Ok still having problems with linuxcnc not opening so here is the error report,any help would really be appreciated,I have been trying stuff for days now.
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.14
Machine configuration directory is '/home/mike/linuxcnc/configs/DELTA_CNC_MILL'
Machine configuration file is 'DELTA_CNC_MILL.ini'
INIFILE=/home/mike/linuxcnc/configs/DELTA_CNC_MILL/DELTA_CNC_MILL.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Found file(REL): ./DELTA_CNC_MILL.hal
Running HAL shutdown script
Killing task linuxcncsvr, PID=3933
Debug file information:
Error: could not insert module /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/hm2_pci.ko: Invalid parameters
./DELTA_CNC_MILL.hal:8: exit value: 1
./DELTA_CNC_MILL.hal:8: insmod for hm2_pci failed, returned -1
See the output of 'dmesg' for more information.
3933
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] Disabled fast string operations
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007f5ffc00 (usable)
[ 0.000000] BIOS-e820: 000000007f5ffc00 - 000000007f601c00 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007f603c00 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fed00400 (reserved)
[ 0.000000] BIOS-e820: 00000000fed20000 - 00000000feda0000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fef00000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: Dell Inc. OptiPlex 745 /0HR330, BIOS 2.4.1 08/21/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7f5ff max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask 000000000 write-back
[ 0.000000] 1 base 07F800000 mask FFF800000 uncachable
[ 0.000000] 2 base 07F700000 mask FFFF00000 uncachable
[ 0.000000] 3 base 080000000 mask F80000000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 000000007f700000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fe710] fe710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36524000 - 3728a000
[ 0.000000] ACPI: RSDP 000febf0 00024 (v02 DELL )
[ 0.000000] ACPI: XSDT 000fce97 0006C (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: FACP 000fcfbf 000F4 (v03 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: DSDT fff68958 0475F (v01 DELL dt_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: FACS 7f5ffc00 00040
[ 0.000000] ACPI: SSDT fff6d1d6 000AA (v01 DELL st_ex 00001000 INTL 20050624)
[ 0.000000] ACPI: APIC 000fd0b3 00092 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: BOOT 000fd145 00028 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: ASF! 000fd16d 00092 (v32 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: MCFG 000fd1ff 0003E (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: HPET 000fd23d 00038 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: TCPA 000fd499 00032 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: SLIC 000fd275 00176 (v01 DELL B8K 00000014 ASL 00000061)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1150MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007f5ff
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007f5ff
[ 0.000000] On node 0 totalpages: 521614
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5534200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2301 pages used for memmap
[ 0.000000] HighMem zone: 292100 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x05] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x07] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x05] lapic_id[0x00] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x06] lapic_id[0x01] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x07] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x08] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high level lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x08] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 8 CPUs, 6 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:60000000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f7769000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 517537
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=737fbe2d-c410-4de9-8c31-460cf9022382 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4173688 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007f5ff)
[ 0.000000] Memory: 2045084k/2086908k available (3495k kernel code, 41372k reserved, 1237k data, 416k init, 1177604k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:744 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2127.938 MHz processor.
[ 0.004003] Calibrating delay loop (skipped), value calculated using timer frequency.. 4255.87 BogoMIPS (lpj=8511752)
[ 0.004008] pid_max: default: 32768 minimum: 301
[ 0.004058] Security Framework initialized
[ 0.004063] AppArmor: AppArmor disabled by boot time parameter
[ 0.004083] Mount-cache hash table entries: 512
[ 0.008111] Initializing cgroup subsys cpuacct
[ 0.008114] Initializing cgroup subsys memory
[ 0.008125] Initializing cgroup subsys devices
[ 0.008127] Initializing cgroup subsys freezer
[ 0.008130] Initializing cgroup subsys net_cls
[ 0.008132] Initializing cgroup subsys blkio
[ 0.008140] Initializing cgroup subsys perf_event
[ 0.008168] Disabled fast string operations
[ 0.008172] CPU: Physical Processor ID: 0
[ 0.008174] CPU: Processor Core ID: 0
[ 0.008177] mce: CPU supports 6 MCE banks
[ 0.008184] CPU0: Thermal monitoring enabled (TM2)
[ 0.008242] ACPI: Core revision 20120320
[ 0.136055] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.136409] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.176390] CPU0: Intel(R) Core(TM)2 CPU 6400 @ 2.13GHz stepping 02
[ 0.180010] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.180010] PEBS disabled due to CPU errata.
[ 0.180010] ... version: 2
[ 0.180010] ... bit width: 40
[ 0.180010] ... generic registers: 2
[ 0.180010] ... value mask: 000000ffffffffff
[ 0.180010] ... max period: 000000007fffffff
[ 0.180010] ... fixed-purpose events: 3
[ 0.180010] ... event mask: 0000000700000003
[ 0.188388] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.200037] CPU 1 irqstacks, hard=f5114000 soft=f5116000
[ 0.200041] Booting Node 0, Processors #1
[ 0.008000] Initializing CPU#1
[ 0.008000] Disabled fast string operations
[ 0.212045] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.212093] Brought up 2 CPUs
[ 0.212097] Total of 2 processors activated (8511.75 BogoMIPS).
[ 0.213211] devtmpfs: initialized
[ 0.213211] PM: Registering ACPI NVS region [mem 0x7f5ffc00-0x7f601bff] (8192 bytes)
[ 0.213211] Dell OptiPlex 745 series board detected. Selecting BIOS-method for reboots.
