OK. I got a bit of time and I thought I'd give some of the learnings a shot... I fixed the pncconf configuration so that it looks a whole lot better now. I'm very happy about that. As mentioned previously, the internal net names for the limit and home switches were used and that enabled the dialog elements for the home velocity, direction, etc. Cool.
I'm still not sure how I'll deal with some of the other stuff such as pins to clear servo errors and, similarly, pins to report servo faults. But my guess is that this will be in a logic ladder someplace and shouldn't affect some basic attempts to move axis around under LinuxCNC. So...
I decided to power up LinuxCNC, selecting my pncconf created cfg files, of course. I know I need to tune the axis so I pulled the high voltage on the X & Y so I could concentrate on just Z for the time being (no big pieces of metal slamming around, etc... seems safer). My experience wasn't what I expected, though. When I try to tune axis 3 (Z), I never hear the servo even hum or drift. The LED indicators on the amp also strongly suggest that the amp is never getting the enable signal. I'm using the axis ENA lines in the 7i77 card, and I know those work because I can test the jogging within pncconf.
So, I'm a little mystified about that one. Any ideas?
[on edit: OK... I think I have a few different areas here that need work before I can continue. First, I monitored the ENA and realize now that I was missing the 'turn on the machine' (F2) step. Duh. Easy fix there. Slightly bigger issue is my estop chain, which is a little more restrictive right now with external start/stop for safety. Thought I had that figured out but the axis is not moving. That said, I have the HV on (good) and I can see the analog out changing when I job (also good). Now I'm wondering if my amp was never moved into the operate mode and, instead, is ignoring the analog input. If so, that makes a lot of sense. The point is, however, I know there are some things I need to check/fix (good... stuff to do)]
I did also poke around LinuxCNC a bit more and saw the HAL monitor "stuff". I have to do a little reading on that because I'm guessing it will be useful. I wasn't able to control the fault reset (even though I don't presently have a servo fault) though. The pin is bound to a net so I can't issue a command directly to that. And when I try to control the net, I get a syntax error. Anyhow, this is lower priority and is just me being unfamiliar with the halrun commands.
[edit: It would be awfully nice to add a button so I could reset my drive just in case it is in an error mode. I saw one writeup where the guy took several screenshots of his UI. He had a lot of PWM indicates and such, much like the spindle speed widget. I am not sure how to add a simple button that will change the state of a 7i77 output pin (ideally a momentary contact).]
[edit2: Figured out how to add a button and status LED but it isn't quite right. I've bound it to the net names for the 7i77 pins. But when I press the UI button, the output of the port doesn't change (halscope doesn't see the change and I confirmed with a volt meter too). So, I'm doing something wrong there. My guess is that I probably need the two pass option.
This gets to another question though... Is there a way to reload the INI, XML, and HAL files without restarting? I read that you probably cannot do this for the INI but the others were not specifically addressed.
