet
[ 0.961152] pnp: PnP ACPI init
[ 0.961166] ACPI: bus type pnp registered
[ 0.964945] pnp 00:00: [bus 00-ff]
[ 0.964949] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.964952] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.964955] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.964958] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.964961] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 0.964966] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.964969] pnp 00:00: [mem 0xf4000000-0xfec00000 window]
[ 0.964972] pnp 00:00: [mem 0x80000000-0xefffffff window]
[ 0.964975] pnp 00:00: [mem 0xf4000000-0xefffffff window]
[ 0.964978] pnp 00:00: [mem 0xff980800-0xff980bff window]
[ 0.964981] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 0.964984] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 0.965029] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.968704] pnp 00:01: [io 0x0062-0x0063]
[ 0.968707] pnp 00:01: [io 0x0065-0x006f]
[ 0.968710] pnp 00:01: [io 0x00e0-0x00ef]
[ 0.968713] pnp 00:01: [io 0x0800-0x085f]
[ 0.968715] pnp 00:01: [io 0x0c00-0x0c7f]
[ 0.968718] pnp 00:01: [io 0x0860-0x08ff]
[ 0.968782] system 00:01: [io 0x0800-0x085f] has been reserved
[ 0.968786] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 0.968789] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 0.968793] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.968993] pnp 00:02: [io 0x0080-0x009f]
[ 0.968996] pnp 00:02: [io 0x0000-0x001f]
[ 0.968998] pnp 00:02: [io 0x00c0-0x00df]
[ 0.969001] pnp 00:02: [dma 4]
[ 0.969034] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.969167] pnp 00:03: [io 0x00f0-0x00ff]
[ 0.969175] pnp 00:03: [irq 13]
[ 0.969210] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.969341] pnp 00:04: [io 0x0061]
[ 0.969375] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.969526] pnp 00:05: [io 0x0070-0x007f]
[ 0.969532] pnp 00:05: [irq 8]
[ 0.969566] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.973597] pnp 00:06: [io 0x03f0-0x03f5]
[ 0.973601] pnp 00:06: [io 0x03f7]
[ 0.973607] pnp 00:06: [irq 6]
[ 0.973609] pnp 00:06: [dma 2]
[ 0.974028] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.975896] pnp 00:07: [io 0x0060]
[ 0.975899] pnp 00:07: [io 0x0064]
[ 0.975905] pnp 00:07: [irq 1]
[ 0.975947] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.980976] pnp 00:08: [irq 12]
[ 0.981015] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.985519] pnp 00:09: [io 0x0378-0x037f]
[ 0.985522] pnp 00:09: [io 0x0778-0x077f]
[ 0.985528] pnp 00:09: [irq 7]
[ 0.985531] pnp 00:09: [dma 0 disabled]
[ 0.986558] pnp 00:09: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.991493] pnp 00:0a: [io 0x03f8-0x03ff]
[ 0.991500] pnp 00:0a: [irq 4]
[ 0.991816] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active)
[ 1.009917] pnp 00:0b: [mem 0x00000000-0x0009ffff]
[ 1.009921] pnp 00:0b: [mem 0x00100000-0x00ffffff]
[ 1.009923] pnp 00:0b: [mem 0x01000000-0x7fe0abff]
[ 1.009926] pnp 00:0b: [mem 0x000f0000-0x000fffff]
[ 1.009929] pnp 00:0b: [mem 0x000c0000-0x000d3fff]
[ 1.009932] pnp 00:0b: [mem 0xfec00000-0xfecfffff]
[ 1.009935] pnp 00:0b: [mem 0xfee00000-0xfeefffff]
[ 1.009937] pnp 00:0b: [mem 0xffb00000-0xffbfffff]
[ 1.009940] pnp 00:0b: [mem 0xffc00000-0xffffffff]
[ 1.010021] system 00:0b: [mem 0x00000000-0x0009ffff] could not be reserved
[ 1.010025] system 00:0b: [mem 0x00100000-0x00ffffff] could not be reserved
[ 1.010029] system 00:0b: [mem 0x01000000-0x7fe0abff] could not be reserved
[ 1.010033] system 00:0b: [mem 0x000f0000-0x000fffff] could not be reserved
[ 1.010037] system 00:0b: [mem 0x000c0000-0x000d3fff] could not be reserved
[ 1.010040] system 00:0b: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 1.010044] system 00:0b: [mem 0xfee00000-0xfeefffff] has been reserved
[ 1.010047] system 00:0b: [mem 0xffb00000-0xffbfffff] has been reserved
[ 1.010051] system 00:0b: [mem 0xffc00000-0xffffffff] has been reserved
[ 1.010055] system 00:0b: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.010233] pnp 00:0c: [mem 0xf0000000-0xf3ffffff]
[ 1.010236] pnp 00:0c: [mem 0xfeda0000-0xfedacfff]
[ 1.010309] system 00:0c: [mem 0xf0000000-0xf3ffffff] has been reserved
[ 1.010313] system 00:0c: [mem 0xfeda0000-0xfedacfff] has been reserved
[ 1.010317] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 1.010472] pnp 00:0d: [mem 0xfed00000-0xfed003ff]
[ 1.010516] pnp 00:0d: Plug and Play ACPI device, IDs PNP0103 (active)
[ 1.010524] pnp: PnP ACPI: found 14 devices
[ 1.010526] ACPI: ACPI bus type pnp unregistered
[ 1.010530] PnPBIOS: Disabled by ACPI PNP