[ 0.213211] dummy:
[ 0.213211] NET: Registered protocol family 16
[ 0.213211] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.213211] ACPI: bus type pci registered
[ 0.213211] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.213211] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.213211] PCI: Using MMCONFIG for extended config space
[ 0.213211] PCI: Using configuration type 1 for base access
[ 0.216092] bio: create slab <bio-0> at 0
[ 0.216142] ACPI: Added _OSI(Module Device)
[ 0.216142] ACPI: Added _OSI(Processor Device)
[ 0.216142] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.216142] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.217256] ACPI: EC: Look up EC in DSDT
[ 0.245971] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.265067] ACPI Warning: Incorrect checksum in table [TCPA] - 0x00, should be 0x89 (20120320/tbutils-323)
[ 0.265278] ACPI: Interpreter enabled
[ 0.265296] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.265334] ACPI: Using IOAPIC for interrupt routing
[ 0.378464] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.378473] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.386466] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.403555] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000effff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x000f0000-0x000fffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xf0000000-0xfec00000] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0x80000000-0xdfffffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xff980800-0xff980bff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xff97c000-0xff97ffff] (ignored)
[ 0.403555] pci_root PNP0A03:00: host bridge window [mem 0xfed20000-0xfed9ffff] (ignored)
[ 0.403555] PCI: root bus 00: using default resources
[ 0.403555] PCI host bridge to bus 0000:00
[ 0.403555] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.403555] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.403555] pci 0000:00:00.0: [8086:2990] type 00 class 0x060000
[ 0.403555] pci 0000:00:01.0: [8086:2991] type 01 class 0x060400
[ 0.403555] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:02.0: [8086:2992] type 00 class 0x030000
[ 0.403555] pci 0000:00:02.0: reg 10: [mem 0xfea00000-0xfeafffff]
[ 0.403555] pci 0000:00:02.0: reg 18: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.403555] pci 0000:00:02.0: reg 20: [io 0xecb8-0xecbf]
[ 0.403555] pci 0000:00:02.1: [8086:2993] type 00 class 0x038000
[ 0.403555] pci 0000:00:02.1: reg 10: [mem 0xfeb00000-0xfebfffff]
[ 0.403555] pci 0000:00:1a.0: [8086:2834] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1a.0: reg 20: [io 0xff20-0xff3f]
[ 0.403555] pci 0000:00:1a.1: [8086:2835] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1a.1: reg 20: [io 0xff00-0xff1f]
[ 0.403555] pci 0000:00:1a.7: [8086:283a] type 00 class 0x0c0320
[ 0.403555] pci 0000:00:1a.7: reg 10: [mem 0xfe9fbc00-0xfe9fbfff]
[ 0.403555] pci 0000:00:1a.7: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1b.0: [8086:284b] type 00 class 0x040300
[ 0.403555] pci 0000:00:1b.0: reg 10: [mem 0xfe9fc000-0xfe9fffff 64bit]
[ 0.403555] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1c.0: [8086:283f] type 01 class 0x060400
[ 0.403555] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1c.4: [8086:2847] type 01 class 0x060400
[ 0.403555] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1d.0: [8086:2830] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1d.0: reg 20: [io 0xff80-0xff9f]
[ 0.403555] pci 0000:00:1d.1: [8086:2831] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1d.1: reg 20: [io 0xff60-0xff7f]
[ 0.403555] pci 0000:00:1d.2: [8086:2832] type 00 class 0x0c0300
[ 0.403555] pci 0000:00:1d.2: reg 20: [io 0xff40-0xff5f]
[ 0.403555] pci 0000:00:1d.7: [8086:2836] type 00 class 0x0c0320
[ 0.403555] pci 0000:00:1d.7: reg 10: [mem 0xff980800-0xff980bff]
[ 0.403555] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.403555] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.403555] pci 0000:00:1f.0: [8086:2810] type 00 class 0x060100
[ 0.403555] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0c00 (mask 007f)
[ 0.403555] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 00e0 (mask 0007)
[ 0.403555] pci 0000:00:1f.2: [8086:2820] type 00 class 0x01018f
[ 0.404038] pci 0000:00:1f.2: reg 10: [io 0xfe00-0xfe07]
[ 0.404047] pci 0000:00:1f.2: reg 14: [io 0xfe10-0xfe13]
[ 0.404056] pci 0000:00:1f.2: reg 18: [io 0xfe20-0xfe27]
[ 0.404066] pci 0000:00:1f.2: reg 1c: [io 0xfe30-0xfe33]
[ 0.404075] pci 0000:00:1f.2: reg 20: [io 0xfec0-0xfecf]
[ 0.404084] pci 0000:00:1f.2: reg 24: [io 0xecc0-0xeccf]
[ 0.404109] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.404124] pci 0000:00:1f.3: [8086:283e] type 00 class 0x0c0500
[ 0.404137] pci 0000:00:1f.3: reg 10: [mem 0xfe9fbb00-0xfe9fbbff]
[ 0.404167] pci 0000:00:1f.3: reg 20: [io 0xece0-0xecff]
[ 0.404202] pci 0000:00:1f.5: [8086:2825] type 00 class 0x010185
[ 0.404217] pci 0000:00:1f.5: reg 10: [io 0xfe40-0xfe47]
[ 0.404226] pci 0000:00:1f.5: reg 14: [io 0xfe50-0xfe53]
[ 0.404235] pci 0000:00:1f.5: reg 18: [io 0xfe60-0xfe67]
[ 0.404245] pci 0000:00:1f.5: reg 1c: [io 0xfe70-0xfe73]
[ 0.404254] pci 0000:00:1f.5: reg 20: [io 0xfed0-0xfedf]
[ 0.404263] pci 0000:00:1f.5: reg 24: [io 0xecd0-0xecdf]
[ 0.404287] pci 0000:00:1f.5: PME# supported from D3hot
[ 0.404328] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.404334] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.404379] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 0.404386] pci 0000:00:1c.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 0.404459] pci 0000:03:00.0: [14e4:167a] type 00 class 0x020000
[ 0.404485] pci 0000:03:00.0: reg 10: [mem 0xfe6f0000-0xfe6fffff 64bit]
[ 0.404589] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 0.412044] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[ 0.412052] pci 0000:00:1c.4: bridge window [mem 0xfe600000-0xfe6fffff]
[ 0.412096] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.412114] pci 0000:04:00.0: reg 10: [mem 0xfe5f0000-0xfe5fffff]
[ 0.412231] pci 0000:00:1e.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.412239] pci 0000:00:1e.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 0.412248] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.412252] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.412284] pci_bus 0000:00: on NUMA node 0
[ 0.412289] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.413124] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI4._PRT]
[ 0.413770] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI2._PRT]
[ 0.414190] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
[ 0.414557] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI5._PRT]
[ 0.414963] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 1.943124] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 15)
[ 1.943934] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 *10 11 12 15)
[ 1.944740] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 7 9 10 11 12 15)
[ 1.945533] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 1.946343] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 1.947136] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11 12 15) *0, disabled.
