Greenie problems configuring 6i25 with 7i77, using Granite Devices VSD-E drives
12 Mar 2018 11:53 #107238 by andypugh
A Z axis is typically configured with home at the top around 0, and the bottom of travel at (in your case) -6.0
Often home will be zero and the switch slightly positive.
Maxlim 0.1
Minlim -5.9
Home position 0
home offset +0.1
As an example.
The following user(s) said Thank You: DeckelHead
13 Mar 2018 00:41 #107267 by DeckelHead
Ah! Of course! That pesky negative z axis. I looked at that and got my home switch correctly, etc, but I wasn't thinking that the travel limit would be negative too. Good catch. Thank you.
I will be attaching my tuning plots at some point. I can't get them as clean as the one in the tuning directions. :( I'm not sure what is "good enough" and what is indicative of poor tuning within the amp itself. Frankly, tuning is the biggest single unknown for me. :(
Anyhow, I can jog at 60IPM and my 1000 encoder stops about 3 or 4 counts in (so 3 of 4000), which feels like it is probably pretty good (?). I think I'll work on the X and Y axis pretty soon. Z was the safest, for obvious reasons.
One sad thing is that I think my spindle VFD got fried for some reason and I have no idea how. It is possible that it got -10V before I had it configured properly but I'm not sure. All I know is that it has power to it and it looks dead as a doornail. Sigh. 3HP VFDs have dropped a lot in price, though, so hopefully I can get a new one without too much pain.
13 Mar 2018 22:03 #107305 by andypugh
You might as well take the cover off and check for internal fuses.
A VFD isn't _that_ complicated. You can (carefully) check that the input stage (diodes and capacitors) is powering up to a (high) DC voltage. If it is a three-phase input device running on single-phase you can also try different combinations of input terminals. Perhaps a rectifier diode has failed.
I wouldn't expect complete failure from a miss-wiring of the control terminals.
14 Mar 2018 01:37 #107325 by DeckelHead
Yeah, I haven't given up the ghost yet on it. I agree that the concept of a VFD is pretty simple, and I also agree that an input signal problem shouldn't cause a major problem. That is part of the curiosity though. It is completely dead. For all practical purposes, aside from the capacitor charged warning LED, you'd never know it was even hooked to the mains. No LEDs, nothing. That reeks of an internal fuse, but if I can't find one, then it could be that something is truly turned out (but I have no acrid smoke smell that is tell-tale of such events).
I have to do a little more research on it. As my axis home stuff is moving along well, I'll probably look at the VFD before I finish with the axis. The reason is that there will be a lead time if I decide my current unit really is toast.
Alan
14 Mar 2018 05:51 #107332 by DeckelHead
Well, I took the VFD apart and I didn't have any luck. It is all conformal coated and I couldn't find any indication of damage to the board or components thereon. Because the display and logic side of things are all low voltage, I looked for a regulator with the hope that it might be bad. I know it is there someplace, or a SMPS, but I didn't see any likely candidates. I also could not find any fuses. Sometimes these can be a little harder to find, but I checked both the components and the legends; I found nothing that was of particular interest.
I think this is one VFD that has flown the coop. :(
14 Mar 2018 10:42 #107339 by andypugh
Are there any chips with a bigger than expected gap between pins?
uk.rs-online.com/web/p/buck-converters/5254167/
(That's an AC input one, but shows the unusual pin layout)
14 Mar 2018 15:44 - 14 Mar 2018 15:45 #107349 by DeckelHead
I'll take a look this evening. This is a GE AF300 (E$, I believe, but I'm at work right now so I cannot confirm) 3HP unit. It is very similar, if not identical to this (edit: well, no... this is a 380V unit and I'm running 220V single phase input):
www.ebay.com/itm/Ge-Fuji-6KAF343003E-A1-...5738.m4383.l4275.c10
I'm not sure when it died on me because it is in a different cabinet. Internally there are several boards. The capacitor one is a no brainer. Then there are two control boards, each of which have components on both sides. The boards are stacked (no surprise there) with pins connecting them. The rear board has the large SCRs and a transformer on the rear. That is probably where the SMPS is located. I'll investigate that a little more carefully.
Alan
Last edit: 14 Mar 2018 15:45 by DeckelHead.
14 Mar 2018 15:51 #107350 by andypugh
It's probably too old to use a high-voltage regulator like I linked to. If there is a transformer on the back then that sounds like an SMPS, as you say.
I guess you can check the input and output sides of that?
15 Mar 2018 16:32 #107380 by DeckelHead
I only had a limited amount of time last night to pull the VFD apart. Definitely no high voltage regulator. :( There are two transformers, one very small (maybe 10mm square) that has a primary and a secondary. The second one is about 30mm square and has a plethora of windings on it. Everything is conformal coated so it is fairly difficult to work on. Given that I don't have any indication that the drive "on", however, I am thinking that something is amiss with the SMPS. I'd expect the display to come on otherwise.
I've been running this in a phase converter mode previously. The machine was an operable Hurco when I yanked the control out of it, but then it sat for a few years. I don't really see a failure case that I could have introduced that would screw up the SMPS, so I'm thinking my present state is just bad luck/timing. Working with a full VFD in a disassembled state will be difficult, especially since the PS is on the backside of everything. I think I'll try a few quick things.
  1. With it fully assembled, I will try a full 3 phase input power. If it suddenly works, then I know that one of the input diodes is a problem and I can just work through which one (or check it with a voltmeter)... Hmmm, probably easier to do that right now without any power!
  2. If there is no love there, I can just work with the power board briefly and see if I can trace down where in the SMPS I have a faulty component
I don't know how long I want to spend on this though as it is a detractor of precious time and I don't want to become side-tracked. I can always buy a Huanyang 2.2kw VFD for about $130 and be done with it. From what I understand, this is a little better now if you can figure out the Chinglish manual. I know everything is made in China now, but it isn't all made equally. I'm a little leery of buying the lowest priced 2.2kw VFD off of ebay when the description is not even very readable. I'm no fool, though. I know all the VFDs, even those from AB, are made in China. But most western brands do a decent job of QC validation to ensure the stuff is decently made. I've got a whole lot more concern about stuff made for a Chinese company. Been there, done that and very often with poor results.
So, we'll see... I'm a bit nervous about the Huanyang but maybe it is worth a shot....
16 Mar 2018 13:31 #107423 by andypugh
Mine has been fine. Make sure you get a real one and not a fake one (Perhaps the fact that fake Huanyang drives exist is a good sign?) as the clones don't have ModBus.
Well, technically, the HY ones don't have Modbus, just something a bit like ModBus, but LinuxCNC has a specific driver.
Time to create page: 0.114 seconds