[ 1.047838] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 1.047843] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 1.047865] pci 0000:00:1c.4: bridge window [io 0x1000-0x0fff] to [bus 03-04] add_size 1000
[ 1.047869] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-04] add_size 200000
[ 1.047879] pci 0000:00:1c.5: bridge window [io 0x1000-0x0fff] to [bus 05-05] add_size 1000
[ 1.047883] pci 0000:00:1c.5: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05-05] add_size 200000
[ 1.047902] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 1.047905] pci 0000:00:1c.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 1.047909] pci 0000:00:1c.5: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 1.047912] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 1.047915] pci 0000:00:1c.4: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 1.047918] pci 0000:00:1c.5: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 1.047924] pci 0000:00:1c.0: BAR 15: assigned [mem 0xf4000000-0xf41fffff 64bit pref]
[ 1.047929] pci 0000:00:1c.4: BAR 15: assigned [mem 0xf4200000-0xf43fffff 64bit pref]
[ 1.047933] pci 0000:00:1c.5: BAR 15: assigned [mem 0xf4400000-0xf45fffff 64bit pref]
[ 1.047937] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 1.047940] pci 0000:00:1c.4: BAR 13: assigned [io 0x2000-0x2fff]
[ 1.047944] pci 0000:00:1c.5: BAR 13: assigned [io 0x3000-0x3fff]
[ 1.047947] pci 0000:00:1f.2: BAR 5: assigned [mem 0xf4600000-0xf46003ff]
[ 1.047955] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 1.047959] pci 0000:00:01.0: bridge window [io 0xd000-0xdfff]
[ 1.047964] pci 0000:00:01.0: bridge window [mem 0xfb000000-0xfdefffff]
[ 1.047968] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xefffffff 64bit pref]
[ 1.047974] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 1.047977] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 1.047983] pci 0000:00:1c.0: bridge window [mem 0xfaf00000-0xfaffffff]
[ 1.047988] pci 0000:00:1c.0: bridge window [mem 0xf4000000-0xf41fffff 64bit pref]
[ 1.047995] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 1.048012] pci 0000:03:00.0: bridge window [mem 0xfae00000-0xfaefffff]
[ 1.048026] pci 0000:00:1c.4: PCI bridge to [bus 03-04]
[ 1.048029] pci 0000:00:1c.4: bridge window [io 0x2000-0x2fff]
[ 1.048035] pci 0000:00:1c.4: bridge window [mem 0xfae00000-0xfaefffff]
[ 1.048040] pci 0000:00:1c.4: bridge window [mem 0xf4200000-0xf43fffff 64bit pref]
[ 1.048047] pci 0000:00:1c.5: PCI bridge to [bus 05-05]
[ 1.048051] pci 0000:00:1c.5: bridge window [io 0x3000-0x3fff]
[ 1.048056] pci 0000:00:1c.5: bridge window [mem 0xfad00000-0xfadfffff]
[ 1.048061] pci 0000:00:1c.5: bridge window [mem 0xf4400000-0xf45fffff 64bit pref]
[ 1.048069] pci 0000:00:1e.0: PCI bridge to [bus 06-06]
[ 1.048072] pci 0000:00:1e.0: bridge window [io 0xc000-0xcfff]
[ 1.048078] pci 0000:00:1e.0: bridge window [mem 0xfac00000-0xfacfffff]
[ 1.048133] pci 0000:00:1e.0: setting latency timer to 64
[ 1.048138] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 1.048141] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 1.048144] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 1.048147] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000effff]
[ 1.048150] pci_bus 0000:00: resource 8 [mem 0x000f0000-0x000fffff]
[ 1.048153] pci_bus 0000:00: resource 9 [mem 0xf4000000-0xfec00000]
[ 1.048156] pci_bus 0000:00: resource 10 [mem 0x80000000-0xefffffff]
[ 1.048159] pci_bus 0000:00: resource 11 [mem 0xff980800-0xff980bff]
[ 1.048161] pci_bus 0000:00: resource 12 [mem 0xff97c000-0xff97ffff]
[ 1.048164] pci_bus 0000:00: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 1.048167] pci_bus 0000:01: resource 0 [io 0xd000-0xdfff]
[ 1.048170] pci_bus 0000:01: resource 1 [mem 0xfb000000-0xfdefffff]
[ 1.048173] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xefffffff 64bit pref]
[ 1.048176] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 1.048179] pci_bus 0000:02: resource 1 [mem 0xfaf00000-0xfaffffff]
[ 1.048182] pci_bus 0000:02: resource 2 [mem 0xf4000000-0xf41fffff 64bit pref]
[ 1.048185] pci_bus 0000:03: resource 0 [io 0x2000-0x2fff]
[ 1.048188] pci_bus 0000:03: resource 1 [mem 0xfae00000-0xfaefffff]
[ 1.048191] pci_bus 0000:03: resource 2 [mem 0xf4200000-0xf43fffff 64bit pref]
[ 1.048194] pci_bus 0000:04: resource 1 [mem 0xfae00000-0xfaefffff]
[ 1.048197] pci_bus 0000:05: resource 0 [io 0x3000-0x3fff]
[ 1.048200] pci_bus 0000:05: resource 1 [mem 0xfad00000-0xfadfffff]
[ 1.048203] pci_bus 0000:05: resource 2 [mem 0xf4400000-0xf45fffff 64bit pref]
[ 1.048206] pci_bus 0000:06: resource 0 [io 0xc000-0xcfff]
[ 1.048208] pci_bus 0000:06: resource 1 [mem 0xfac00000-0xfacfffff]
[ 1.048211] pci_bus 0000:06: resource 4 [io 0x0000-0x0cf7]