[ 1.947934] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 *9 10 11 12 15)
[ 1.948743] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 *5 6 7 9 10 11 12 15)
[ 1.948986] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 1.948986] vgaarb: loaded
[ 1.948986] vgaarb: bridge control possible 0000:00:02.0
[ 1.948986] PCI: Using ACPI for IRQ routing
[ 1.955295] PCI: pci_cache_line_size set to 64 bytes
[ 1.955382] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 1.955386] reserve RAM buffer: 000000007f5ffc00 - 000000007fffffff
[ 1.955559] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 1.955566] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 1.957143] Switching to clocksource hpet
[ 1.957213] pnp: PnP ACPI init
[ 1.957227] ACPI: bus type pnp registered
[ 1.965375] pnp 00:00: [bus 00-ff]
[ 1.965379] pnp 00:00: [io 0x0cf8-0x0cff]
[ 1.965383] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 1.965385] pnp 00:00: [io 0x0d00-0xffff window]
[ 1.965389] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 1.965391] pnp 00:00: [mem 0x000c0000-0x000effff window]
[ 1.965394] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 1.965397] pnp 00:00: [mem 0xf0000000-0xfec00000 window]
[ 1.965400] pnp 00:00: [mem 0x80000000-0xdfffffff window]
[ 1.965403] pnp 00:00: [mem 0xf0000000-0xefffffff window disabled]
[ 1.965406] pnp 00:00: [mem 0xff980800-0xff980bff window]
[ 1.965409] pnp 00:00: [mem 0xff97c000-0xff97ffff window]
[ 1.965412] pnp 00:00: [mem 0xfed20000-0xfed9ffff window]
[ 1.965460] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 1.969462] pnp 00:01: [io 0x0060]
[ 1.969465] pnp 00:01: [io 0x0064]
[ 1.969467] pnp 00:01: [io 0x0062-0x0063]
[ 1.969470] pnp 00:01: [io 0x0065-0x006f]
[ 1.969473] pnp 00:01: [io 0x00e0-0x00ef]
[ 1.969475] pnp 00:01: [io 0x0800-0x085f]
[ 1.969478] pnp 00:01: [io 0x0c00-0x0c7f]
[ 1.969480] pnp 00:01: [io 0x0860-0x08ff]
[ 1.969541] system 00:01: [io 0x0800-0x085f] has been reserved
[ 1.969545] system 00:01: [io 0x0c00-0x0c7f] has been reserved
[ 1.969549] system 00:01: [io 0x0860-0x08ff] has been reserved
[ 1.969553] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 1.969844] pnp 00:02: [io 0x0080-0x009f]
[ 1.969847] pnp 00:02: [io 0x0000-0x001f]
[ 1.969849] pnp 00:02: [io 0x00c0-0x00df]
[ 1.969853] pnp 00:02: [dma 4]
[ 1.969887] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 1.970113] pnp 00:03: [io 0x00f0-0x00ff]
[ 1.970121] pnp 00:03: [irq 13]
[ 1.970158] pnp 00:03: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 1.970372] pnp 00:04: [io 0x0061]
[ 1.970408] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 1.970631] pnp 00:05: [io 0x0070-0x007f]
[ 1.970638] pnp 00:05: [irq 8]
[ 1.970674] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 1.979183] pnp 00:06: [io 0x03f0-0x03f5]
[ 1.979187] pnp 00:06: [io 0x03f7]
[ 1.979192] pnp 00:06: [irq 6]
[ 1.979195] pnp 00:06: [dma 2]
[ 1.979717] pnp 00:06: Plug and Play ACPI device, IDs PNP0700 (active)
[ 1.992767] pnp 00:07: [io 0x0378-0x037f]
[ 1.992770] pnp 00:07: [io 0x0778-0x077f]
[ 1.992776] pnp 00:07: [irq 7]
[ 1.992779] pnp 00:07: [dma 0 disabled]
[ 1.994011] pnp 00:07: Plug and Play ACPI device, IDs PNP0401 (active)
[ 2.000775] pnp 00:08: [io 0x03f8-0x03ff]
[ 2.000781] pnp 00:08: [irq 4]
[ 2.001207] pnp 00:08: Plug and Play ACPI device, IDs PNP0501 (active)
[ 2.023081] pnp 00:09: [mem 0x00000000-0x0009ffff]
[ 2.023085] pnp 00:09: [mem 0x00100000-0x00ffffff]
[ 2.023088] pnp 00:09: [mem 0x01000000-0x7f5ffbff]
[ 2.023090] pnp 00:09: [mem 0x000f0000-0x000fffff]
[ 2.023093] pnp 00:09: [mem 0x000c0000-0x000cffff]
[ 2.023096] pnp 00:09: [mem 0xfec00000-0xfecfffff]
[ 2.023099] pnp 00:09: [mem 0xfee00000-0xfeefffff]
[ 2.023102] pnp 00:09: [mem 0xffb00000-0xffbfffff]
[ 2.023104] pnp 00:09: [mem 0xffc00000-0xffffffff]
[ 2.023176] system 00:09: [mem 0x00000000-0x0009ffff] could not be reserved
[ 2.023180] system 00:09: [mem 0x00100000-0x00ffffff] could not be reserved
[ 2.023184] system 00:09: [mem 0x01000000-0x7f5ffbff] could not be reserved
[ 2.023188] system 00:09: [mem 0x000f0000-0x000fffff] could not be reserved
[ 2.023192] system 00:09: [mem 0x000c0000-0x000cffff] could not be reserved
[ 2.023195] system 00:09: [mem 0xfec00000-0xfecfffff] could not be reserved
[ 2.023199] system 00:09: [mem 0xfee00000-0xfeefffff] has been reserved
[ 2.023202] system 00:09: [mem 0xffb00000-0xffbfffff] has been reserved
[ 2.023206] system 00:09: [mem 0xffc00000-0xffffffff] has been reserved
[ 2.023210] system 00:09: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 2.026395] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 2.026398] pnp 00:0a: [mem 0xfeda0000-0xfedacfff]
[ 2.026401] pnp 00:0a: [io 0x0100-0x01fe]
[ 2.026404] pnp 00:0a: [io 0x0200-0x0277]
[ 2.026406] pnp 00:0a: [io 0x0280-0x02e7]
[ 2.026409] pnp 00:0a: [io 0x02f0-0x02f7]
[ 2.026411] pnp 00:0a: [io 0x0300-0x0377]
[ 2.026414] pnp 00:0a: [io 0x0380-0x03bb]
[ 2.026417] pnp 00:0a: [io 0x03c0-0x03e7]
[ 2.026419] pnp 00:0a: [io 0x03f6-0x03f7]
[ 2.026422] pnp 00:0a: [io 0x0400-0x04cf]
[ 2.026424] pnp 00:0a: [io 0x04d2-0x057f]
[ 2.026427] pnp 00:0a: [io 0x0580-0x0677]
[ 2.026431] pnp 00:0a: [io 0x0680-0x0777]
[ 2.026433] pnp 00:0a: [io 0x0780-0x07bb]
[ 2.026436] pnp 00:0a: [io 0x07c0-0x07ff]
[ 2.026438] pnp 00:0a: [io 0x08e0-0x08ff]
[ 2.026441] pnp 00:0a: [io 0x0900-0x09fe]
[ 2.026443] pnp 00:0a: [io 0x0a00-0x0afe]
[ 2.026446] pnp 00:0a: [io 0x0b00-0x0bfe]
[ 2.026449] pnp 00:0a: [io 0x0c80-0x0caf]
[ 2.026451] pnp 00:0a: [io 0x0cc0-0x0cf7]
[ 2.026454] pnp 00:0a: [io 0x0d00-0x0dfe]
[ 2.026456] pnp 00:0a: [io 0x0e00-0x0efe]
[ 2.026459] pnp 00:0a: [io 0x0f00-0x0ffe]
[ 2.026461] pnp 00:0a: [io 0x2000-0x20fe]
[ 2.026464] pnp 00:0a: [io 0x2100-0x21fe]
[ 2.026466] pnp 00:0a: [io 0x2200-0x22fe]
[ 2.026469] pnp 00:0a: [io 0x2300-0x23fe]
[ 2.026471] pnp 00:0a: [io 0x2400-0x24fe]
