I only had a limited amount of time last night to pull the VFD apart. Definitely no high voltage regulator.
There are two transformers, one very small (maybe 10mm square) that has a primary and a secondary. The second one is about 30mm square and has a plethora of windings on it. Everything is conformal coated so it is fairly difficult to work on. Given that I don't have any indication that the drive "on", however, I am thinking that something is amiss with the SMPS. I'd expect the display to come on otherwise.
I've been running this in a phase converter mode previously. The machine was an operable Hurco when I yanked the control out of it, but then it sat for a few years. I don't really see a failure case that I could have introduced that would screw up the SMPS, so I'm thinking my present state is just bad luck/timing. Working with a full VFD in a disassembled state will be difficult, especially since the PS is on the backside of everything. I think I'll try a few quick things.
- With it fully assembled, I will try a full 3 phase input power. If it suddenly works, then I know that one of the input diodes is a problem and I can just work through which one (or check it with a voltmeter)... Hmmm, probably easier to do that right now without any power!
- If there is no love there, I can just work with the power board briefly and see if I can trace down where in the SMPS I have a faulty component
I don't know how long I want to spend on this though as it is a detractor of precious time and I don't want to become side-tracked. I can always buy a Huanyang 2.2kw VFD for about $130 and be done with it. From what I understand, this is a little better now if you can figure out the Chinglish manual. I know everything is made in China now, but it isn't all made equally. I'm a little leery of buying the lowest priced 2.2kw VFD off of ebay when the description is not even very readable. I'm no fool, though. I know all the VFDs, even those from AB, are made in China. But most western brands do a decent job of QC validation to ensure the stuff is decently made. I've got a whole lot more concern about stuff made for a Chinese company. Been there, done that and very often with poor results.
So, we'll see... I'm a bit nervous about the Huanyang but maybe it is worth a shot....