[ 1.048214] pci_bus 0000:06: resource 5 [io 0x0d00-0xffff]
[ 1.048217] pci_bus 0000:06: resource 6 [mem 0x000a0000-0x000bffff]
[ 1.048220] pci_bus 0000:06: resource 7 [mem 0x000c0000-0x000effff]
[ 1.048223] pci_bus 0000:06: resource 8 [mem 0x000f0000-0x000fffff]
[ 1.048225] pci_bus 0000:06: resource 9 [mem 0xf4000000-0xfec00000]
[ 1.048228] pci_bus 0000:06: resource 10 [mem 0x80000000-0xefffffff]
[ 1.048231] pci_bus 0000:06: resource 11 [mem 0xff980800-0xff980bff]
[ 1.048234] pci_bus 0000:06: resource 12 [mem 0xff97c000-0xff97ffff]
[ 1.048237] pci_bus 0000:06: resource 13 [mem 0xfed20000-0xfed9ffff]
[ 1.048326] NET: Registered protocol family 2
[ 1.048410] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 1.048612] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 1.048994] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 1.049184] TCP: Hash tables configured (established 131072 bind 65536)
[ 1.049187] TCP: reno registered
[ 1.049190] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 1.049199] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 1.049307] NET: Registered protocol family 1
[ 1.049502] pci 0000:01:00.0: Boot video device
[ 1.049535] PCI: CLS 64 bytes, default 64
[ 1.049593] Unpacking initramfs...
[ 1.357977] Freeing initrd memory: 13716k freed
[ 1.363651] Simple Boot Flag at 0x7a set to 0x1
[ 1.364245] audit: initializing netlink socket (disabled)
[ 1.364263] type=2000 audit(1211158301.360:1): initialized
[ 1.376959] highmem bounce pool size: 64 pages
[ 1.376964] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 1.377183] VFS: Disk quotas dquot_6.5.2
[ 1.377215] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.377310] msgmni has been set to 1720
[ 1.377507] alg: No test for stdrng (krng)
[ 1.377538] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.377543] io scheduler noop registered
[ 1.377545] io scheduler deadline registered
[ 1.377567] io scheduler cfq registered (default)
[ 1.377916] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.377938] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.377940] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.378538] GHES: HEST is not enabled!
[ 1.378553] isapnp: Scanning for PnP cards...
[ 1.731623] isapnp: No Plug & Play device found
[ 1.731686] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.752051] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.772780] 00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.793725] 0000:06:04.0: ttyS1 at I/O 0xccc0 (irq = 16) is a ST16650V2
[ 1.814618] 0000:06:04.1: ttyS2 at I/O 0xccc8 (irq = 17) is a ST16650V2
[ 1.835513] 0000:06:05.0: ttyS3 at I/O 0xcce0 (irq = 17) is a ST16650V2
[ 1.835612] Couldn't register serial port 0000:06:05.1: -28
[ 1.835862] Linux agpgart interface v0.103
[ 1.836105] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12
[ 1.839055] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.839091] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.839212] mousedev: PS/2 mouse device common for all mice
[ 1.839269] rtc_cmos 00:05: RTC can wake from S4
[ 1.839396] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.839422] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 1.839567] TCP: cubic registered
[ 1.839629] NET: Registered protocol family 10
[ 1.839904] Mobile IPv6
[ 1.839907] NET: Registered protocol family 17
[ 1.839912] Registering the dns_resolver key type
[ 1.839974] Using IPI No-Shortcut mode
[ 1.840126] PM: Hibernation image not present or could not be loaded.
[ 1.840138] registered taskstats version 1
[ 1.840627] rtc_cmos 00:05: setting system clock to 2008-05-19 00:51:42 UTC (1211158302)
[ 1.840728] Freeing unused kernel memory: 416k freed
[ 1.840929] Write protecting the kernel text: 3496k
[ 1.840956] Write protecting the kernel read-only data: 984k
[ 1.853778] udevd[49]: starting version 175
[ 1.872024] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 1.881636] usbcore: registered new interface driver usbfs
[ 1.881666] usbcore: registered new interface driver hub
[ 1.884113] usbcore: registered new device driver usb
[ 1.884606] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.884681] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 1.884686] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 1.884717] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 1.884737] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 1.884749] ehci_hcd 0000:00:1d.7: debug port 1
[ 1.895419] SCSI subsystem initialized
[ 1.903710] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 1.903745] ehci_hcd 0000:00:1d.7: irq 21, io mem 0xff980800
[ 1.903785] libata version 3.00 loaded.