[ 2.026474] pnp 00:0a: [io 0x2500-0x25fe]
[ 2.026476] pnp 00:0a: [io 0x2600-0x26fe]
[ 2.026479] pnp 00:0a: [io 0x2700-0x27fe]
[ 2.026482] pnp 00:0a: [io 0x2800-0x28fe]
[ 2.026484] pnp 00:0a: [io 0x2900-0x29fe]
[ 2.026487] pnp 00:0a: [io 0x2a00-0x2afe]
[ 2.026489] pnp 00:0a: [io 0x2b00-0x2bfe]
[ 2.026492] pnp 00:0a: [io 0x2c00-0x2cfe]
[ 2.026494] pnp 00:0a: [io 0x2d00-0x2dfe]
[ 2.026497] pnp 00:0a: [io 0x2e00-0x2efe]
[ 2.026499] pnp 00:0a: [io 0x2f00-0x2ffe]
[ 2.026502] pnp 00:0a: [io 0x5000-0x50fe]
[ 2.026504] pnp 00:0a: [io 0x5100-0x51fe]
[ 2.026507] pnp 00:0a: [io 0x5200-0x52fe]
[ 2.026510] pnp 00:0a: [io 0x5300-0x53fe]
[ 2.026512] pnp 00:0a: [io 0x5400-0x54fe]
[ 2.026515] pnp 00:0a: [io 0x5500-0x55fe]
[ 2.026517] pnp 00:0a: [io 0x5600-0x56fe]
[ 2.026520] pnp 00:0a: [io 0x5700-0x57fe]
[ 2.026522] pnp 00:0a: [io 0x5800-0x58fe]
[ 2.026525] pnp 00:0a: [io 0x5900-0x59fe]
[ 2.026527] pnp 00:0a: [io 0x5a00-0x5afe]
[ 2.026530] pnp 00:0a: [io 0x5b00-0x5bfe]
[ 2.026532] pnp 00:0a: [io 0x5c00-0x5cfe]
[ 2.026535] pnp 00:0a: [io 0x5d00-0x5dfe]
[ 2.026537] pnp 00:0a: [io 0x5e00-0x5efe]
[ 2.026540] pnp 00:0a: [io 0x5f00-0x5ffe]
[ 2.026543] pnp 00:0a: [io 0x6000-0x60fe]
[ 2.026545] pnp 00:0a: [io 0x6100-0x61fe]
[ 2.026548] pnp 00:0a: [io 0x6200-0x62fe]
[ 2.026550] pnp 00:0a: [io 0x6300-0x63fe]
[ 2.026553] pnp 00:0a: [io 0x6400-0x64fe]
[ 2.026555] pnp 00:0a: [io 0x6500-0x65fe]
[ 2.026558] pnp 00:0a: [io 0x6600-0x66fe]
[ 2.026560] pnp 00:0a: [io 0x6700-0x67fe]
[ 2.026563] pnp 00:0a: [io 0x6800-0x68fe]
[ 2.026566] pnp 00:0a: [io 0x6900-0x69fe]
[ 2.026568] pnp 00:0a: [io 0x6a00-0x6afe]
[ 2.026571] pnp 00:0a: [io 0x6b00-0x6bfe]
[ 2.026573] pnp 00:0a: [io 0x6c00-0x6cfe]
[ 2.026576] pnp 00:0a: [io 0x6d00-0x6dfe]
[ 2.026578] pnp 00:0a: [io 0x6e00-0x6efe]
[ 2.026582] pnp 00:0a: [io 0x6f00-0x6ffe]
[ 2.026585] pnp 00:0a: [io 0xa000-0xa0fe]
[ 2.026587] pnp 00:0a: [io 0xa100-0xa1fe]
[ 2.026590] pnp 00:0a: [io 0xa200-0xa2fe]
[ 2.026592] pnp 00:0a: [io 0xa300-0xa3fe]
[ 2.026595] pnp 00:0a: [io 0xa400-0xa4fe]
[ 2.026597] pnp 00:0a: [io 0xa500-0xa5fe]
[ 2.026600] pnp 00:0a: [io 0xa600-0xa6fe]
[ 2.026602] pnp 00:0a: [io 0xa700-0xa7fe]
[ 2.026605] pnp 00:0a: [io 0xa800-0xa8fe]
[ 2.026607] pnp 00:0a: [io 0xa900-0xa9fe]
[ 2.026610] pnp 00:0a: [io 0xaa00-0xaafe]
[ 2.026612] pnp 00:0a: [io 0xab00-0xabfe]
[ 2.026615] pnp 00:0a: [io 0xac00-0xacfe]
[ 2.026618] pnp 00:0a: [io 0xad00-0xadfe]
[ 2.026620] pnp 00:0a: [io 0xae00-0xaefe]
[ 2.026623] pnp 00:0a: [io 0xaf00-0xaffe]
[ 2.026862] system 00:0a: [io 0x0100-0x01fe] has been reserved
[ 2.026865] system 00:0a: [io 0x0200-0x0277] has been reserved
[ 2.026869] system 00:0a: [io 0x0280-0x02e7] has been reserved
[ 2.026872] system 00:0a: [io 0x02f0-0x02f7] has been reserved
[ 2.026875] system 00:0a: [io 0x0300-0x0377] has been reserved
[ 2.026879] system 00:0a: [io 0x0380-0x03bb] has been reserved
[ 2.026882] system 00:0a: [io 0x03c0-0x03e7] could not be reserved
[ 2.026886] system 00:0a: [io 0x03f6-0x03f7] has been reserved
[ 2.026889] system 00:0a: [io 0x0400-0x04cf] has been reserved
[ 2.026892] system 00:0a: [io 0x04d2-0x057f] has been reserved
[ 2.026896] system 00:0a: [io 0x0580-0x0677] has been reserved
[ 2.026899] system 00:0a: [io 0x0680-0x0777] has been reserved
[ 2.026902] system 00:0a: [io 0x0780-0x07bb] has been reserved
[ 2.026906] system 00:0a: [io 0x07c0-0x07ff] has been reserved
[ 2.026909] system 00:0a: [io 0x08e0-0x08ff] has been reserved
[ 2.026912] system 00:0a: [io 0x0900-0x09fe] has been reserved
[ 2.026916] system 00:0a: [io 0x0a00-0x0afe] has been reserved
[ 2.026919] system 00:0a: [io 0x0b00-0x0bfe] has been reserved
[ 2.026922] system 00:0a: [io 0x0c80-0x0caf] has been reserved
[ 2.026926] system 00:0a: [io 0x0cc0-0x0cf7] has been reserved
[ 2.026929] system 00:0a: [io 0x0d00-0x0dfe] has been reserved
[ 2.026932] system 00:0a: [io 0x0e00-0x0efe] has been reserved
[ 2.026936] system 00:0a: [io 0x0f00-0x0ffe] has been reserved
[ 2.026939] system 00:0a: [io 0x2000-0x20fe] has been reserved
[ 2.026942] system 00:0a: [io 0x2100-0x21fe] has been reserved
[ 2.026946] system 00:0a: [io 0x2200-0x22fe] has been reserved
[ 2.026951] system 00:0a: [io 0x2300-0x23fe] has been reserved
[ 2.026954] system 00:0a: [io 0x2400-0x24fe] has been reserved
[ 2.026958] system 00:0a: [io 0x2500-0x25fe] has been reserved
[ 2.026961] system 00:0a: [io 0x2600-0x26fe] has been reserved
[ 2.026964] system 00:0a: [io 0x2700-0x27fe] has been reserved
[ 2.026968] system 00:0a: [io 0x2800-0x28fe] has been reserved
[ 2.026971] system 00:0a: [io 0x2900-0x29fe] has been reserved
[ 2.026975] system 00:0a: [io 0x2a00-0x2afe] has been reserved
[ 2.026978] system 00:0a: [io 0x2b00-0x2bfe] has been reserved
[ 2.026982] system 00:0a: [io 0x2c00-0x2cfe] has been reserved
[ 2.026985] system 00:0a: [io 0x2d00-0x2dfe] has been reserved
[ 2.026988] system 00:0a: [io 0x2e00-0x2efe] has been reserved
[ 2.026992] system 00:0a: [io 0x2f00-0x2ffe] has been reserved
[ 2.026995] system 00:0a: [io 0x5000-0x50fe] has been reserved
[ 2.026999] system 00:0a: [io 0x5100-0x51fe] has been reserved
[ 2.027002] system 00:0a: [io 0x5200-0x52fe] has been reserved
[ 2.027006] system 00:0a: [io 0x5300-0x53fe] has been reserved
[ 2.027009] system 00:0a: [io 0x5400-0x54fe] has been reserved
[ 2.027013] system 00:0a: [io 0x5500-0x55fe] has been reserved
[ 2.027016] system 00:0a: [io 0x5600-0x56fe] has been reserved
[ 2.027020] system 00:0a: [io 0x5700-0x57fe] has been reserved
[ 2.027023] system 00:0a: [io 0x5800-0x58fe] has been reserved
[ 2.027027] system 00:0a: [io 0x5900-0x59fe] has been reserved
[ 2.027030] system 00:0a: [io 0x5a00-0x5afe] has been reserved
[ 2.027034] system 00:0a: [io 0x5b00-0x5bfe] has been reserved
[ 2.027037] system 00:0a: [io 0x5c00-0x5cfe] has been reserved
[ 2.027041] system 00:0a: [io 0x5d00-0x5dfe] has been reserved
