5i25 pulse voltage 1V
8 years 8 months ago #106248 by Lui23
5i25 pulse voltage 1V was created by Lui23
Hello !
It's my first post so be patient please :)
I worked few years on LinuxCNC LPT version and now I decided to jump on mesa cards.
I chose 5i25 + 7i76. I made everything according manual & information from forums. (correct PC dell GX270, 5i25 firmware, jumpers, root access, Linux upgrade to 2.7.12. Problem is that my set still doesn't work.
I started to measure signals & I found that high step signals on DB25 5i25 wire 14, 15 & 16 have not more than 1V. Dir signal seams to work fine (about 5V).
Could you help me to solve that please ? What could be a reason?
Mariusz
8 years 8 months ago #106249 by PCW
Replied by PCW on topic 5i25 pulse voltage 1V
I would not expect the step signals to have high levels if measured with a meter since they will idle in the low state
and only be high during the actual step pulse
8 years 8 months ago #106278 by Lui23
Replied by Lui23 on topic 5i25 pulse voltage 1V
OMG - Mesa is working perfect, it was problem with Chinese encoder wire colors :/ manual was from different schipment :D
I have connect different serwo and it's working perfect.
Thank you anyway !
Time to create page: 2.681 seconds