[ 1.912032] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 1.912069] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.912073] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.912076] usb usb1: Product: EHCI Host Controller
[ 1.912079] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.912082] usb usb1: SerialNumber: 0000:00:1d.7
[ 1.912239] hub 1-0:1.0: USB hub found
[ 1.912245] hub 1-0:1.0: 8 ports detected
[ 1.915414] tg3.c:v3.123 (March 21, 2012)
[ 1.916602] ahci 0000:00:1f.2: version 3.0
[ 1.916708] ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
[ 1.916713] ahci 0000:00:1f.2: flags: 64bit ncq pm led clo pio slum part
[ 1.916718] ahci 0000:00:1f.2: setting latency timer to 64
[ 1.918119] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.918603] microcode: CPU0 sig=0x6f2, pf=0x1, revision=0x56
[ 1.920653] scsi0 : ahci
[ 1.921768] scsi1 : ahci
[ 1.922566] scsi2 : ahci
[ 1.922675] scsi3 : ahci
[ 1.922745] ata1: SATA max UDMA/133 abar m1024@0xf4600000 port 0xf4600100 irq 20
[ 1.922749] ata2: SATA max UDMA/133 abar m1024@0xf4600000 port 0xf4600180 irq 20
[ 1.922753] ata3: SATA max UDMA/133 abar m1024@0xf4600000 port 0xf4600200 irq 20
[ 1.922757] ata4: SATA max UDMA/133 abar m1024@0xf4600000 port 0xf4600280 irq 20
[ 1.922830] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.922835] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 1.922849] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 1.922880] uhci_hcd 0000:00:1d.0: irq 21, io base 0x0000ff80
[ 1.922926] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.922929] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.922932] usb usb2: Product: UHCI Host Controller
[ 1.922935] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.922938] usb usb2: SerialNumber: 0000:00:1d.0
[ 1.923089] hub 2-0:1.0: USB hub found
[ 1.923095] hub 2-0:1.0: 2 ports detected
[ 1.923200] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 1.923205] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 1.923215] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 1.923256] uhci_hcd 0000:00:1d.1: irq 22, io base 0x0000ff60
[ 1.923295] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.923299] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.923301] usb usb3: Product: UHCI Host Controller
[ 1.923304] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.923308] usb usb3: SerialNumber: 0000:00:1d.1
[ 1.923433] hub 3-0:1.0: USB hub found
[ 1.923439] hub 3-0:1.0: 2 ports detected
[ 1.923546] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 1.923551] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 1.923560] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 1.923597] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 1.923636] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.923641] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.923644] usb usb4: Product: UHCI Host Controller
[ 1.923646] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.923649] usb usb4: SerialNumber: 0000:00:1d.2
[ 1.923776] hub 4-0:1.0: USB hub found
[ 1.923782] hub 4-0:1.0: 2 ports detected
[ 1.923902] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 1.923907] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 1.923916] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 1.923971] uhci_hcd 0000:00:1d.3: irq 23, io base 0x0000ff20
[ 1.924181] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.924184] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.924187] usb usb5: Product: UHCI Host Controller
[ 1.924190] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.924193] usb usb5: SerialNumber: 0000:00:1d.3
[ 1.924313] hub 5-0:1.0: USB hub found
[ 1.924319] hub 5-0:1.0: 2 ports detected
[ 1.924478] ata_piix 0000:00:1f.1: version 2.13
[ 1.924528] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 1.925273] scsi4 : ata_piix
[ 1.925385] scsi5 : ata_piix
[ 1.925439] ata5: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 1.925443] ata6: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 1.925736] ata6: port disabled--ignoring
[ 1.931433] Floppy drive(s): fd0 is 1.44M
[ 1.938254] tg3 0000:05:00.0: eth0: Tigon3 [partno(BCM95754) rev b002] (PCI Express) MAC address 00:1a:a0:29:cb:56
[ 1.938259] tg3 0000:05:00.0: eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 1.938263] tg3 0000:05:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 1.938267] tg3 0000:05:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 1.946127] FDC 0 is a post-1991 82077
[ 1.958362] microcode: CPU0 updated to revision 0x5d, date = 2010-10-02
[ 1.958377] microcode: CPU1 sig=0x6f2, pf=0x1, revision=0x56
[ 1.961508] microcode: CPU1 updated to revision 0x5d, date = 2010-10-02
[ 1.961620] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.972151] firewire_ohci 0000:06:02.0: added OHCI v1.0 device as card 0, 8 IR + 8 IT contexts, quirks 0x0
[ 2.096323] ata5.00: ATAPI: HL-DT-STDVD-ROM GDR8164B, 0D08, max UDMA/33
[ 2.096330] ata5.01: ATAPI: PHILIPS DVD+/-RW DVD8801, 4D28, max UDMA/33
[ 2.112209] ata5.00: configured for UDMA/33
[ 2.128460] ata5.01: configured for UDMA/33
[ 2.240047] ata3: SATA link down (SStatus 0 SControl 300)
[ 2.240067] ata2: SATA link down (SStatus 0 SControl 300)
[ 2.240105] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.240719] ata1.00: ATA-7: WDC WD2500JS-75NCB3, 10.02E04, max UDMA/133
[ 2.240724] ata1.00: 488281250 sectors, multi 8: LBA48 NCQ (depth 31/32), AA
[ 2.241410] ata1.00: configured for UDMA/133
[ 2.241570] scsi 0:0:0:0: Direct-Access ATA WDC WD2500JS-75N 10.0 PQ: 0 ANSI: 5
[ 2.244089] ata4: SATA link down (SStatus 0 SControl 300)
[ 2.247505] scsi 4:0:0:0: CD-ROM HL-DT-ST DVD-ROM GDR8164B 0D08 PQ: 0 ANSI: 5
[ 2.249763] scsi 4:0:1:0: CD-ROM PHILIPS DVD+-RW DVD8801 4D28 PQ: 0 ANSI: 5
[ 2.259374] sd 0:0:0:0: [sda] 488281250 512-byte logical blocks: (250 GB/232 GiB)
[ 2.259443] sd 0:0:0:0: [sda] Write Protect is off
[ 2.259447] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.259477] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.262354] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.262410] sr 4:0:0:0: Attached scsi generic sg1 type 5
[ 2.262461] scsi 4:0:1:0: Attached scsi generic sg2 type 5
[ 2.263059] sr0: scsi3-mmc drive: 48x/48x cd/rw xa/form2 cdda tray
[ 2.263063] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.263329] sr 4:0:0:0: Attached scsi CD-ROM sr0
[ 2.272583] sr1: scsi3-mmc drive: 48x/48x writer cd/rw xa/form2 cdda tray
[ 2.272746] sr 4:0:1:0: Attached scsi CD-ROM sr1
[ 2.295854] sda: sda1 sda2 < sda5 >
[ 2.296278] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.360045] Refined TSC clocksource calibration: 2127.999 MHz.