[ 2.027044] system 00:0a: [io 0x5e00-0x5efe] has been reserved
[ 2.027048] system 00:0a: [io 0x5f00-0x5ffe] has been reserved
[ 2.027051] system 00:0a: [io 0x6000-0x60fe] has been reserved
[ 2.027055] system 00:0a: [io 0x6100-0x61fe] has been reserved
[ 2.027059] system 00:0a: [io 0x6200-0x62fe] has been reserved
[ 2.027062] system 00:0a: [io 0x6300-0x63fe] has been reserved
[ 2.027066] system 00:0a: [io 0x6400-0x64fe] has been reserved
[ 2.027070] system 00:0a: [io 0x6500-0x65fe] has been reserved
[ 2.027073] system 00:0a: [io 0x6600-0x66fe] has been reserved
[ 2.027077] system 00:0a: [io 0x6700-0x67fe] has been reserved
[ 2.027080] system 00:0a: [io 0x6800-0x68fe] has been reserved
[ 2.027084] system 00:0a: [io 0x6900-0x69fe] has been reserved
[ 2.027087] system 00:0a: [io 0x6a00-0x6afe] has been reserved
[ 2.027091] system 00:0a: [io 0x6b00-0x6bfe] has been reserved
[ 2.027094] system 00:0a: [io 0x6c00-0x6cfe] has been reserved
[ 2.027098] system 00:0a: [io 0x6d00-0x6dfe] has been reserved
[ 2.027101] system 00:0a: [io 0x6e00-0x6efe] has been reserved
[ 2.027105] system 00:0a: [io 0x6f00-0x6ffe] has been reserved
[ 2.027108] system 00:0a: [io 0xa000-0xa0fe] has been reserved
[ 2.027112] system 00:0a: [io 0xa100-0xa1fe] has been reserved
[ 2.027116] system 00:0a: [io 0xa200-0xa2fe] has been reserved
[ 2.027119] system 00:0a: [io 0xa300-0xa3fe] has been reserved
[ 2.027123] system 00:0a: [io 0xa400-0xa4fe] has been reserved
[ 2.027126] system 00:0a: [io 0xa500-0xa5fe] has been reserved
[ 2.027130] system 00:0a: [io 0xa600-0xa6fe] has been reserved
[ 2.027134] system 00:0a: [io 0xa700-0xa7fe] has been reserved
[ 2.027137] system 00:0a: [io 0xa800-0xa8fe] has been reserved
[ 2.027141] system 00:0a: [io 0xa900-0xa9fe] has been reserved
[ 2.027144] system 00:0a: [io 0xaa00-0xaafe] has been reserved
[ 2.027148] system 00:0a: [io 0xab00-0xabfe] has been reserved
[ 2.027153] system 00:0a: [io 0xac00-0xacfe] has been reserved
[ 2.027157] system 00:0a: [io 0xad00-0xadfe] has been reserved
[ 2.027161] system 00:0a: [io 0xae00-0xaefe] has been reserved
[ 2.027164] system 00:0a: [io 0xaf00-0xaffe] has been reserved
[ 2.027168] system 00:0a: [mem 0xe0000000-0xefffffff] has been reserved
[ 2.027172] system 00:0a: [mem 0xfeda0000-0xfedacfff] has been reserved
[ 2.027176] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 2.027403] pnp 00:0b: [mem 0xfed00000-0xfed003ff]
[ 2.027449] pnp 00:0b: Plug and Play ACPI device, IDs PNP0103 (active)
[ 2.027457] pnp: PnP ACPI: found 12 devices
[ 2.027459] ACPI: ACPI bus type pnp unregistered
[ 2.027463] PnPBIOS: Disabled by ACPI PNP
[ 2.064895] pci 0000:00:1c.0: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 2.064900] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 2.064910] pci 0000:00:1c.4: bridge window [io 0x1000-0x0fff] to [bus 03-03] add_size 1000
[ 2.064914] pci 0000:00:1c.4: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 2.064928] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.064932] pci 0000:00:1c.4: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 2.064936] pci 0000:00:1c.0: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.064939] pci 0000:00:1c.4: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 2.064944] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 2.064948] pci 0000:00:1c.4: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 2.064952] pci 0000:00:1c.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.064956] pci 0000:00:1c.4: BAR 13: assigned [io 0x3000-0x3fff]
[ 2.064960] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 2.064965] pci 0000:00:01.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 2.064972] pci 0000:00:1c.0: PCI bridge to [bus 02-02]
[ 2.064976] pci 0000:00:1c.0: bridge window [io 0x1000-0x1fff]
[ 2.064981] pci 0000:00:1c.0: bridge window [mem 0xfe700000-0xfe7fffff]
[ 2.064986] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 2.064993] pci 0000:00:1c.4: PCI bridge to [bus 03-03]
[ 2.064996] pci 0000:00:1c.4: bridge window [io 0x3000-0x3fff]
[ 2.065002] pci 0000:00:1c.4: bridge window [mem 0xfe600000-0xfe6fffff]
[ 2.065007] pci 0000:00:1c.4: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 2.065014] pci 0000:00:1e.0: PCI bridge to [bus 04-04]
[ 2.065019] pci 0000:00:1e.0: bridge window [mem 0xfe500000-0xfe5fffff]
[ 2.065057] pci 0000:00:1e.0: setting latency timer to 64
[ 2.065061] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 2.065064] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 2.065067] pci_bus 0000:01: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 2.065070] pci_bus 0000:02: resource 0 [io 0x1000-0x1fff]
[ 2.065073] pci_bus 0000:02: resource 1 [mem 0xfe700000-0xfe7fffff]
[ 2.065076] pci_bus 0000:02: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 2.065079] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 2.065082] pci_bus 0000:03: resource 1 [mem 0xfe600000-0xfe6fffff]
[ 2.065085] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 2.065088] pci_bus 0000:04: resource 1 [mem 0xfe500000-0xfe5fffff]
[ 2.065091] pci_bus 0000:04: resource 4 [io 0x0000-0xffff]
[ 2.065094] pci_bus 0000:04: resource 5 [mem 0x00000000-0xffffffff]
[ 2.065179] NET: Registered protocol family 2
[ 2.065263] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 2.065514] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 2.065860] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 2.066036] TCP: Hash tables configured (established 131072 bind 65536)
[ 2.066038] TCP: reno registered
[ 2.066042] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 2.066050] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 2.066164] NET: Registered protocol family 1
[ 2.066186] pci 0000:00:02.0: Boot video device
[ 2.066401] PCI: CLS 64 bytes, default 64
[ 2.066460] Unpacking initramfs...
