7i76e error
7 years 4 months ago #136261 by SjCNC
Replied by SjCNC on topic 7i76e error
You say 'try setup before install'. Are you running 'live', booting from a CD or USB? It's been quite some time, but I recall having certain errors when running live, which cleared up once installed. You can install LinuxCNC along with Windows, dual boot. It's worth a try!
6 years 8 months ago - 6 years 8 months ago #157052 by JimPanski
Replied by JimPanski on topic 7i76e error
Hello PCW,
recently I updated my config at my 7i76E setup and switched from a J1900 Celeron with a wheezy installation to a Dell Optiplex System with an I3-2120 CPU and a stretch rt-preemt config.
This was nice until i get the same rt error messages like the author "steos"
Because you mentioned it before
PCW wrote: If you have a Intel or Qualcom MAC you must make some driver setting adjustments with the ethtool utility
and as I am now using a "Intel Corporation 82579LM Gigabit Network Connection (rev 04)" I want to ask if you can give some more details on it.
Thank you for your help!
Greentings
Conny
EDIT:
I think I might have already found the solution here:
for Intel Chipsets you need to turn off IRQ coalescing by :
sudo ethtool -C ethN rx-usecs 0
Please feel free to correct me if I am wrong. But my avg ping times to the 7i76e already went down to ~0.1ms which is about 1/3 of the times without that setting.
Last edit: 6 years 8 months ago by JimPanski.
6 years 8 months ago #157057 by PCW
Replied by PCW on topic 7i76e error
Take a look at the hm2_eth manual page. Its has instructions
for editing the interfaces file to setup the static IP on the host
and turn off the irq coalescing option on the driver (this option will
add a lot of latency to Ethernet communications and needs to be disabled)
man hm2_eth
The following user(s) said Thank You: JimPanski
6 years 8 months ago #157058 by JimPanski
WOW PCW that was quick.
Thank you very much for your advice!
6 years 8 months ago #157076 by bbsr_5a
Replied by bbsr_5a on topic 7i76e error
you can do this in your Network config file
/etc/network/interfaces
hardware-irq-coalesce-rx-usecs 0
6 years 8 months ago #157084 by tommylight
Replied by tommylight on topic 7i76e error
bbsr_5a wrote: you can do this in your Network config file
Not IRQ, !
Eth.
PCW mentioned it several times, ETH.
Just do a search for it.