[ 2.360053] Switching to clocksource tsc
[ 2.472184] firewire_core 0000:06:02.0: created device fw0: GUID 0000d1008128b3a8, S400
[ 7.654649] PM: Starting manual resume from disk
[ 7.654653] PM: Hibernation image partition 8:5 present
[ 7.654655] PM: Looking for hibernation image.
[ 7.654818] PM: Image not found (code -22)
[ 7.654823] PM: Hibernation image not present or could not be loaded.
[ 7.721391] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.083293] udevd[348]: starting version 175
[ 10.435820] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 10.435830] ACPI: Power Button [VBTN]
[ 10.435908] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 10.435912] ACPI: Power Button [PWRF]
[ 10.689037] coretemp coretemp.0: Using relative temperature scale!
[ 10.689050] coretemp coretemp.0: Using relative temperature scale!
[ 10.694585] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 10.943328] EDAC MC: Ver: 2.1.0
[ 10.961422] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.085310] intel_rng: Firmware space is locked read-only. If you can't or
[ 11.085312] intel_rng: don't want to disable this in firmware setup, and if
[ 11.085313] intel_rng: you are certain that your system has a functional
[ 11.085314] intel_rng: RNG, try using the 'no_fwh_detect' option.
[ 11.086897] EDAC MC0: Giving out device to 'i82975x_edac' 'i82975x': DEV 0000:00:00.0
[ 11.087937] parport_pc 00:09: reported by Plug and Play ACPI
[ 11.087991] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 11.090498] iTCO_vendor_support: vendor-support=0
[ 11.091265] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 11.091346] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 11.100710] leds_ss4200: no LED devices found
[ 11.184358] PCI parallel port detected: 14f2:0121, I/O at 0xccd0(0x0), IRQ 18
[ 11.184379] parport1: PC-style at 0xccd0, irq 18 [PCSPP,TRISTATE,EPP]
[ 11.280135] PCI parallel port detected: 14f2:0121, I/O at 0xccf0(0x0), IRQ 19
[ 11.280160] parport2: PC-style at 0xccf0, irq 19 [PCSPP,TRISTATE,EPP]
[ 11.352529] [drm] Initialized drm 1.1.0 20060810
[ 11.369348] hda_intel: position_fix set to 1 for device 1028:01de
[ 11.395887] wmi: Mapper loaded
[ 11.427258] [drm] nouveau 0000:01:00.0: Detected an NV40 generation card (0x049e00a2)
[ 11.429665] [drm] nouveau 0000:01:00.0: Checking PRAMIN for VBIOS
[ 11.442903] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input3
[ 11.470719] [drm] nouveau 0000:01:00.0: ... appears to be valid
[ 11.470723] [drm] nouveau 0000:01:00.0: Using VBIOS from PRAMIN
[ 11.470727] [drm] nouveau 0000:01:00.0: BIT BIOS found
[ 11.470730] [drm] nouveau 0000:01:00.0: Bios version 05.71.22.29
[ 11.470734] [drm] nouveau 0000:01:00.0: TMDS table version 1.1
[ 11.470736] [drm] nouveau 0000:01:00.0: TMDS table script pointers not stubbed
[ 11.470842] [drm] nouveau 0000:01:00.0: MXM: no VBIOS data, nothing to do
[ 11.470846] [drm] nouveau 0000:01:00.0: DCB version 3.0
[ 11.470849] [drm] nouveau 0000:01:00.0: DCB outp 00: 01000300 00000028
[ 11.470852] [drm] nouveau 0000:01:00.0: DCB outp 01: 03000302 00000000
[ 11.470855] [drm] nouveau 0000:01:00.0: DCB outp 02: 04011310 00000028
[ 11.470858] [drm] nouveau 0000:01:00.0: DCB outp 03: 0c011312 00000000
[ 11.470861] [drm] nouveau 0000:01:00.0: DCB outp 04: 020223f1 00c0c080
[ 11.470863] [drm] nouveau 0000:01:00.0: DCB conn 00: 1030
[ 11.470867] [drm] nouveau 0000:01:00.0: DCB conn 01: 2130
[ 11.470870] [drm] nouveau 0000:01:00.0: DCB conn 02: 0210
[ 11.470873] [drm] nouveau 0000:01:00.0: DCB conn 03: 0211
[ 11.470876] [drm] nouveau 0000:01:00.0: DCB conn 04: 0213
[ 11.470883] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 0 at offset 0xD6F9
[ 11.470945] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 1 at offset 0xDFEC
[ 11.483065] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 2 at offset 0xEA0D
[ 11.483081] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 3 at offset 0xEB88