[ 2.376102] Freeing initrd memory: 13720k freed
[ 2.383647] Simple Boot Flag at 0x7a set to 0x1
[ 2.384281] audit: initializing netlink socket (disabled)
[ 2.384299] type=2000 audit(1539042464.380:1): initialized
[ 2.397019] highmem bounce pool size: 64 pages
[ 2.397026] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.397246] VFS: Disk quotas dquot_6.5.2
[ 2.397283] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.397374] msgmni has been set to 1721
[ 2.397574] alg: No test for stdrng (krng)
[ 2.397609] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.397614] io scheduler noop registered
[ 2.397616] io scheduler deadline registered
[ 2.397637] io scheduler cfq registered (default)
[ 2.397923] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.397950] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.397953] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.398656] GHES: HEST is not enabled!
[ 2.398670] isapnp: Scanning for PnP cards...
[ 2.751699] isapnp: No Plug & Play device found
[ 2.751760] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.772131] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.792846] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.793271] Linux agpgart interface v0.103
[ 2.793407] agpgart-intel 0000:00:00.0: Intel 965Q Chipset
[ 2.793482] agpgart-intel 0000:00:00.0: detected gtt size: 524288K total, 262144K mappable
[ 2.793969] agpgart-intel 0000:00:00.0: detected 8192K stolen memory
[ 2.794090] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000
[ 2.794270] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 2.797173] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.797211] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.797337] mousedev: PS/2 mouse device common for all mice
[ 2.797400] rtc_cmos 00:05: RTC can wake from S4
[ 2.797533] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 2.797558] rtc0: alarms up to one day, 242 bytes nvram, hpet irqs
[ 2.797718] TCP: cubic registered
[ 2.797779] NET: Registered protocol family 10
[ 2.798063] Mobile IPv6
[ 2.798067] NET: Registered protocol family 17
[ 2.798072] Registering the dns_resolver key type
[ 2.798138] Using IPI No-Shortcut mode
[ 2.798262] PM: Hibernation image not present or could not be loaded.
[ 2.798275] registered taskstats version 1
[ 2.798679] rtc_cmos 00:05: setting system clock to 2018-10-08 23:47:45 UTC (1539042465)
[ 2.798783] Freeing unused kernel memory: 416k freed
[ 2.799001] Write protecting the kernel text: 3496k
[ 2.799028] Write protecting the kernel read-only data: 984k
[ 2.811888] udevd[49]: starting version 175
[ 2.832846] usbcore: registered new interface driver usbfs
[ 2.832877] usbcore: registered new interface driver hub
[ 2.837073] usbcore: registered new device driver usb
[ 2.837598] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.837669] ehci_hcd 0000:00:1a.7: setting latency timer to 64
[ 2.837674] ehci_hcd 0000:00:1a.7: EHCI Host Controller
[ 2.837707] ehci_hcd 0000:00:1a.7: new USB bus registered, assigned bus number 1
[ 2.837740] ehci_hcd 0000:00:1a.7: debug port 1
[ 2.846565] SCSI subsystem initialized
[ 2.849421] ehci_hcd 0000:00:1a.7: cache line size of 64 is not supported
[ 2.849449] ehci_hcd 0000:00:1a.7: irq 22, io mem 0xfe9fbc00
[ 2.849497] libata version 3.00 loaded.
[ 2.854227] microcode: CPU0 sig=0x6f2, pf=0x1, revision=0x56
[ 2.857089] uhci_hcd: USB Universal Host Controller Interface driver
[ 2.860030] ehci_hcd 0000:00:1a.7: USB 2.0 started, EHCI 1.00
[ 2.860084] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.860088] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.860092] usb usb1: Product: EHCI Host Controller
[ 2.860094] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.860097] usb usb1: SerialNumber: 0000:00:1a.7
[ 2.860254] hub 1-0:1.0: USB hub found
[ 2.860261] hub 1-0:1.0: 4 ports detected
[ 2.860411] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 2.860415] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 2.860428] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 2
[ 2.860463] ehci_hcd 0000:00:1d.7: debug port 1
[ 2.864546] ehci_hcd 0000:00:1d.7: cache line size of 64 is not supported
[ 2.864572] ehci_hcd 0000:00:1d.7: irq 23, io mem 0xff980800
[ 2.869865] tg3.c:v3.123 (March 21, 2012)
[ 2.876069] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 2.876103] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.876107] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.876110] usb usb2: Product: EHCI Host Controller
[ 2.876113] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.876115] usb usb2: SerialNumber: 0000:00:1d.7
[ 2.876265] hub 2-0:1.0: USB hub found
[ 2.876272] hub 2-0:1.0: 6 ports detected
[ 2.876740] ata_piix 0000:00:1f.2: version 2.13
[ 2.876770] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 2.886043] Floppy drive(s): fd0 is 1.44M
[ 2.893095] tg3 0000:03:00.0: eth0: Tigon3 [partno(BCM95754) rev b002] (PCI Express) MAC address 00:1a:a0:ae:38:fc
[ 2.893100] tg3 0000:03:00.0: eth0: attached PHY is 5787 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 2.893105] tg3 0000:03:00.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 2.893108] tg3 0000:03:00.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 2.902189] FDC 0 is a post-1991 82077
[ 2.908953] microcode: CPU0 updated to revision 0x5d, date = 2010-10-02
[ 2.908969] microcode: CPU1 sig=0x6f2, pf=0x1, revision=0x56
[ 2.911669] microcode: CPU1 updated to revision 0x5d, date = 2010-10-02
[ 2.911722] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 3.032078] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 3.032552] scsi0 : ata_piix
[ 3.032679] scsi1 : ata_piix
[ 3.037584] ata1: SATA max UDMA/133 cmd 0xfe00 ctl 0xfe10 bmdma 0xfec0 irq 20
[ 3.037590] ata2: SATA max UDMA/133 cmd 0xfe20 ctl 0xfe30 bmdma 0xfec8 irq 20
[ 3.037656] uhci_hcd 0000:00:1a.0: setting latency timer to 64
[ 3.037661] uhci_hcd 0000:00:1a.0: UHCI Host Controller
[ 3.037675] uhci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 3.037713] uhci_hcd 0000:00:1a.0: irq 16, io base 0x0000ff20
[ 3.037757] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.037761] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.037764] usb usb3: Product: UHCI Host Controller
