7i76 spindle setup
8 years 6 months ago #108676 by Ross77
7i76 spindle setup was created by Ross77
Im having trouble setting up the 7i76 for +/-10v control of the spindle for easy CW and CCW control
the spindle is a DC motor running off is a Sprint 340XRi which i have tested with a Pot and works fine for CW and CCW operation.
The 340Xri generates the -10v but seems to be ok. When I connect the -10 and +10v to the 7i76 the Spin- drops to -7.2 but spin+ is 10v. When I run the spindle from MDI it starts at -7.2 and when the speed is incremented on the + button it jumps to 10v and drops down to 0 as the + button is pressed.
I haven't connected the 340xri to the controller yet as I wanted to get the signals working correctly first. I checked +/- control in PCconfig but it doesn't seem to work. Could someone have a look and see if I have a setting wrong? Thanks in advance
8 years 6 months ago - 8 years 6 months ago #108687 by PCW
Replied by PCW on topic 7i76 spindle setup
If you connect +10 and -10V to a 7I76 analog interface you may damage it
(it expects 15V maximum between SPIN+ and SPIN-)
If you need bipolar operation, you can run the analog interface from +- 7.5V but you would probably
need to use the scale component to add a 1/2 scale offset to the spindle speed command in hal
Last edit: 8 years 6 months ago by PCW.
8 years 6 months ago #108770 by Ross77
Replied by Ross77 on topic 7i76 spindle setup
Ah! that could be a problem then, fingers crossed I haven't damaged the board!
I don't need bipolar but it just seemed an easier way to set up the direction control of the spindle and I thought it might transition better for indexing when using Orient.
I can wire it up for the push buttons if required. Can I connect the Spindle enable direct to the 340XRI pin 9 , if I connected feild GND to the com line, or would it be better to relay it to keep the earths separate?
Me end goal is to use the spindle for indexing (with a brake) so what would be the best way to set it up? Cheers
8 years 6 months ago #108776 by PCW
The 7I76's spindle enable and direction outputs are floating switches
(Opto-isolator outputs) and have no common pins with field or logic power.
If you have a active low enable (pull down to enable) for example you connect:
7I76 ENA+ --> Drive enable input
7I76 ENA- --> Drive enable common
If you had a active high +24V enable, you would wire
+24V --> 7I76 ENA+
7I76 ENA- --> Drive enable input
(and 24V common to the drives input common)
The following user(s) said Thank You: Ross77
8 years 6 months ago #108778 by Ross77
Thanks that makes more sense now,
As long as I haven't damaged the board then I have a few options to try. First job is to get it working and then I can tweek later if its not quite right.
Thanks again
8 years 6 months ago #108855 by Ross77
Well the good news is I didn't damage the 7i76 with the +/-10v.
Problem is I cant seem to find the right wiring set up to make it work with only 0-10v. the controller seems to need +/-10v and the different diagrams basically swap the +10 to the -10 feed which means that spin+ is negative and wont work as it below 0v
will it work if if I did a switch over relay to make spin- -10 and spin + 0v?
I have set the spin out to 7.5v and adjusted the max output on the 340XRI but it wont get any were near 1000rpm so not really an option to scale a +/-7.5v supply.
The only 2 options I can see is to use an external controller that can accept step direction to generate +/-10v or try a +10-5v steup as I dont need full RPM in reverse. (its only for indexing)
Have I missed an easier option?
Time to create page: 0.323 seconds