[ 11.486229] [drm] nouveau 0000:01:00.0: Parsing VBIOS init table 4 at offset 0xECDC
[ 11.486390] [TTM] Zone kernel: Available graphics memory: 440768 kiB
[ 11.486393] [TTM] Zone highmem: Available graphics memory: 1033688 kiB
[ 11.486396] [TTM] Initializing pool allocator
[ 11.486410] [drm] nouveau 0000:01:00.0: Detected 256MiB VRAM (GDDR3)
[ 11.486428] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 11.492422] [drm] nouveau 0000:01:00.0: 512 MiB GART (aperture)
[ 11.492518] [drm] nouveau 0000:01:00.0: Saving VGA fonts
[ 11.497461] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input4
[ 11.497616] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 11.497759] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 11.497901] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 11.537231] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 11.537234] [drm] No driver support for vblank timestamp query.
[ 11.542498] [drm] nouveau 0000:01:00.0: 2 available performance level(s)
[ 11.542503] [drm] nouveau 0000:01:00.0: 0: core 375MHz shader 325MHz memory 625MHz voltage 1200mV fanspeed 20%
[ 11.542508] [drm] nouveau 0000:01:00.0: 1: core 375MHz shader 325MHz memory 625MHz voltage 1200mV fanspeed 40%
[ 11.542513] [drm] nouveau 0000:01:00.0: c: core 324MHz shader 324MHz memory 627MHz voltage 1200mV fanspeed 100%
[ 11.544506] [drm] nouveau 0000:01:00.0: 0xCACD: Parsing digital output script table
[ 11.594130] [drm] nouveau 0000:01:00.0: 0xCB08: Parsing digital output script table
[ 11.644189] [drm] nouveau 0000:01:00.0: Setting dpms mode 3 on TV encoder (output 4)
[ 11.776934] [drm] nouveau 0000:01:00.0: allocated 1920x1080 fb: 0x49000, bo f491d600
[ 11.777013] fbcon: nouveaufb (fb0) is primary device
[ 11.787947] [drm] nouveau 0000:01:00.0: 0xCACD: Parsing digital output script table
[ 11.838853] Console: switching to colour frame buffer device 240x67
[ 11.839949] fb0: nouveaufb frame buffer device
[ 11.839952] drm: registered panic notifier
[ 11.839958] [drm] Initialized nouveau 1.0.0 20120316 for 0000:01:00.0 on minor 0
[ 13.611368] Adding 4189180k swap on /dev/sda5. Priority:-1 extents:1 across:4189180k
[ 13.626440] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.935299] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 14.108822] loop: module loaded
[ 15.470569] RPC: Registered named UNIX socket transport module.
[ 15.470573] RPC: Registered udp transport module.
[ 15.470576] RPC: Registered tcp transport module.
[ 15.470578] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 15.508356] FS-Cache: Loaded
[ 15.545075] NFS: Registering the id_resolver key type
[ 15.545098] FS-Cache: Netfs 'nfs' registered for caching
[ 15.558260] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.856114] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input8
[ 20.958877] Bluetooth: Core ver 2.16
[ 20.958897] NET: Registered protocol family 31
[ 20.958900] Bluetooth: HCI device and connection manager initialized
[ 20.958903] Bluetooth: HCI socket layer initialized
[ 20.958906] Bluetooth: L2CAP socket layer initialized
[ 20.958912] Bluetooth: SCO socket layer initialized
[ 21.518417] Bluetooth: RFCOMM TTY layer initialized
[ 21.518425] Bluetooth: RFCOMM socket layer initialized
[ 21.518427] Bluetooth: RFCOMM ver 1.11
[ 21.548897] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.548901] Bluetooth: BNEP filters: protocol multicast
[ 22.536062] lp0: using parport0 (interrupt-driven).
[ 22.536109] lp1: using parport1 (interrupt-driven).
[ 22.536153] lp2: using parport2 (interrupt-driven).
[ 22.618218] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.628441] ppdev: user-space parallel port driver
[ 25.657055] tg3 0000:05:00.0: eth0: Link is up at 1000 Mbps, full duplex
[ 25.657060] tg3 0000:05:00.0: eth0: Flow control is on for TX and on for RX
[ 25.657177] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 36.704030] eth0: no IPv6 routers present
[ 55.315354] I-pipe: head domain RTAI registered.