[ 3.037766] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.037769] usb usb3: SerialNumber: 0000:00:1a.0
[ 3.037912] hub 3-0:1.0: USB hub found
[ 3.037918] hub 3-0:1.0: 2 ports detected
[ 3.038022] uhci_hcd 0000:00:1a.1: setting latency timer to 64
[ 3.038026] uhci_hcd 0000:00:1a.1: UHCI Host Controller
[ 3.038036] uhci_hcd 0000:00:1a.1: new USB bus registered, assigned bus number 4
[ 3.038074] uhci_hcd 0000:00:1a.1: irq 17, io base 0x0000ff00
[ 3.038116] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.038119] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.038122] usb usb4: Product: UHCI Host Controller
[ 3.038125] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.038128] usb usb4: SerialNumber: 0000:00:1a.1
[ 3.038503] hub 4-0:1.0: USB hub found
[ 3.038509] hub 4-0:1.0: 2 ports detected
[ 3.038612] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 3.038617] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 3.038626] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 5
[ 3.038652] uhci_hcd 0000:00:1d.0: irq 23, io base 0x0000ff80
[ 3.038692] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.038695] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.038698] usb usb5: Product: UHCI Host Controller
[ 3.038701] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.038703] usb usb5: SerialNumber: 0000:00:1d.0
[ 3.038914] hub 5-0:1.0: USB hub found
[ 3.038920] hub 5-0:1.0: 2 ports detected
[ 3.039022] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 3.039026] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 3.039035] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 6
[ 3.039060] uhci_hcd 0000:00:1d.1: irq 17, io base 0x0000ff60
[ 3.039103] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.039106] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.039109] usb usb6: Product: UHCI Host Controller
[ 3.039112] usb usb6: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.039114] usb usb6: SerialNumber: 0000:00:1d.1
[ 3.040046] hub 6-0:1.0: USB hub found
[ 3.040054] hub 6-0:1.0: 2 ports detected
[ 3.040161] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 3.040165] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 3.040175] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 7
[ 3.040218] uhci_hcd 0000:00:1d.2: irq 18, io base 0x0000ff40
[ 3.040262] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[ 3.040265] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.040268] usb usb7: Product: UHCI Host Controller
[ 3.040271] usb usb7: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 3.040274] usb usb7: SerialNumber: 0000:00:1d.2
[ 3.040461] hub 7-0:1.0: USB hub found
[ 3.040467] hub 7-0:1.0: 2 ports detected
[ 3.041723] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 3.196085] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 3.196462] scsi2 : ata_piix
[ 3.196560] scsi3 : ata_piix
[ 3.196624] ata3: SATA max UDMA/133 cmd 0xfe40 ctl 0xfe50 bmdma 0xfed0 irq 20
[ 3.196629] ata4: SATA max UDMA/133 cmd 0xfe60 ctl 0xfe70 bmdma 0xfed8 irq 20
[ 3.348039] usb 3-1: new low-speed USB device number 2 using uhci_hcd
[ 3.380059] Refined TSC clocksource calibration: 2127.999 MHz.
[ 3.380067] Switching to clocksource tsc
[ 3.516104] ata3: SATA link down (SStatus 0 SControl 300)
[ 3.516173] ata4: SATA link down (SStatus 0 SControl 300)
[ 3.520759] usb 3-1: New USB device found, idVendor=0e6a, idProduct=6001
[ 3.520763] usb 3-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.520767] usb 3-1: Product: HID Keyboard Device
[ 3.574317] input: HID Keyboard Device as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.0/input/input0
[ 3.574386] generic-usb 0003:0E6A:6001.0001: input,hidraw0: USB HID v1.10 Keyboard [HID Keyboard Device] on usb-0000:00:1a.0-1/input0
[ 3.596889] input: HID Keyboard Device as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1:1.1/input/input1
[ 3.596962] generic-usb 0003:0E6A:6001.0002: input,hidraw1: USB HID v1.10 Device [HID Keyboard Device] on usb-0000:00:1a.0-1/input1
[ 3.597000] usbcore: registered new interface driver usbhid
[ 3.597002] usbhid: USB HID core driver
[ 3.664039] usb 3-2: new low-speed USB device number 3 using uhci_hcd
[ 3.832105] ata1.00: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.832118] ata1.01: SATA link down (SStatus 4 SControl 300)
[ 3.832326] ata2.00: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 3.832339] ata2.01: SATA link down (SStatus 4 SControl 300)
[ 3.832350] ata2.01: link offline, clearing class 3 to NONE
[ 3.839757] usb 3-2: New USB device found, idVendor=046d, idProduct=c016
[ 3.839762] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.839766] usb 3-2: Product: Optical USB Mouse
[ 3.839769] usb 3-2: Manufacturer: Logitech
[ 3.840154] ata2.00: ATAPI: HL-DT-ST DVDRAM GH15F, EG00, max UDMA/100
[ 3.841064] ata1.00: ATA-8: WDC WD2500BPVT-00JJ5T0, 01.01A01, max UDMA/133
[ 3.841070] ata1.00: 488397168 sectors, multi 8: LBA48 NCQ (depth 0/32)
[ 3.853099] ata1.00: configured for UDMA/133
[ 3.853268] scsi 0:0:0:0: Direct-Access ATA WDC WD2500BPVT-0 01.0 PQ: 0 ANSI: 5
[ 3.856177] ata2.00: configured for UDMA/100
[ 3.856294] input: Logitech Optical USB Mouse as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.0/input/input2
[ 3.856388] generic-usb 0003:046D:C016.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech Optical USB Mouse] on usb-0000:00:1a.0-2/input0
[ 3.973820] scsi 1:0:0:0: CD-ROM HL-DT-ST DVDRAM GH15F EG00 PQ: 0 ANSI: 5
[ 3.984145] sd 0:0:0:0: [sda] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 3.984150] sd 0:0:0:0: [sda] 4096-byte physical blocks
[ 3.984220] sd 0:0:0:0: [sda] Write Protect is off
[ 3.984223] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.984254] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 4.047404] sda: sda1 sda2 < sda5 >
[ 4.047860] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.049718] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.049770] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 4.092423] sr0: scsi3-mmc drive: 40x/40x writer dvd-ram cd/rw xa/form2 cdda tray
[ 4.092429] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 4.092693] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 9.623121] PM: Starting manual resume from disk
[ 9.623125] PM: Hibernation image partition 8:5 present
[ 9.623128] PM: Looking for hibernation image.
