Hi All
I am at a stage where I want to run my 3 axis mill with basic open loop spindle control. I don't need synchronous spindle motion right now and just want to do some test cuts an generally prove things out a bit more.
I have a VSD 0-10V with direction and enable wired to TB4. This works in manual mode and spindle override seems to work but have not checked actual speed in detail.
If i run in MDI the spindle runs away to max speed - i guess due to the lack of an encoder signal.
I set up TB4 in PNFCONF as spindle, in subsequent spindle set up configured 0-10v over 2600 rpm, The remainder of the set up relates to encoder parameters. Is it possible to set up without an encoder?
Not sure how relevant but when I set up the board I set jumpers to TTL as I expected if I add an encoder at some point it will be single channel, single sided.
Any help greatly appreciated.