[ 55.315360] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 55.315407] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 55.315411] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127968000, CPU_FREQ 2127968000
[ 55.315415] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 55.315418] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 8228750
[ 55.529728] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 55.529763] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 55.529768] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 55.529771] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127968000 hz.
[ 55.529774] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 55.873647] RTAI[math]: loaded.
[ 57.401749] hm2: loading Mesa HostMot2 driver version 0.15
[ 57.571157] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 57.571202] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 57.571277] NMI: PCI system error (SERR) for reason b1 on CPU 0.
[ 57.571281] Dazed and confused, but trying to continue
[ 57.571621] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 57.627517] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 57.627522] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 57.627525] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 57.627528] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 57.627530] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 57.627533] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 57.627535] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 57.627538] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 57.627541] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 57.627544] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 57.627547] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 57.627551] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 57.627554] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 57.627556] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 57.627559] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 57.627561] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 57.627563] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 57.627566] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 57.627568] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 57.627571] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 57.627573] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 57.627576] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 57.627578] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 57.627581] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 57.627583] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 57.627586] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 57.627588] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 57.627590] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 57.627593] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 57.627595] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 57.627598] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 57.627600] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 57.627603] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 57.627605] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 57.627608] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 57.627685] hm2/hm2_5i25.0: registered
[ 57.627687] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 57.787729] classicladder_rt: module license 'LGPL' taints kernel.
[ 57.787734] Disabling lock debugging due to kernel taint
[ 57.788391] creating ladder-state
[ 58.276549] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 58.276555] hm2/hm2_5i25.0: unregistered
[ 58.276607] hm2_pci: driver unloaded
[ 58.278468] hm2: unloading
[ 60.452392] RTAI[math]: unloaded.
[ 60.454387] SCHED releases registered named ALIEN PEDV$D
[ 60.459605] RTAI[malloc]: unloaded.
[ 60.556030] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 60.557952] I-pipe: head domain RTAI unregistered.
[ 60.558009] RTAI[hal]: unmounted.
[ 106.772277] I-pipe: head domain RTAI registered.
[ 106.772283] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 106.772327] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 106.772331] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127968000, CPU_FREQ 2127968000
[ 106.772335] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 106.772339] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16570000
[ 106.780744] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 106.780775] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 106.780781] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 106.780784] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127968000 hz.
[ 106.780787] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 106.788080] RTAI[math]: loaded.
[ 106.946638] hm2: loading Mesa HostMot2 driver version 0.15
[ 106.948872] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 106.948915] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 106.949314] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 107.005177] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 107.005181] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 107.005184] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 107.005186] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 107.005189] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 107.005191] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 107.005193] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 107.005196] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 107.005199] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 107.005202] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 107.005205] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 107.005208] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 107.005211] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 107.005214] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 107.005216] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 107.005218] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 107.005221] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 107.005223] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 107.005226] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 107.005228] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 107.005230] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 107.005233] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 107.005235] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 107.005237] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 107.005240] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 107.005242] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 107.005245] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 107.005247] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 107.005250] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 107.005252] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 107.005254] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 107.005257] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 107.005259] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 107.005262] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 107.005264] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 107.005340] hm2/hm2_5i25.0: registered
[ 107.005343] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 107.010824] creating ladder-state
[ 107.246795] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 107.246801] hm2/hm2_5i25.0: unregistered
[ 107.246846] hm2_pci: driver unloaded
[ 107.248679] hm2: unloading
[ 109.366530] RTAI[math]: unloaded.
[ 109.368540] SCHED releases registered named ALIEN PEDV$D
[ 109.373636] RTAI[malloc]: unloaded.
[ 109.472093] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 109.474086] I-pipe: head domain RTAI unregistered.
[ 109.474142] RTAI[hal]: unmounted.
[ 234.874098] I-pipe: head domain RTAI registered.
[ 234.874105] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 234.874171] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 234.874174] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127968000, CPU_FREQ 2127968000
[ 234.874178] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 234.874181] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16590250
[ 234.884360] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 234.884394] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 234.884399] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 234.884403] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127968000 hz.
[ 234.884405] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 234.889827] RTAI[math]: loaded.
[ 235.048831] hm2: loading Mesa HostMot2 driver version 0.15
[ 235.050987] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 235.051029] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 235.051415] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 235.107223] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 235.107227] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 235.107229] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 235.107232] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 235.107235] hm2/hm2_5i25.0: IO Pin 003 (P3-15): IOPort
[ 235.107237] hm2/hm2_5i25.0: IO Pin 004 (P3-03): IOPort
[ 235.107240] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 235.107242] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 235.107245] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 235.107248] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 235.107252] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 235.107255] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 235.107258] hm2/hm2_5i25.0: IO Pin 011 (P3-08): IOPort
[ 235.107260] hm2/hm2_5i25.0: IO Pin 012 (P3-09): IOPort
[ 235.107262] hm2/hm2_5i25.0: IO Pin 013 (P3-10): IOPort
[ 235.107265] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 235.107267] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 235.107270] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 235.107272] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 235.107275] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 235.107277] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 235.107279] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 235.107282] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 235.107285] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 235.107287] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 235.107289] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 235.107292] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 235.107294] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 235.107297] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 235.107299] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 235.107302] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 235.107304] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 235.107307] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 235.107309] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 235.107312] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 235.107386] hm2/hm2_5i25.0: registered
[ 235.107388] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 235.370509] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 235.370515] hm2/hm2_5i25.0: unregistered
[ 235.370561] hm2_pci: driver unloaded
[ 235.372327] hm2: unloading
[ 237.485245] RTAI[math]: unloaded.