[ 9.623508] PM: Image not found (code -22)
[ 9.623513] PM: Hibernation image not present or could not be loaded.
[ 9.720337] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.950385] udevd[345]: starting version 175
[ 12.364900] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 12.364909] ACPI: Power Button [VBTN]
[ 12.365041] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 12.365046] ACPI: Power Button [PWRF]
[ 12.886522] coretemp coretemp.0: Using relative temperature scale!
[ 12.886535] coretemp coretemp.0: Using relative temperature scale!
[ 12.893560] dcdbas dcdbas: Dell Systems Management Base Driver (version 5.6.0-3.2)
[ 12.953500] iTCO_vendor_support: vendor-support=0
[ 13.150769] [drm] Initialized drm 1.1.0 20060810
[ 13.195046] i915 0000:00:02.0: setting latency timer to 64
[ 13.209709] mtrr: type mismatch for d0000000,10000000 old: write-back new: write-combining
[ 13.209712] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 13.209975] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 13.209978] [drm] Driver supports precise vblank timestamp query.
[ 13.210023] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 13.228687] [drm] initialized overlay support
[ 13.275790] fbcon: inteldrmfb (fb0) is primary device
[ 13.281325] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 13.281406] parport_pc 00:07: reported by Plug and Play ACPI
[ 13.281437] iTCO_wdt: unable to reset NO_REBOOT flag, device disabled by hardware/BIOS
[ 13.281467] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 13.323911] Console: switching to colour frame buffer device 240x67
[ 13.331274] fb0: inteldrmfb frame buffer device
[ 13.331277] drm: registered panic notifier
[ 13.331324] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 13.435717] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 15.663864] Adding 4170748k swap on /dev/sda5. Priority:-1 extents:1 across:4170748k
[ 15.679206] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 15.918403] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 16.024934] loop: module loaded
[ 17.333553] RPC: Registered named UNIX socket transport module.
[ 17.333557] RPC: Registered udp transport module.
[ 17.333559] RPC: Registered tcp transport module.
[ 17.333561] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 17.406334] FS-Cache: Loaded
[ 17.437446] NFS: Registering the id_resolver key type
[ 17.437471] FS-Cache: Netfs 'nfs' registered for caching
[ 17.452892] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 19.681877] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input6
[ 20.480523] lp0: using parport0 (interrupt-driven).
[ 20.679971] ppdev: user-space parallel port driver
[ 20.934385] Bluetooth: Core ver 2.16
[ 20.934407] NET: Registered protocol family 31
[ 20.934409] Bluetooth: HCI device and connection manager initialized
[ 20.934413] Bluetooth: HCI socket layer initialized
[ 20.934415] Bluetooth: L2CAP socket layer initialized
[ 20.934421] Bluetooth: SCO socket layer initialized
[ 21.048660] Bluetooth: RFCOMM TTY layer initialized
[ 21.048666] Bluetooth: RFCOMM socket layer initialized
[ 21.048668] Bluetooth: RFCOMM ver 1.11
[ 21.346526] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.346530] Bluetooth: BNEP filters: protocol multicast
[ 24.183660] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.824848] tg3 0000:03:00.0: eth0: Link is up at 1000 Mbps, full duplex
[ 27.824853] tg3 0000:03:00.0: eth0: Flow control is on for TX and on for RX
[ 27.825034] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 38.688278] eth0: no IPv6 routers present
[ 102.699343] I-pipe: head domain RTAI registered.
[ 102.699349] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 102.699408] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 102.699412] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127938000, CPU_FREQ 2127938000
[ 102.699416] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 102.699419] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 8837750
[ 102.752802] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 102.752843] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 102.752848] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 102.752852] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127938000 hz.
[ 102.752854] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 102.760811] RTAI[math]: loaded.
[ 103.039324] hm2: loading Mesa HostMot2 driver version 0.15
[ 103.126744] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 103.126788] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 103.126899] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver
[ 103.126904] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 103.126910] hm2_5i25.0: board fails HM2 registration
[ 103.126926] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 103.494850] hm2: unloading
[ 105.647976] RTAI[math]: unloaded.
[ 105.649980] SCHED releases registered named ALIEN PEDV$D
[ 105.656036] RTAI[malloc]: unloaded.
[ 105.756036] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 105.757994] I-pipe: head domain RTAI unregistered.
[ 105.758044] RTAI[hal]: unmounted.
[ 243.095661] I-pipe: head domain RTAI registered.
[ 243.095667] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 243.095714] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 243.095718] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127938000, CPU_FREQ 2127938000
[ 243.095721] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 243.095724] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 13664000
[ 243.104188] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 243.104230] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 243.104234] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 243.104238] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127938000 hz.
[ 243.104241] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 243.109923] RTAI[math]: loaded.
[ 243.270324] hm2: loading Mesa HostMot2 driver version 0.15
[ 243.272634] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 243.272676] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 243.272855] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver
[ 243.272859] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 243.272866] hm2_5i25.0: board fails HM2 registration
[ 243.272882] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 243.508901] hm2: unloading
[ 245.617540] RTAI[math]: unloaded.
[ 245.619509] SCHED releases registered named ALIEN PEDV$D
[ 245.624801] RTAI[malloc]: unloaded.
[ 245.724031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 245.726075] I-pipe: head domain RTAI unregistered.
[ 245.726120] RTAI[hal]: unmounted.
[ 535.816294] I-pipe: head domain RTAI registered.
[ 535.816300] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 535.816338] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 535.816342] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16623760, CLK_FREQ 2127938000, CPU_FREQ 2127938000
[ 535.816345] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 535.816348] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623760, 16623760, 16562750
[ 535.826566] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 535.826609] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 535.826614] RTAI[sched]: hard timer type/freq = APIC/16623760(Hz); default timing: oneshot; linear timed lists.
[ 535.826617] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127938000 hz.
[ 535.826620] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 535.836340] RTAI[math]: loaded.
[ 535.997339] hm2: loading Mesa HostMot2 driver version 0.15
[ 535.999435] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 535.999477] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 535.999590] hm2/hm2_5i25.0: config.num_encoders=6, but only 2 are available, not loading driver
[ 535.999595] hm2/hm2_5i25.0: failed to parse Module Descriptor 2
[ 535.999601] hm2_5i25.0: board fails HM2 registration
[ 535.999618] hm2_pci: probe of 0000:04:00.0 failed with error -22
[ 536.234413] hm2: unloading
[ 538.346618] RTAI[math]: unloaded.
[ 538.348630] SCHED releases registered named ALIEN PEDV$D
[ 538.354081] RTAI[malloc]: unloaded.
[ 538.452031] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 538.454070] I-pipe: head domain RTAI unregistered.
[ 538.454120] RTAI[hal]: unmounted.
