homing with 5i25,7i76
- lendrum
20 Dec 2019 04:13 #152935
by lendrum
homing with 5i25,7i76 was created by lendrum
I am using PnCConf to set up a wood router with mesa 5i25 and 7i76 The home switches don't work.
If I edit mesa_7i76.hal and change
net min-home-x <= hm2_5i25.0.gpio.08.in
to
net min-home-x <=hm2_5i25.0.7i76.0.0.input-08
it fixes the problem.
Is this a bug in PnCConf or a bug in me?
to
- Thank you received: 5326
20 Dec 2019 14:22 #152945
Replied by PCW on topic homing with 5i25,7i76
Is it possible you chose the wrong tab in pncconf when setting up the home input?
You should choose the 7I76 I/O (#SS0) tab
I made a test config with the current pncconf and got:
# --- HOME-X ---
net home-x <= hm2_5i25.0.7i76.0.0.input-08
# --- HOME-Y ---
net home-y <= hm2_5i25.0.7i76.0.0.input-09
# --- HOME-Z ---
net home-z <= hm2_5i25.0.7i76.0.0.input-10
In the created hal file
# --- HOME-X ---
# --- HOME-Y ---
# --- HOME-Z ---
The following user(s) said Thank You: lendrum
- Thank you received: 1476
20 Dec 2019 14:24 #152946
Replied by Todd Zuercher on topic homing with 5i25,7i76
It is a mistake you made setting up your config in PNCConf.
On the screen where you configure the I/O, Don't select anything on the tabs for I/O Connectors 2 or 3, The tab for 7i76 I/O (SS#0) would be for the field I/0 on the 7i76, that should be where you would connect your home and limit switches. The other two tabs are for using the pins directly on the 5i25 card as GPIO without a Mesa daughter card such as the 7i76.
- lendrum
20 Dec 2019 15:59 #152951
by lendrum
Replied by lendrum on topic homing with 5i25,7i76
Thank you for the help. On the first tab I had entered 0 smart serial ports so the 7i76 tab was missing.
Time to create page: 0.371 seconds