[ 237.487243] SCHED releases registered named ALIEN PEDV$D
[ 237.489992] RTAI[malloc]: unloaded.
[ 237.588062] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 237.590066] I-pipe: head domain RTAI unregistered.
[ 237.590123] RTAI[hal]: unmounted.
christoph@PhysicalComputingLinuxCNC:~$ sudo mesaflash --device 5i25 --readhmid
[sudo] password for christoph:
Configuration Name: HOSTMOT2
BoardName : MESA5I25
FPGA Size: 9 KGates
FPGA Pins: 144
Number of IO Ports: 2
Width of one I/O port: 17
Clock Low frequency: 33.3333 MHz
Clock High frequency: 200.0000 MHz
IDROM Type: 3
Instance Stride 0: 4
Instance Stride 1: 64
Register Stride 0: 256
Register Stride 1: 256
Modules in configuration:
Module: WatchDog
There are 1 of WatchDog in configuration
Version: 0
Registers: 3
BaseAddress: 0C00
ClockFrequency: 33.333 MHz
Register Stride: 256 bytes
Instance Stride: 4 bytes
Module: IOPort
There are 2 of IOPort in configuration
Version: 0
Registers: 5
BaseAddress: 1000
Module: MuxedQCount
There are 12 of MuxedQCount in configuration
Version: 3
Registers: 5
BaseAddress: 3600
Module: MuxedQCountSel
There are 1 of MuxedQCountSel in configuration
Version: 0
Registers: 0
BaseAddress: 0000
Module: SSerial
There are 1 of SSerial in configuration
Version: 0
Registers: 6
BaseAddress: 5B00
Instance Stride: 64 bytes
Module: LED
There are 1 of LED in configuration
Version: 0
Registers: 1
BaseAddress: 0200
Configuration pin-out:
IO Connections for P3
Pin# I/O Pri. func Sec. func Chan Pin func Pin Dir
1 0 IOPort SSerial 0 TXEn3 (Out)
14 1 IOPort SSerial 0 TXData3 (Out)
2 2 IOPort SSerial 0 RXData3 (In)
15 3 IOPort SSerial 0 TXData2 (Out)
3 4 IOPort SSerial 0 RXData2 (In)
16 5 IOPort SSerial 0 TXData1 (Out)
4 6 IOPort SSerial 0 RXData1 (In)
17 7 IOPort MuxedQCountSel 0 MuxSel0 (Out)
5 8 IOPort MuxedQCount 0 MuxQ-A (In)
6 9 IOPort MuxedQCount 0 MuxQ-B (In)
7 10 IOPort MuxedQCount 0 MuxQ-IDX (In)
8 11 IOPort MuxedQCount 1 MuxQ-A (In)
9 12 IOPort MuxedQCount 1 MuxQ-B (In)
10 13 IOPort MuxedQCount 1 MuxQ-IDX (In)
11 14 IOPort MuxedQCount 2 MuxQ-A (In)
12 15 IOPort MuxedQCount 2 MuxQ-B (In)
13 16 IOPort MuxedQCount 2 MuxQ-IDX (In)
IO Connections for P2
1 17 IOPort SSerial 0 TXEn6 (Out)
14 18 IOPort SSerial 0 TXData6 (Out)
2 19 IOPort SSerial 0 RXData6 (In)
15 20 IOPort SSerial 0 TXData5 (Out)
3 21 IOPort SSerial 0 RXData5 (In)
16 22 IOPort SSerial 0 TXData4 (Out)
4 23 IOPort SSerial 0 RXData4 (In)
17 24 IOPort MuxedQCountSel 6 MuxSel0 (Out)
5 25 IOPort MuxedQCount 3 MuxQ-A (In)
6 26 IOPort MuxedQCount 3 MuxQ-B (In)
7 27 IOPort MuxedQCount 3 MuxQ-IDX (In)
8 28 IOPort MuxedQCount 4 MuxQ-A (In)
9 29 IOPort MuxedQCount 4 MuxQ-B (In)
10 30 IOPort MuxedQCount 4 MuxQ-IDX (In)
11 31 IOPort MuxedQCount 5 MuxQ-A (In)
12 32 IOPort MuxedQCount 5 MuxQ-B (In)
13 33 IOPort MuxedQCount 5 MuxQ-IDX (In)
thx for help
8 years 9 months ago #104052 by PCW
Looks like the wrong firmware ( that's 7I77 firmware ), unless you have a 6I25/7I77 kit
The following user(s) said Thank You: Chriscore
8 years 9 months ago #104498 by Chriscore
ok no i have an 7i76 kit where did u see this ??
so i need to get the standard 7i76 bit file right ?
regards chris
8 years 9 months ago #104501 by PCW
You need to flash the 5I25/6I25 with 5i25_7i76x2.bit
if you have mesaflash installed you fetch the 5i25_7i76x2.bit file and then
sudo mesaflash --device 5i25 --write 5i25_7i76x2.bit --reload
Time to create page: 0.798 seconds
